Home | Canon | Elura 100 Mini DV Digital Camcorder | Whenever I turn it on
Canon Elura 100 Mini DV Digital Camcorder
Problem for Canon Elura 100 Mini DV Digital Camcorder
By Kat309 on Oct 12, 2008
whenever I turn it on theres just a blue screen and I can't get it to record
Best Solution
posted on Apr 24, 2009
Very Helpful)
vk123214
Rank: Apprentice
Rating: 100%, 1 votes
This tip was fantastic. It worked like a charm. I did exactly as instructed and my camera with the same blue screen problem is now fixed.
Thanks...
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 14, 2008
Very Helpful)
KCMiller3
Rank: Apprentice
Rating: 96%, 4 votes
It took me a while to figure this one out but I finally did and mine is back to working perfectly. The problem: The Play option worked fine but the camera did not. When turned to camera mode the blue canon screen would come up and then freeze. The only way to turn it off was to remove the battery.
The fix: I was brave enough to take the entire outer shell off the camera. On the main board, underneath the screen/battery side, all the different parts are connected together. There is a single connector from the lens that had come out of its port. The ribbon connector must have somehow been shaken out of the port at some point. With needle nose pliers I carefully fit the ribbon connector back into the port. I carefully reattached the outer shell and everything was back working!
I will warn you that this task takes some time due to many many screws. It's a lot better than sending it off for hundreds of dollars though.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #3
posted on Oct 02, 2009
Not Rated)
JulianDave
Rank: Apprentice
Rating: 0%, 0 votes
Glad I found this!
I just sent my Elura 90 in to Canon for this exact problem and they're estimate to fix it is $161.40. At least they do estimates and return shipping free. When I get it back I'm going to try this. Thanks!
Was this helpful?
Yes
No
Solution #4
posted on May 10, 2009
Not Rated)
joni606
Rank: Apprentice
Rating: 0%, 0 votes
Ok I just finished this. I followed KC's advice and I did solve the problem but let me give you some warnings. This took me about an hour and 20 min to figure out. I would not try this again without having plenty of time set aside without interruptions. Luckily the tools I started with were enough. I used a tiny screwdriver with a free spinning end and a magnetized tweezer. I found out the magnetized part was really helpful when I was putting the whole thing back together. I kept the screws separated based on which side or part they came out of and surprisingly I used them all up at the end. There are a lot of screws and it wasn't really clear to me where to start and some of them are on the inside. One is near the lens under a tiny plastic flap that I picked off with the tweezer. Also the shell didn't come apart that easily and I got really scared that I was going to break it or not be able to get it back together but actually putting it back together was way easier than taking it apart. When I finally got the battery/ screen section off a connector to the battery came loose and I had to reattach it before putting it back together. Check your power before putting everything back. The connector that caused the problem was the first orange on the left. I think there were 3 total going accross the top. It was only a tiny bit loose and I just pushed it back in with the tweezers. Now my camera works perfectly! Thanks for the help KC!
Was this helpful?
Yes
No
Popular Solutions for Canon Elura 100 Mini DV
Questions and Unsolved Problems for Canon Elura 100 Mini DV
Do you recommend Canon Elura 100 Mini DV Digital Camcorder?
Answer
Answer
sometimes when I put a tape in, it just starts racing and it says "remove cassette".... (More)
Answer
I lost the software that come with my Canon ELURA 100 A
Answer
My Elura 100 only boots to ''CANON'' blue screen in camera mode. It seems to boot ok in play mode.... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon Elura 100 Mini DV...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
