Question about Frigidaire FEQ1442ES Electric Dryer
Nothing works Power good to dryer but no lights no power at controls
  • Anonymous Oct 13, 2008
    Power good to dryer but no lights no power at controls. Was wired wrong when turn on. Then re wired correctly. what part do I need
    Thanks
  • davvcarr Nov 04, 2008
    that's it !!!!    installed new one today .
      thanks, dave
    Sergeant:
    Champion:
  • 324 Answers
You May have blown the control board.
Posted on Oct 31, 2008
Can anyone tell me why my dryer just flashes and I can not turn it off or on?
Electronic components rely heavily on having a good ground connection. Without a good ground, Mr.Gremlin can make an appearance, anytime, anywhere.https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link may be of some help in a diagnosis.
Oct 23, 2017 | Kenmore Dryers
Bravo 2012 gas dryer control panel
I have the same dryer. My control panel went dead today too. Light in drum works just fine. Nothing working at all on the control panel.
Mar 07, 2014 | Maytag Bravos 7.0 Cu. Ft. Gas Dryer
Nothing works on control panel except control locked sensor light. The buttons were working fine then I went to add more drying time and the buttons do not light up or work.
From the details of your symptom you're indicating a possible intermittent loose connection between the user interface (touch panel) and the machine control board or the voltage supply to machine control board at P1 connector.
Disconnect the power cord from the power source.
  • Disconnect P3 and P4 connectors from the machine control board and then reconnect them.
  • Disconnect P1 connector and then reinstall the P1 connector and then recheck operation.
If the wires are good then you will need to replace the control board on your unit.
Here is a link to the part.
Jan 09, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
I have no power dryer interior light works but nothing on panel?
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 03, 2010 | Kenmore Elite HE4 Electric Dryer
I have no power on the control panel but the light works inside the dryer
I have power to the dryer. when depressing the selector switch, 20 min for example, the ride light illuminates, you hear a click sound but nothing happens
Aug 19, 2009 | Kenmore Elite HE4 Electric Dryer
Sears elite he dryer stopped working
Bad control panel. Replace the control panel at repairclinic.com. When your control panel clicks like that it means that a resistor or solder joint has gone bad and it is cheaper and easier to just replace the board
Feb 19, 2009 | Kenmore Elite HE4 Electric Dryer
Duet sport dryer control lock out on
stop coumting and just hole till light goes out if still no response try cutting power then hold power button down 10-15 seconds this may drain and remaining power to control and allow it to reset ..still problem probably control issuefront interface where buttons are most likelt
Jul 16, 2008 | Whirlpool GEW9250 Electric Dryer
No pwer in Control panel but light is on the the dryer
You may have blown one of the two circuit breakers at the building fuse box. Sometimes they are physically linked together so that both trip at the same time. This is how it's suppose to work but sometimes one will trip leaving you with half power but enough to work the minor circuits. Resetting the circuit breaker is an easy fix. If this doesn't work ohm out the thermal fuses. They are ususally accessable by lifting the top. With it open check that all connector are connected.
Jun 13, 2007 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
229 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
