Question about Epson Aculaser C1100 Printer
Swopping cartridges When I first set up my Epson C1100, I stupidly put the yellow toner in the magenta slot and visa versa. The printer now prints green images in a brown colour. Can I remove the cartridges and place them back in the right positions? If so, how do I do this?
  • bedfordi Oct 13, 2008
    many thanks, but how do I remove the cartridges since I can't see how to move them round
    Problem Solver:
  • 8 Answers
You need to use the menu on the printer to move the appropriate cartridge around, one at a time. Whatever the first colour you replace, you may need a spare cartridge, as this printer does not like empty slots!
With the printer in idle mode (you may see Ready or Sleep in the LED), go to the Reset menu by pressing the small button with the Enter symbol beside (crooked arrow).
Then press the down (bottom button of the four small ones) until you see "Change Toner ?" and press the Enter button again.
The printer will move the appropriate cartridge to the front and you can change it.
As the previous poster mentioned, you are going to need some LINT FREE cloth or printer cleaning tissues (don't use normal tissue to wipe the inside of the printer under any circumstances - you may end up with bits left inside).
Do a couple of test prints until the toner colours clear up.
Posted on Oct 29, 2008
    Scholar:
  • 136 Answers
You can swap them again, but be careful because it is a job that requires some kleenex, for the ink will spill easily from the cartridges. I am really not sure if the jets are part of the cartridge or not, but if they are not, you will get weird printings for a while.
Good luck.
Posted on Oct 12, 2008
  • velut_umbra Oct 13, 2008
    Ok. There must be a button with a teardrop symbol on it. You just have to open the lid and press that button for a few seconds. That should make the cartridge slots move around for a while and finally stop in the position where you can remove them.
My Epson Aculaser C1100 shows 'change toner K'
I've just replaced the the Yellow and Magenta colour toner based on your fantastic advice...
gbdmequick
Jul 17, 2012 | Epson Aculaser C1100 Printer
How exchange cartridge for Epson C1100
Make sure that Ready or Sleep is displayed in the LCD panel.
Select Change Toner X (The letters C, M, Y, or K appear in place of X, indicating the colors Cyan, Magenta, Yellow, and Black.) in the Reset Menu on the control panel.While the cartridge X you selected above moves to the cartridge replacement position, Please Wait appears on the LCD panel.Replace Toner X appears in the LCD panel when the cartridge to be replaced reaches the cartridge replacement position.Then Open Cover A.Push up the right lever to unlock the toner cartridge. Then remove the toner cartridge from the printer.
May 15, 2010 | Epson Aculaser C1100 Printer
Epson acculaser c1100 ink replacement
K- black
M- Magenta (red)
Y- Yellow
C- Cyan (blue)
Hope this helps.
Jul 03, 2009 | Epson Aculaser C1100 Printer
Epson Aculaser Need to bring faulty cartridge to front
On the LCD display choose the 'Reset Menu' Then within that menu keep going through the options till you get to 'Change Toner M' (if it is Magenta). Once you select the appropriate 'Change Toner' it will rotate to offer the correct toner.
Apr 06, 2009 | Epson Aculaser C1100 Printer
Changing a cartridge C1100
On the LCD display choose the 'Reset Menu' Then within that menu keep going through the options till you get to 'Change Toner M' (if it is Magenta). Once you select the appropriate Toner it will rotate to offer the correct toner. Open up the front cover, reach inside and change the position of the coloured part of the cartridge on the right to the Unlock symbol and then ease the cartridge out. It comes out at a slight angle as the part you move to unlock it comes out first. Put the new toner in and turn the coloured part to the locked symbol.
Please take a moment to rate this solution, thanks.
Mar 24, 2009 | Epson Aculaser C1100 Printer
K toner low
C - is for Cyan
M - is for Magenta
Y - is for Yellow
K - is for BlacK
Jan 25, 2008 | Epson Aculaser C1100 Printer
How to change cartdridge for other color???
If you wait until the colour has completely run out, you will see a message to that effect, and the correct cartride will be presented. If you wish to change before this:
1. On the printers' control panel, press the "right" button (labeled no. 3) once and then the "down" button (labeled no. 4) until you see the RESET MENU.
2. Press the "right" button (labeled no. 3) once.
3. Press the "down" button (labeled no. 4) until you see "CHANGE TONER X" appear on the screen (where X is either C, M, Y or K, Cyan. Magenta, Yellow or Black).
4. Press the "right" button (labeled no. 3) once. The printer will rotate the toner carousel to the correct position for you to change.
5. Open the printer door and change the toner as normal.
Jan 20, 2008 | Epson Aculaser C1100 Printer
Wrong colour
This could one of a few fairly major problems. The easiest way to track down the fault is start by replacing the consumables - make sure you install them in the correct positions - it is possible on the C1100 to put them in the wrong places!! Change the toners first. Most importantly the magenta and yellow. Print several pages. Use MS Paint or similar to create a page with all four component colours on (cyan, magenta, yellow and black)in large blocks (see image below) and print them full page. Now look at the print and see if any one colour is missing or has reduced density. If you have a spare PCU you should but that in next. Let me know what the print outs look like and we will progress to the next step.
Aug 13, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
130 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
