Question about Refrigerators
Kenmore side by side ice maker/water dispenser
Model 106.5673*602 there is approximately 50' of excess hose wrapped behind the crisper's in the refrigerator. This I believe contributes to the poor water pressure that is dispensed and my question is can I cut this line and make it shorter with a pressure connector?
fridgetech
  • 473 Answers
SOURCE: Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Posted on Oct 05, 2007
  • 100 Answers
SOURCE: Kenmore Refrigerator stopped dispensing water
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Posted on Oct 30, 2007
SOURCE: Kenmore Side by Side Refrigerator - ice/water dispenser
The water will not dispense, its worked since we moved in but last night it just stopped working.
Posted on Apr 16, 2008
duby1990
  • 370 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
I had the same problem with our Whirlpool Gold. Which by the way was just out of warranty. The guy who repaired the problem told us that since there were so many replacement dispenser motors at different supply locations that there must be a problem. I think that the root cause is the arm in the ice holder is hard to move, and it burns the dispenser ( #2252130) motor out. Whirlpool should get to the bottom of this and offer free or reduced repairs. Motor # 2252130
Posted on Jul 29, 2010
Can I take the freezer door apart and wrap the water line with more insolation
No, you can't. The line goes into the mold of the machine with no access there.You have either an air leak in the dispenser area, around the ice shoot possibly, or the resevoir, which is located on the refrigerator side in the lower area behind the drawers is freezing, which is most likely the case. There are vents on the lower section for the crisper drawers. If you take out the drawers you'll find a roll of 1/4 " tubing which they call a resevoir that cools the water down. This is probably frozen,and you can insulate this, but I would raise the temperature in the fridge side or close the vents to the crisper area.
May 08, 2012 | Whirlpool ED2FHEXN Side by Side...
Water dispenser just stopped working. Ice dispenser still works and the refrigerator has a new filter
two possibilities
1) the water valve is defective it has one inlet from the house plumbing,two outlets, one for i/m one for water dispenser
2) the reservior that chills the water is frozen, it is located behind the lower crisper drawers in the ref. to see if its frozen remove crispers and shelves and tap on it , if hollow sounding it's not froze if solid sounding its froze. to thaw it turn off unit for at least a hour
Jul 21, 2011 | Kenmore Side by Side Refrigerator
My ice maker produces ice with white flakes in it, and slowly.
If you also get the flakes with the water from the water dispenser it could be the water chiller reservoir behind the crisper in the fridge. If it's just the ice maker the non stick surface in the ice mold may be coming loose.
Oct 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
On my Kenmore model 106.74254400 refrigerator the water dispenser quit working. I push the button dispenser but nothing happens. The ice maker is working fine. Could it be the water dispenser switch?
It could be the switch. It also could be the resevoir is frozen behind the crispers. It could be the water valve has a bad coil. It could be a plugged filter if you have one in the line. Was the frig recently extra cold just before the problem? Check the resevoir first.
Eric
Jun 29, 2009 | Refrigerators
I have a Kenmore side-by-side refrigerator and the water dipenser quit working, the ice maker works fine. Any solutions?
Check water valves on back of fridge, one is for the ice maker and other is for water dispenser. Need to get the correct and complete model number listed on front and near floor behind the fresh food door. Problem may be the water valve in back or the dispenser switch on the front. let me know and I will try to get it going for you.
Thanks, Sea Breeze
Mar 20, 2009 | Kenmore 57029 Side by Side Refrigerator
The water dispencer dribbles the water out.
The water hose coil is to chill the drinking water coming out of the dispenser. If the water drips out it could be a bad solenoid valve since the water dispenser requires power to dispenser water. If the Ice maker is working fine then check the dispenser water solenoid valve.
Dec 27, 2008 | Frigidaire FRS23H5AS Side by Side...
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
check the mirco-switches behind the panel at the dispenser section. basically, when you depress the lever for water or ice, those levers make contact with a switch, and the switch turns on the ice dispenser motor. if the lever is pushed too hard, the switch can be knocked out of position. I had to re-position my ice switch with some duct tape.
Feb 16, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite Trio model#596.73503201
I believe you may be on the right track. Usually the coil for the water is behind the crispers. You can try taking the crispers out and use a hairdryer on air/no heat to speed up the coil thawing out.
Feb 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker Kenmore Side by side
You have two separate solenoids to your ice and water. One controls the water the other the ice maker. Check the ice maker solenoid and see if it is getting 110v to it and is opening. You will find it in back of the refer under the cardboard panel. Just follow the hoses.
Dec 18, 2007 | Kenmore 44109 / 44102 Side by Side...
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
