Question about LG WM2688HWM TROMM SteamWasher
LE error My washing machine is a Tromm ultra capacity direct drive system, Model number : WM2277HW. The machine turns itsself off and displays the following Error massage:LE Please advise
  • olson1951 Oct 12, 2008
    I am also having the mildew/mold smell in my washer and in my towels and other things. I try to leave the door open, but if I close the door ir reeks upon opening. I do not have a manual for this machine. Does anyone know how I can find one? (FREE)
  • olson1951 Nov 03, 2008
    Thanks for hint. What is a-fresh?
    Problem Solver:
  • 16 Answers
Try using a-fresh its should help you out.
Posted on Nov 03, 2008
My lg tromm model number wm2277hw/01 has the error code le show 2 seconds into the cycle even if nothing is in the washer what is going on
Hall sensor needs replacing (motor position sensor). Pretty easy and under$20. Check out appliancepartsproscom, repairclinic.com or YouTube for how to videos.
Jan 22, 2017 | LG Washing Machines
LG Tromm WM2277HW will not spin both directions, LE error.
clean filter check that its drained all the water out any blockage and the machine will not spin
Nov 28, 2011 | Washing Machines
LG Tromm WM2277HW will not spin, LE error
the pressure switch is jammed on meaning the water has not empty le reading the is excessive water in the machine
Nov 28, 2011 | LG WM-2277HW Front Load Washer
I have washer machine wm2277hw LG., Tromm., this machine have flash light "" LE"" Error, what is the problem?
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
May 22, 2011 | LG WM-2277HW Front Load Washer
"LG Tromm WM2277HW will not
Kevin
Mar 27, 2011 | LG WM-2277HW Front Load Washer
LG Washer Model #wm2277hw
It is a motor error
• The connector in the LEAD WIRE ASSEMBLY is not connected to the connnector of STATOR ASSEMBLY Reconnect or repair the connector • The hall sensor is out of order/defective. Replace the STATOR ASSEMBLY
Apr 19, 2010 | LG WM-2277HW Front Load Washer
Our LG Tromm Washer is struggling to spin. Humming sound in the beginning and then displays LE on the panel. Heard it may be the Stator Sensor/Part. Any Advise please!!!
Definitely the Stator/Sensor/Hall switch. Go to http://www.mcminone.com and order part number 6501KW2002A (if your machine is model number WM2277HW). Remove rear panel, remove three retaining screws for sensor wires at left bottom of drum, remove drum outer retainer bolt in center, stator assembly is now exposed. Remove bolts holding stator assembly (I think there were six) and replace switch assembly by lightly prying tab locks off of stator. Press on new switch and reassemble...
Jan 23, 2010 | LG WM-2277HW Front Load Washer
LG TROMM displays LE
LE stands for Load Error,
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Jun 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE DISPLAYING
le light on lg tromm wm2277hw
Jan 28, 2009 | Washing Machines
Turned on my washer a TROMM LG wm2277hw and at every cycle turn it beeps LE
LE means a faulty motor. The motor is called the "stator" in this machine. Located behind the back panel. Pretty easy to replace in this machine. Replace the stator and it will work like new!
Apr 07, 2008 | Washing Machines
Washing Machines Logo
721 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
