Question about Hitachi 53UDX10B 53" Rear Projection Television
Power light flashes on Hitachi TV model #53UWX10BA
When I turn on the Set I get no picture or sound. I have unplugged the set and let set idle for over 30 min. When I tryed to turn on the set again the power light keeps flashing.
  • 2 more comments
  • wfletch1948 Oct 12, 2008
    Power light is still flashing
    need a solution
  • erniesc7 Jan 13, 2009
    Power light is on and red but nothing on the screen. Looks turned off but no sound as well.
  • Roger3111 Jan 17, 2009
    power light is on but no pictue or sound
    Sergeant:
    Champion:
  • 200 Answers
Hi
Can u tell me model no and company name so that i can help u clearly..
If u have warranty then u can claim it..
thank you
Posted on Oct 12, 2008
Hitachi 53uwx10ba service mode
are you using an HDMI cable? is it a cheap thin cable or heavy duty?
HDMI cables carry sound but it's possible you don't have it seated completely or it's a cheap cable. or your audio settings on your TV are not set to HDMI if that's the cable you're using. try running your audio setup on the TV Menu.
Dec 03, 2013 | Televison & Video
Screen will not turn off
Model does not sound like Hitachi but if it is have you unplugged the set? The magic focus is a auto convergence circuit in the Hitachi sets.
Nov 01, 2012 | Hitachi Televison & Video
HITACHI MODEL # 53UDX10B has a flashing red light and a buzzing sound
If it was transported likely the set was damaged--one of the three picture tubes used could have been damaged--the flashing light is the set trying to come on and the buzzing is related to whatever is bad.
It needs to be opened and inspected.
May 18, 2012 | Hitachi 53UDX10B 53" Rear Projection...
I have a Hitachi 53uwx10ba power light flashes and tv won't turn on
It is rare in this set but it indicates a short somewhere that is pulling voltage inside the set down---not a do it yourself repair unless you are a Technician with some basic equipment and a schematic diagram.
Have someone look at it from a repair shop or ?
Apr 14, 2012 | Hitachi Televison & Video
No picture no sound, red light on, left unplugged over-nite, no change. Turn on/off a number of times, got back perfect picture/sound. Turn off, same problem, no picture/sound, red light on. Tried...
First if the model number is right here: When the red light is on about 80% of the set inside is powered up and running all out.
On these sets if you turn it off and the red light does not go out one of the relays on the power board is engaged or stuck in the closed position.
If I remember this model it has three black rectangular plastic relays on the power supply board(follow power cord into the set to see if this is the case.)
Relays have voltage and type marked on top (like 12 vdc etc).
Carefully with back removed what I would do is with something NOT metal tap on each relay until (with set turned off) the red light goes out.
That is the bad relay----if set has 3 I usually replace all as only 4 solder connections each and they are not real expensive.
I saw one of these sets where the customer had been gone for a month and when she returned set appeared to be off but Red light for power was on.
The set was so hot I tapped on the relays and then when I knew which was bad shut the set off and unplugged it to let it cool off.
I am saying if you leave the set plugged in and the red light is on There is the chance it may overheat to the point where you could have a fire.
Let me know if you have questions.
SD TECH
Sep 26, 2011 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 53uwx10ba turns on & off when off red flashing light/clic
Same problem. Replaced both convergence ICs about 5 months ago. Worked fince since then and just recently no sound, no video, blinking red on front panel and clicking sound. I suspect that the ICs went bad again and blew a resistor or two. I used cheap Chinese ICs instead of the Sanyo ones and thing this is why. I'll be looking at it again and post solution.
Jan 21, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Red power light flashes and set wont come on
Hi
Turn off the tv for five minutes and then turn on..
thank you
Oct 12, 2008 | Hitachi 46F510 46" Projection HDTV
Hitachi 55FX20B 55 in. Rear Projection - no picture or sound
TV always has high voltage shock risk while repair. As you said you are not familiar with TV repair so better to handle repair person this issue.
Oct 01, 2008 | Hitachi 55FX20B 55" Rear Projection...
51F59A model hitachi rear projection tv
You may need to set your screens look at the picture when you have a real dark background if there is faint lines in the picture then the screens should be set correctly
Jun 11, 2008 | Hitachi 50V715 50" Rear Projection...
Hitachi 53uwx10ba no sound/picture flashing power light cricket sound
Possible shorted cap C702 ? Open E994 pico fuse.....check
carefully with ohmmeter...all fuses and let me know.....T.
Mar 05, 2008 | Televison & Video
Hitachi 53UDX10B 53" Rear Projection Television Logo
199 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
