Question about Durabrand 5.1 Surround Sound Computer Speakers
Duraband HT-400 It stays hot when the power is off how do I cool it??
  • 59 Answers
It has an amplifier inside the wooden case and its normal for amps to get warm during operation.
Posted on Nov 14, 2008
HT-5100, PROTEC notice on display and will not power up ?
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Aug 11, 2011 | Samsung HT-DB600 System
Samsung HT-DS610 Will not stay on. display said Hello,(Protection), Good by.And then goes off.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 01, 2011 | Samsung HT-DS610 System
Why does protection come up on the display of my samsung ht-x200
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Mar 27, 2011 | Samsung HT-X200 Theater System
My dvd player samsung ht tq85 shows a red light and wont power on?
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 23, 2011 | Samsung HT-TQ85 System
My samsung ht-x50 receiver stays on for about an hour then shuts off then if you turn it back on it shuts back off and it will do it all the time after it rests....the sleep is off so what is the problem
It's probbaly overheating.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 07, 2011 | Samsung HT-X50 System
My samsung ht-p10 theater system displays protection then shut down
Feb 06, 2011 | Samsung HT-P10 Theater System
I have a Samsung HT X 30 home cinema after about 15 to 20 minutes turns off saying protected??
Feb 06, 2011 | Samsung HT-X20 Home Cinema 600W Theater...
Hi, my NEC HT 1100 shows following problem. After starting, there are two horizontal black and white stripes moving from the top to the bottom of the screen. They stay for hours then they disappear. What`s...
Dried out capacitors that conduct electricity very poorly when cool will begin to work normally for a time when over heated, lenses and display components that are warped may also regain a workable shape when hot. It's very common for integrated circuits, etc. damaged by heat or electrical surge to show symptoms cool that don't manifest when the device gets hot. But they are indicators of an imminent failure.
Most likely the 3LCD component that generates the picture or the integrated electronics themselves have been damaged. This can happen over time from heat for example if the air filter doesn't get changed or from a power surge.
Jun 04, 2010 | NEC HT1100 Multimedia Projector
No user manual
All speaker cables go into the surround sound system, they should be colour coded, then phono cables into the TV or just the the normal green audio cable into the green audio hole on the computer
Feb 18, 2009 | Durabrand 5.1 Surround Sound Computer...
Dishnetwork Remote Code
Dish Network does not support duraband. Some thing are made by another company so their code might work. But Duraband is one that doesn't work.
Dec 19, 2007 | Durabrand HT-3915 System
Durabrand 5.1 Surround Sound Computer Speakers Logo
104 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
