We have a 2004 Cadillac SRX and the CD player is stuck. (it has 2 cds stuck in it). How do I remove the CD player?
Remove stereo and unplug the 3 wire harness in the back, this should reset it. I had the same problem, cd was in motion to eject, but the gate (dam) wasn't moving down to allow the cd to come out.
Posted on May 25, 2009
CD stuck in my cadillac srx 2004
Remove the CD player and have it repaired, ask for the CD to come back with the repaired player.
Jan 24, 2017 | 2004 Cadillac SRX
How to remove Cadillac srx center console
Open the lid fully, you should see small hold down bolt heads, maybe 7 mm...these must come completely out, be sure to label as length etc is important. There are also 2 front connectors to the lower dash, but depending on your need to remove, you may not need to remove these...you probably need to remove the gear shift knob to raise the console...look directly under the knob...sometimes a small pull out clip to release the knob, sometimes a allen head screw to release...hope this helps.
Jan 01, 2015 | 2004 Cadillac SRX
It says cd error and my CDs are stuck, tried disconnect the battery, did not work.i have a 2006 Cadillac srx.whats the next step, please help
remove the radio take it apart and try to clear the cds ,if you can achieve this then all well and good if not fit a aftermarket radio
Nov 30, 2013 | 2006 Cadillac SRX
Two cds stuck in player
PULL IT OUT AND TAKE IT APART AND REMOVE THEM THATS THE ONLY WAY
Feb 14, 2013 | 2004 Cadillac CTS 3.2
2004 Cadillac srx key stuck in ignition and loss of power
if the battery is dead then the key will not come out hook up a another car with jumper cables then it will come out
Aug 26, 2012 | 2004 Cadillac SRX
My 2005 cadillac srx is stuck on park, how do you de-activate it
hi i have a 2004 cadillac cts that is stuck in park when the ing key is turned on the ing sencor 10 amp fuse is blown
Jan 07, 2011 | 2005 Cadillac SRX
I am receiving the following error for cd..cd mechanical error its a 2004 srx
USUALLY WHE U GET THIS MESSAGE ON YOUR DISPLAY THERES ONE OF 2 THINGS. THE MICROPROCESSOR OR ANOTHER PART THERE IN THE CD PLAYER IS DEFECTIVE OR THE CD IS DAMAGED.
Aug 01, 2010 | 2004 Cadillac SRX
CD player hs 2 cds jammed in it
best way is to remove cd player and unscrew cover and take out cd,s,i had to do this,the other way is to get pair of tweasers and try to grab hold of the cd through the slot but this also damages the cd
Feb 14, 2010 | 2009 Cadillac XLR-V
2004 cadillac srx cd player jammed
I had the same problem. disconnect the battery cables. then reconnect them. this will reset the cd player and it should relaese all your cd player problems.
this happened twice to me and the above worked fine both times.
Jun 11, 2009 | 2004 Cadillac SRX
164 people viewed this question
 Grubhead
Grubhead
