Question about Frigidaire GLTF2940ES Front Load Washer
Black mold Hi, I have black mold inside the rubber seal of my washer. I have been scrubbing and scrubbing, but it won't come out. I have run bleach through the machine and wipe it dry after each wash. What can I do? I do have an extended warranty, will they come out and try and fix this? I have had a cold and sore throat since August and am wondering if the mildewy smell in my laundry room and kitchen are the reason. HELP is needed. Any advice for me?
  • 29 Answers
You can try a product called Affresh it's supposed to work quite well to maintian a clean washer. If you already have a smelly washer you should run a few cycles using Affresh. You also want to make sure you're using HE soap (it will have an HE oval shaped logo on the detergent bottle). If you're not soap residue will build up in the machine and start to smell.
Posted on Oct 13, 2008
My Frigidaire Affinity washer has black mold on the rubber seal .how do I remove it .
it takes 5 cups bleach put some in detergent cup the rest inside the washer run full cycle then fill wash at least 1 more time to make sure bleach is gone
Jul 09, 2014 | Frigidaire Washing Machines
Black scum forming forming on rubber seal on inside of washing machine door
  • 1 Put on rubber gloves and safety glasses before commencing the cleaning process.
  • 2 Lay an old towel or drop cloth on the floor under the front of the washer to prevent floor damage as you clean.
  • 3 Fill a plastic cup with bleach and dip a tooth brush into the bleach.
  • 4 Remove the toothbrush and scrub the washing machine gasket with it to remove the black mold from it. Hold the gasket open with the fingers of your other hand so that you can clean the center grooves of the gasket where the most mold is likely to grow.
  • 5 Rinse the toothbrush in the cup of bleach and continue cleaning until you have removed the mold from the entire gasket.
  • 6 Wipe the gasket with a paper towel to remove excess bleach residue and any remaining mold.
  • Jul 02, 2011 | Zanussi Washing Machines
    I have a frigidaire front load washer and the rubber seal if full of mold. How can I get rid of it?
    First you should reach deep into the front door seal and run your fingers around. There is probably slime in there. You will need to thoroughly clean this with a bleach water mix about 50-50. You might need to pull the seal almost inside out to get in there good. If after scrubbing you still have black in the rubber the mold will come right back in that case you will need to replace the seal. They are not to hard to replace but a little tricky. Here is a link that should help if you need to replace the seal or if the wire ring pops off when cleaning. Now if all cleans up well or you replaced it be sure to wipe out the seal after each use (deep in there) and /or leave the door open.
    If the seal is clean and no mold present and it still smells then you likely have a clogged drain pump filter or pump. Here is a link that should help cleaning a drain pump
    Oct 23, 2010 | Frigidaire ATF6000ES Front Load Washer
    Hi, can u show me how to clean my washer to get rid of that moldy smell. there's also mold around the rubber ring around the opening and it feels slimy. Can u please help
    First you should reach deep into the front door seal and run your fingers around. There is probably slime in there. You will need to thoroughly clean this with a bleach water mix about 50-50. You might need to pull the seal almost inside out to get in there good. If after scrubbing you still have black in the rubber the mold will come right back, in that case you will need to replace the seal. They are not to hard to replace but a little tricky. Here is a link that should help if you need to replace the seal or if the wire ring pops off when cleaning. Now if all cleans up well or you replaced it be sure to wipe out the seal after each use (deep in there) and /or leave the door open.
    If the seal is clean and no mold present and it still smells then you likely have a clogged drain pump filter or pump. Here is a link that should help cleaning a drain pump or try this one for cleaning a ge drain pump filter and this one for cleaning/replacing a Kenmore drain pump
    Oct 07, 2010 | Maytag Neptune MAH9500A Front Load Washer
    I AM ALWAYS GETTING MOLD INSIDE THE LG FRONT LOADER. THE RUBBER SEAL IS ALWAYS MOLDY
    Hi
    Try using bleach with hot water, run a cycle with hot water and bleach. Or spray bleach +water mixture on the seal. Run a cleaning cycle with hot water and bleach or vinegar at least once a month to reduce the growth of mold in other parts of the washer. If the growth is very high then try and leave the door open for 4-5 hours and let it dry and then spray the bleach+water (3:1) mixture on the seal. Let it dry for another 2-3 hours. You may need to change the seal in case of extreme growth of mold. Hope this helps...
    Daniel
    Aug 30, 2010 | LG WM-2077C Front Load Washer
    There is mold around the rubber and in the inside of the rubber on my Front Load. How can I get rid of this? Is there a product to clean front load washers?
    Hi.
    The mold is an enzime from the washing detergent or softener. It attacks certain rubbers and causes them to turn black. Eventually it will cause a musty smell which will go on the clothes.
    The only way to remove is by replacing the door seal.
    If you try bleach etc then it will cause the mold to get worse.
    Hope this helps
    Aardvark Repairs
    Nov 16, 2009 | Frigidaire ATF6000ES Front Load Washer
    Black mold on washer door seal
    this is a very common problem with the neptune washers.
    use a javex and hot water solution and scrub the rubber boot.
    you should also do an acid wash. (hot wash with bleach, and no clothes) if there is mold on the boot it is inside the washer as well.
    There is a way to prevent this. when the washer is not in use, hang a small towl on the washer door, and do not close the door.
    this will allow for air movement in the washer
    May 27, 2009 | Maytag MAH6700AWW Neptune Front-Load...
    Mold issue on front gasket
    A solution of bleach and water will do. Just wet the rag and rub it down well. When this is done you may still have the marks but the mold is dead. If you want it to be completely clean you may need to replace.it.
    Jan 08, 2009 | Frigidaire Affinity ATF7000E Front Load...
    Black mold growing on rubber gasket and under rubber gasket in Whirlpool Duet front loading Washer
    The solution? Plain old bleach.
    Scrub rubber seal on door. Run the bleach through the machine once a month to keep clean.
    Keep door open after each wash to ensure that it dries out properly.
    d
    Oct 12, 2008 | Whirlpool Washing Machines
    Frigidaire GLTF2940ES Front Load Washer Logo
    117 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
