Question about Motorola Mobility RAZR V3
Phone is working but Screen doesn't work its blank
Dear experts,
could u tell me what that kind of problem is it and how it can be fix that my motorola razer v3 phone screen got blank suddenly but phone is working well but i cant see through screen please please tell me how i can fix it by my self. ill be appreciate that alot. thanks
Shazi
  • 4 more comments
  • shazirufi Oct 13, 2008
    o yes many times i tried that and u said it so i tried it again but no use. any way thanks for reply and please tell me what i do more for fixing my phone. Shazi
  • xxx_punk_xxx Oct 15, 2008
    same problem but my sceen is black and ive tried taking the battery out and putting it back in but that doesnt work....
  • Anonymous Oct 16, 2008
    This just happened to me this morning as well and I can't figure it out. The little screw that holds the flip part in place on the one side came out last night but I got it back in. Now this morning the screen is blank. I'm thinking the way I put the screw in must have something to do with it but I can't figure it out. Any suggestions???? I need this fixed
  • gdebrown Nov 29, 2008
    We have 2 RAZR's in a familiy plan..both screens went blank within 24 hours of eachother. I have alot of phone #'s saved to the phone I would like to retreive. The t-mobile store clerk said he could attempt to transfer the directory with a 50/50 chance of success. The problem is if it is not successful the directory is erased. Any suggestions?
  • jason May 11, 2010
    for this you will have to open it and see if the hinge part has pull on the wires and/or maybe unplugged.( no power )
    but first , does the front display ( clock ) work?
    have you tried pulling the battery out for alittle while?
I have a similar issue...left side hinge pin came out...found it in my pocket and attempted to put it in place and then the screen went blank...no luck...but I was able to take the motorola phone toola and retrieve the data, names, etc and move to another motorrola phone I have. A few days later I found a small wire clip thing that must ground or contact something in the hinge...no luck yet fixing it. Help
Posted on Nov 29, 2008
Dear Rim Experts, My Blackberry curve fell onto concrete after being flung of the the headphones - I have no idea how it happened but it did... when this happened before I picked it back up I saw the...
YES IT CAN BE FIXED U CAN TAKE IT TO UR SEVICE CNTRE THEY WILL FIX IT ,THIS IS QUITE C0MMON PROBLEM OF SCREEN GOING WHITE OR BLANK.DO TELL ME ONCE IT IS FIXED.BEST OF LUCK.
Sep 03, 2011 | RIM BlackBerry Curve 8520 Smartphone
Screen is totally blank on the handset of my Panasonic phone. Model # KX-TGA931T How do I fix this please....besides telling me to change the batteries because I already tried that several times. Thank...
if you have changed the battery then they might be fault with the screen, if you see the power light or the key pad lights on then you should visit an expert shop for repair. he may replace your screen for you.
May 17, 2011 | Cell Phones
Hello Expert. Hope you are fine. All sudden, i got problem with my Iphone 2G. my half screen icons from top side is not working where as half icons are working including icons in gray line which...
Your digitizer is broken, and with the 2G you will need to replace the entire screen to fix it. It is probably not cost effective to do so.
Mar 21, 2011 | Cell Phones
Blank and white screen solution
Hi,there are two kinds of white screen in phone,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage lcd the phone will detected
by computer because its software is still working...so ,
the problem of your phone am sure is the second one ,
corrupted software....your phone needs to reprogram,and
need to go to the model of the phones care center to fix you problem...
And also flex can make screen go blank and or white.(if it is a flip phone)The flex is a connector that connects the screen to the phone board of the phone.That can also be the cause, when the flex is damaged,it can cause blank and white screen display .
i hope ,i will help you ,thanks for trusting fixya...
Sep 16, 2010 | Cell Phones
My blackberry pearl flip 8220 cellular phone not working
hello,it is a flex problem that mainly occurs to flip phones as a result of various opening and closing of the flip.all you need to get is a new flex to fix up the faulty one.you can kindly take it to an authorized expert to fix it up for you if you are not electronically inclined.and also it could be a affect the inner screen soonest if not attended to immediately.it could also be that the outer screen is bad so after the flex is replaced if the screen still does the same then you will need to fix up the screen.
please kindly rate this solution if it's helpful,
take care.
Jun 16, 2010 | RIM BlackBerry Pearl Flip 8220 Cellular...
Blank screen
if the screen is not cracked or kind of dark, then its not a screen problem.
Flex that connects the screen to the phone board must have loosed contact.
You need to loose the phone in other to fix this.
Take care.
Jan 12, 2010 | Nokia N95 Cellular Phone
Phone cuts out
dear, you have to check it by removing battery.. if doesnt work then surely its strip problem... the flip and slide phone have this kind of issue...you have to check it by an expert tech.
. goodluck.....
Aug 06, 2009 | Dual Electronics CECT P168 Cellular Phone
The Screen on my phone is blank/white
Dear,
first of all tell me what kind of model u have and the brand of ur phone.
if u have any kind of flip or slide phone then it is because of strip brakage. Totally or partially. If the strip is partially broken then can be repaired if totally or more than repairable then u have to replace the strip and ur cell will be in working position.
do it plz.
dont forget to rate it as it will fix the issue.......
Feb 19, 2009 | Cell Phones
Blank Screen
GO TO THE INDIAN KIND OF MEN THAT SELL PHONES AND THINGS LIKE THAT .. AND CHARGERS AND HEAD PHONES.. THEY WILL FIX YOUR SCREEN FOR YOU..! BUT YOU WILL HAVE TO PAY
Jul 04, 2008 | Sony Ericsson K550i Cellular Phone
Mobile phone
What kind of phone do you have ?
You should try removing the battery and turning it back on.. If this doesn`t help it`s probably a software related problem. I can`t help you more unless you tell what kind of phone you have.
Jun 29, 2008 | Nokia N70 Cellular Phone
Motorola Mobility RAZR V3 Logo
115 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
