My champion shredder wq120d does not work.The machine was working fine, but when i emptied the container and tried to shred papers the red light turns and does not work. How can the problem be fixed?
    Genius:
  • 2,120 Answers
It sounds like bin full flapper / switch isn't working Move the flapper back anfd forth to hear the switch clicking.
Also do the same thing to the front door.
Posted on Oct 12, 2008
How to restore shredding capacity?
Access the mechanism and spend some time picking out all the bits of paper jammed in it.
Aug 22, 2016 | Office Equipment & Supplies
I emptied the shredder and now the red overheat/door open light comes on when I turn it on. will not allow me to shred anything. please help!
There is an interlock that prevents your shredder from operating without the bin in place. Something may be stuck inside, preventing the bin from closing the interlock. There also could be a shred of paper preventing operation.
Feb 17, 2015 | Compucessory CCS60076 - High Security...
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
My handyman took apart my Champion WQ120D paper shredder to remove the checkbook that was jammed. But it looked to him as if some transisters were burned. Once together again, minus a plastic shim at the...
It sounds like the shredder overloaded when you tried to shred the checkbook. If there is a smell of burned electronics this probably means that the shreader is dead. The plastic shims have nothing to do with the turning on and off of the shredder. Next time buy a shredder that is rated for at least 7-8 sheets, indicating a more powerful motor and sturdier blades. If the current shredder was repairable, it would be cost prohibitive over buying a replacement. Sorry for the bad news.
Sep 09, 2011 | Office Equipment & Supplies
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Paper shredder jammed - won't turn on anymore. Not sure how to clear jam. Champion WQ120D shredder.
there should be access to manually move the rollers may be with an allen wrench
Apr 21, 2010 | Office Equipment & Supplies
Just does not shrep the paper and smell like it is burning
Buy a commercial model the next time. It will cost you a few hundred, but worth it. Fellowes is a good brand with great support.
Jun 19, 2009 | Office Equipment & Supplies
Champion shredder WQ120D will not shut down after shredding but continues to run . must move to center position to shut down
If you look at the blades, some are likely bent (probably the middle ones) causing the machine to not drop the clippings which makes it think that there's paper to be shredded. It's a common problem with this shredder and there's no fixing it because the company doesn't offer replacement parts. The shredder is an overpriced piece of junk. I bought mine at Walmart but our local store doesn't even carry them anymore because of all of the returns they've had.
Jan 20, 2009 | Office Equipment & Supplies
285 people viewed this question
k24674
jasbo
jasbo
