Lexmark 20 color cartridge - red fails to print.
  • 26 Answers
Clean the hole port and try it again.
Posted on Oct 12, 2008
What type of ink cartriges are used in the lexmark 5400 model
hello there
here is the lexmark ink cartridges #31 for color and #32 for black 18c0031us_sm.jpg #31 Photo Color Print Cartridge (18C0031) $ 34.99 QTY 18c0032us_sm.jpg #32 Black Print Cartridge (18C0032) $ 24.99 QTY 18c0533_sm.jpg Twin Pack #32 Black Print Cartridge (18C0533) $ 47.99 QTY 18c0033us_sm.jpg #33 Color Print Cartridge (18C0033) $ 26.99 QTY 18c0534_sm.jpg Twin Pack #33 Color Print Cartridge (18C0534)
Sep 29, 2009 | Lexmark X5470 All-In-One InkJet Printer
Can print the color I want. Only prints red.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Aug 24, 2009 | Lexmark X2350 All-In-One InkJet Printer
Color Cartridge Has Stopped Working...Lexmark Z45 Printer
i think this a firmware issue of the printer..
try to flash a new compatible firmware .
May 12, 2009 | Lexmark Color Z45 InkJet
Document color differs from screen color- lexmark z617
Sounds like the print head is clogged. Some models have the head in the cartridge, others don't. Those that do, a cartridge replacement will help, others need cleaning manually. Also, a software head cleaning may be all it needs.
Jan 01, 2009 | Lexmark Z617 InkJet Photo Printer
My lexmark X1185 all in one printer will not print color.
did you make sure that you pulled all of the tape off the bottom of the cartridge. next recheck your settings. they will not return to normal themselfs
Jun 09, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X83 printer has streaks printing color pictures (but text is fine)
This is the problem with the cartridge if you brought original Lexmark cartridge you can get it exchanged as the cartridge is nay be defective and the cartridge comes with one year warranty...........................................
Jun 02, 2008 | Lexmark X83 All-In-One InkJet Printer
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
No color printing with lexmark x4270
How may times did you use the printer to print befor this happened? If you used it a lot then you may need to buy more ink. My printer showed full ink and it turned out that they were empty.
Feb 26, 2007 | Lexmark X4270 All-In-One InkJet Printer
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
