My Iriver HP120 MP3 player will not charge or come on either with charging or not. when I plug it in to charge the main page and red and green light come on and then seconds later the main page and red light go off but the green light stays on. I charge it for 3 hrs. when I have it charging it won't come on or after I charge it either. What is the problem or did I press A wrong button? can you also give me an estimate of what the cost of the battery runs? Thanx!
SOURCE: iRiver H320 is completely dead
Hi, you can get a step by step video tutorial on how to change the battery here.. http://www.videojug.com/film/how-to-replace-the-battery-in-your-iriver-h320-or-h340 all the best John
SOURCE: Iriver Clix problem
yes i river has got customer support in online but i don t know how efficient it is if you had brought it from india , you better contact the vndor and ask for its warranty support man or else give a try connect the i river to another computer with windows xp (i prefer) and then install the software bundled up with your device and try to format the device via the software and then disconnect the device and power it on it will work i think
SOURCE: Iriver Clix (Gen1)
i lost the driver of my iriver clix gen1 2gb please send the driver on my email address thanx my email is [email protected]
SOURCE: iriver pmp 120 use the wrong charger
try this. the iriver doesn't boot at times ( wrong charger or using the right charger abroad), unlatch the battery and hold down the power button for about 20 seconds. also reset the instrument. hopefully that might work for you.
SOURCE: IRIVER PLUS 3 MEDIA TRANSFER SCREEN
My understanding, as a new user, is that IRiver plus 3 only communicates with the player via UMS mode, which is not the default. Windows Explorer and Windows Media Player only communicate through MTP mode. If you change from MTP (the default) to UMS, it will reformat the player and delete all your files.
In other words, do not use iriver plus 3 unless that is the only software that you want to use. Boing back to MTP mode after a sync or download will then delete all THOSE files you just downloaded.
I just say NO to Plus 3.
Good luck.
