Question about Whirlpool Dryers
Dryer problem this dryer works fine for the first 5 minutes or so. the ignitor heats up, the gas fires up and everything seems ok. After about 5 minutes, the gas inexplicably shuts off and will not turn on again. you have to shut the dryer off, wait about 5 minutes, and then turn it on again. it then repeats this process. I replaced the gas dryer sensor, but that hasn't seemed to solve the problem. I'm wondering what else it could be.
  • johnathene Oct 15, 2008
    OK I found the gas valves on the schematic, and it looks like I can buy them seperately from the rest of the gas valve. Since I am an engineer, I have to ask... what do these coils do, and what is their failure mode? Why do they seem to work for 5 minutes and then shut off. That failure mode seemed more like a feedback loop problem (hence I replaced the sensor) than a source problem. Just curious. Thanks for the help.
    John
  • johnathene Nov 18, 2008
    Replacing the coil valves didn't seem to solve the problem. There were two coil valves on the gas valve. To replace them all I had to do was remove a retainer clip and swap them out. Each sat around a steel post, and neither had any physical interface with the gas flow (I didn't have to turn off the gas to swap them out). Did I replace the wrong thing, or is there still something else wrong?
    John
  • 943 Answers
HI thanks for your question. the problem is with the 2 coils on the gas valve. replace the coils. thanks
Posted on Oct 13, 2008
  • john gagnon
    john gagnon Oct 15, 2008
    HI the coils keep the gas flow. going , one gets worn it gets hot breaks the coils continuity. and wont open up, to let the gas in.
Kitchenaid gas dryer won't ignite and heat. Everything else seems to work fine -- drum rotates, timer works, just no heat. Model# KGYL517BWH1.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 10, 2011 | KitchenAid Dryers
Heating element glows but it will not fire- kenmore elite HE3. cleaned out vents and all seems to have good flow, everything else works, nor error code. help please
heatman101';
Aug 14, 2011 | Dryers
Whirlpool Gas Accudry dryer has no heat...everything else seems fine.?
heatman101[
Aug 11, 2011 | Dryers
My ROPER RGL4636BW2, isn't heating anymore. Everything else seems to work fine.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 17, 2011 | Roper Dryers
Just hooked up my gas dryer. worked great thru 5 loads and then quit heating,help!
What did you do move it from one place to another place? You may have shifted the lint around and cause a limit to get tripped.
Here is the manual and more
A gas dryer has a burner assembly consisting of an ignitor, 2 coils, and a flame sensor. The ignitor does 2 functions. It lights the fire and confirms the fire is on like a thermocouple. When it is heated it holds in the coil. If the glowbar is not lit then the coils will not open. The ignitor must be heated to allow that. So if the ignitor and flame sensor is fine and the dryer works when cool but stops heating when hot I would say you need to replace the solenoids.
Nov 17, 2010 | Frigidaire GLGR331A Gas Dryer
Roper RGX5634KQ2 Dryer will fire initially, and heat up. It will stay fired up for around 1-2 minutes, and go out. After another couple minutes, the igniter fires, but there is no flame. This continues...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Could be a coil...but I have learned that it usually is the ignitor...
heatman101
Sep 02, 2010 | Roper RGX4634KQ Gas Dryer
Dryer is spinning but the burner wont fire up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 07, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Running but not firing & heating
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gdryertroublevideo.html that will walk you thru this.
Jun 03, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Gas......starts to heat then quits minutes later.
Problem is your gas solenoid coils. When they get worn they will open til they get out then shut. They will need to be replaced.
Part number 279834 replaces for most models.
May 15, 2009 | Kenmore 62602 Electric Dryer
Dryer heat shuts off after a few minutes.
replace the 2 black solenoids on the gas valve ..after heat up they sometimes will go bad and burner will not reignite even though the ignitor glows
Sep 23, 2008 | Dryers
Dryers Logo
102 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
