My Sony tv model kv27v42 will not recognize the remote control signal. I have ruled out the remote being the problem. I assume it has something to do with the remote sensor on the tv itself. I live in a very remote area where there are no repair shops. Is there a part I can order and install myself?
  • alandcami Oct 12, 2008
    At first I thought it was the remote, so I bought a universal remote and programmed in the appropriate numbers. No success. I foolishly assumed I had bought a defective universal remote and bought another. When this also did not work I tried programming it for the other devices (e.g. VCR, DVD) and it works fine. Hence my conclusion that the problem is in the TV, not the remote.
  • 200 Answers
Well.. I would check the followiing:
Check the battery
or else Change the remote..
thank you
Posted on Oct 12, 2008
  • Thafa Oct 12, 2008
    can u tell me where r u..
    If u have warranty means then claim it..
    try this link for new remote
    thank you
  • 10,594 Answers
Have you tested your remote? You can test it by using any camera even camera in mobile phone.
  • Shahid Electronics
    Shahid Electronics Oct 12, 2008
    I can provide you Remote Sensor part number and where you can but it, but let me confirm first TV remote.
    Shahid Electronics Oct 13, 2008
    Infra red Remote sensor circuit part code is IC004and its part number is...
    " 8-742-014-11" HYB IC SBX1981-51
    You can order this part at Parts Store and price is approx $13
    Thank you.
Bravura not recognizing an Apple TV signal
You need to connect using an hdmi cable from the appletv to the tv, and notice which hdmi socket on the tv you use (eg 1 or 2 or 3...) Then make sure the light is on green on your apple tv by using the supplied remote control to power it up. And then you need to make sure you have chosen the correct hdmi source on your tv remote control (eg hdmi1 or 2 or 3...).
Sep 16, 2014 | Televison & Video
Samsung 55
You did not say what the model number is.
The next thing to try is to get something to block the electric eye that sees the remote so that you can rule out a stray signal from some other LED source. You said that it does not happen all the time, so what makes it stop?
Jul 08, 2013 | Televison & Video
Hi my name is Oscar I have a tv element model FLX-3211B and do not work the remote control codes sony RM-VZ320 and need help please!
Please reset the codes and try again. You must replace the batteries by new ones type alkaline b) clean the contacts batteries c) retight the spring contacts batteries with pliers d) open the remote control for clena the keypad switch from dirty, dust, oxide, bad contacts or open , remember they send infrared signal from Syscon to the microncontroler Receiver. see the blck..d
go to the next web pages, give your model, mark. +
God bless you
Jul 29, 2012 | Sony RM-VZ320 Remote Control
I have a Dish IR. Not sure of the model number. Uses 4 AAA batts. The problem I have is the every function seems to work fine except for the volume control. In order to change volume I have to use the TV...
It is possible that those buttons have failed, but a bit more likely the remote lost the codes for the TV itself... since almost everything the remote controls... is on the DVR. I apologize if I am guessing wrong in assuming other "TV" buttons (like INPUT) don't function either.
To re-program your remote to recognize your TV (like when the tech first set up the system) choose from the following receiver types to find the correct remote control TV codes for your Zenith.
Remote TV Codes for 722/622/612/411/222/211 Receivers
Remote TV Codes for 625/522/512/510/508/501 Receivers
Remote TV Codes for 811/381/322/311/301 Receivers
Aug 29, 2011 | DISH Network IR Remote Control
Have a 2006 Sony LCD Bravia 46" TV. Receipt from
I don't know the relationship that Cosco has with their customers however the best way to get the CORRECT model number is directly off of the back of the TV. The model number you have is not complete. It should have something like a "KVR" or at least something beginning with a K.
Hope this helps,
Best Regards,
Jan 26, 2011 | Sony Televison & Video
Hard drive needs format
You need to download below manual... it seems it is all similar, read below as well.
Your remote might be using the wrong "infrared code", so the recorder when in service mode cannot understand it. Sony offers a feature that allows their recorders to operate under three different remote control signals, so if you own more than one Sony the remotes will not interfere with each other. The standard remote code the recorder is set to when new is "3". If by some chance you changed that code yourself, or the store changed it, then your remote is not sending signals that "service mode" can recognize.
You will need to change the remote's control code to "3" before the recorder will recognize it while in service mode. To change the remote code, take the remote to another room away from the recorder. Hold down the enter button, then press the 3 button. Hold both buttons down for 7 seconds, then release. Try the remote on the recorder: it should now be recognized and able to operate the service menu. Upon exiting service mode, the recorder may revert back to whatever code was last set, and the "3" codes that worked in service mode may not work in normal recorder mode. If it does not, do the same as before: try changing the remote control from "3" to "2" or "1".
Feb 26, 2010 | Sony HARD1000
Re-program a Sharp remote control for LC-46XD1E
Are you sure it is the remote that has stopped working? If you get something like a camera phone and put it over the LED on the remote and press the buttons (with the phone in camera mode) the camera will pick up the infered signal from the remote. This will rule out if it is the TV or remote.
If you get the infered signal then your TV is faulty (possibly a main pcb fault) if you dont then it is your remote. Which as far as I am award you can not reprogram, but you can get them from places on the internet (search on google) for a couple of 10 pound.
Jan 30, 2010 | Sharp Aquos LC46XD1E 46 in. HD-Ready LCD...
Are picture tubes for Sony KV27V42 still available?
No not likely. If it was it would be not economical to replace - usually between $300-$400.
Nov 24, 2009 | Sony KV-27V42 27" TV
Problems with my Sony TV
check out this link and they will provide you the required part just tell them proper model number of the unit.
Oct 12, 2008 | Sony Televison & Video
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
