Question about Cameras
Digimaster Happycam 5010 Problem: The shutter that protects the lens is stuck fully open. The camera is stuck with lens fully extended. ERROR 2 appears on the screen. The LED near the top left of the display flashes red. The camera will not take pictures. Before the camera got stuck the movement was getting more and more difficult to achieve. I needed to switch the camera off and on. This camera seems to be identical to the Premier Camera SL-8.
  • 10,594 Answers
Camera lens mechanism is broken, need new lens assembly. Cost would be more then camera worth. Better to get new camera.
Posted on Oct 12, 2008
  • Cameras Master
  • 19,396 Answers
That is probably a lens error, or a problem with the main pcb inside the camera.
Only easy fix is checking if the problem disappears by removing batteries and putting them back.
  • Ginko
    Ginko Oct 12, 2008
    What you are experiencing is a common lens error.
    This happens because the gears that allow the lens to extend and retract are bent, deformed , or dirty with dust, sand etc on the inside.
    To fix it in the proper way, the lens barrel should be taken apart, and mounted back after fixing the problem.
    To restart it temporarily you can try helping gently the camera lens back in place, while you turn off (or on ) the camera, by pushing it with your finger.
    If that does not work, the camera must be disassembled, in this case the job should be done by a qualified technician.
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
When trying to turn the camera on, the lens will not extend fully. it extends partially, and then the camera turns itself off, leaving the lens in the partially extended position. you have to try and turn...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 23, 2011 | FUJIFILM FinePix JX250 Digital Camera
E18 error on canon digital camera s200 powershot dropped it and now the lens is stuck halfway out/in The lens will not open, it was not dropped. I get e18 error.
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
You can Try the following also;
Remove the batteries from the camera, wait a few minutes. Put a fully charged batteries back in and turn the camera on. if it doesnot work then,
2: Remove the batteries again, as also remove the memory card. Then install the newly charged batteries, when you turn it on it should come back to life.
3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful to overcome any grit or sand particles that may be jamming the lens.
4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Try the above and let me if its any help.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Mar 07, 2009 | Canon PowerShot S200 / IXUS 178 Digital...
Shutter won't close all the way
The lens cover of PSA60 opens along with the move of the objective lens. Normally the camera will sound an error beep when the lens does not end to the end position -- the lens cover is also not fully opened. In reverse, the lens will be retracted when the camera is switched off.
The "shutter" (outside lens cover) might have something stuck inside the blades or other mechanical parts that prevents the lens cover fully closed. Try to blow with a clean air (no hot air - because it can damage the electronics or plastics).
Or maybe the blades are probably not flat that may create resistance on the surface. Try to flatten the blades by hands.
Or maybe the mechanical systems need to be calibrated (by Canon service center).
My suggestion, try to exchange/trade-in your PSA60 with the latest model at the Canon center, because I have done it last year (trade-in with PS S5IS).
Aug 08, 2008 | Canon PowerShot A60 Digital Camera
Lens doesn't open fully
Sounds like something has contaminated the protective shutter.
any idea what?
If its something sticky like coke then its unlikely to cause further damage, but if its grit or sand I wouldn't keep trying to open it as it may scratch the lens.
I don't specificly know this camera but have have had experience on many like it.
Basically the shutter needs removing, usually this involves removing the trim surrounding the lens which is usually held on with double sided tape but can be very well held on and the surround easily damaged then the shutter is often clipped in or held in with a couple of tiny screws.
It can then be removed and washed with isopropyl alcohol.
If its not something you would want to attempt yourself a good camera shop that offers repairs should be able to help.
although if the lens is contaminated with sand or grit, eventually it may work its way into the gearbox and jam the lens..
best of luck
May 26, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Lens cover jamming
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Aug 28, 2006 | Samsung Digimax 250 Digital Camera
Cameras Logo
76 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
