Question about Roper RGX4634KQ Gas Dryer
I still need instructions on how to remove the motor
My Roper RGX4634KQ Gas Dryer hums when I press the start button. I suspect the motor has gone bad. Before I spend $100 on a new motor, is there anything else that could be causing the dryer to do this?
How do I remove the motor?
  • 943 Answers
Hi. not unless the blower is jammed with something.the top comes of, the front comes off the drum comes off replace the motor. if you need my assistance lets chat. thanks
Posted on Oct 16, 2008
I moved and cannot locate the pilot/ignition source on the dryer to relight it.
It's been many, many years since dryers had pilot lights. Look for an igniter that may have gone out. It should be behind a service door.
May 30, 2015 | Roper RGX4634KQ Gas Dryer
Recently had 8" of water in basement. When dryer
You may need to call for service...what your describing sounds like the motor is bad..give it several days and see if it does start but i suspect the motor is bad
GENE
Sep 10, 2011 | Roper RGX4634KQ Gas Dryer
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
The dryer is humming but not spinning when i removed the top cover i see the belt in the middle of the drum. Do you know where it supposed to go?
is belt disconnected? Is belt broken? Will dryer rotate manually? if so ,
I suspect that the belt broke. order a new belt Home depot has a good parts service or try other local appliance places. You will have to disconnect power first, Remove front panel to access drum Dont forget to unplug door switch there should be a plug front top right, in the rear on the bottom there is a motor and an idler/tensioner. install the new belt and under tensioner Yes the path will seem awkward and re assemble. Also now is the time to vacuum lint out
Dec 30, 2008 | Roper RGX4634KQ Gas Dryer
Gas dryer hums when I press the start button but won't start
hi thats a sign of a faulty motor . replace the motor thanks the appliance doc.
Oct 12, 2008 | Roper RGX4634KQ Gas Dryer
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Jul 21, 2008 | Roper RGX4634KQ Gas Dryer
Roper gas dryer will not start
hi that sounds like a bad motor.
Jul 14, 2008 | Roper RGX4634KQ Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
77 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
