Question about Bose LifeStyle 5 Series-III CD Shelf System
No sound Do you have sound from the headphone outlet? YES If yes, then it could be a known problem on the model 5 where it will not switch on the sub.. I have a fix for this, just let me know. WOULD APPRECIATE HEARING FROM YOU REGARDING THE FIX. THANKS
  • wallkill38 Oct 15, 2008
    Hi the problem is R428 open circuit, replace with 330 ohm resistor
    Dave
    Dave,
    Thanks for the prompt reply. Just to clarify, the problem would be with the model 5 music center and not with the subwoofer. Correct?
  • Kiwi jeff Nov 09, 2008
    I believe I have a similar issue. I never saw whether replacing R428 resolved the issue. Can someone please comment.
    If this did resolve the issue can someone please direct me to R428 on the appropriate board. I took a look but couldn't track it down.
    Thanks, Jeff
  • 12 Answers
Dave
Posted on Oct 14, 2008
2000 lmpala dashlight not working so as climated control and gear shifter it's not the fuse can not find it can you help pls.
Instrument Panel Lamps Inoperative
Step
Action
Yes
No
Did you perform the Lighting System Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Lighting Systems in Lighting Systems.
Turn the ignition to the ON position.
Turn the headlamp switch to the ON position.
Turn the I/P dimmer switch to a low position.
Are the I/P lamps on?
YES - Go to Testing for Intermittent Conditions and Poor Connections
NO - Go to Step 3
Disconnect the headlamp switch.
Using a test lamp connected to a known good ground, probe the park lamp switch ON circuit at the headlamp switch.
Does the test lamp illuminate?
YES - Go to Step 5
NO - Go to Step 4
Repair a poor connection or an open in the park lamp switch ON circuit.
YES - Did you complete the repair?
NO - Go to Step 10
5
Using a test lamp, probe the headlamp switch between the park lamp ON circuit and the I/P dimmer switch control circuit.
YES - Go to Step 6
NO - Go to Step 7
6
Replace the headlamp switch.
Refer to Headlamp Switch Replacement .
YES - Go to Step 10
7
Inspect the I/P dimmer switch control circuit for a poor connection, or an open.
Is the circuit OK?
YES - Go to Step 9
NO - Go to Step 8
8
Repair a poor connection, short to ground or an open in the I/P dimmer switch control circuit.
YES - Go to Step 10
9
Replace the LH I/P accessory wiring junction block.
YES - Go to Step 10
10
Operate the system in order to verify the repair.
Did you correct the condition?
YES -- Go to Diagnostic System Check - Lighting Systems
NO Go to Step 2
Dec 27, 2016 | 2000 Chevrolet Impala
No power sennheiser rs120
Probably a defective item, Try for a return.
Oct 13, 2014 | Sennheiser RS 120 Consumer Headphones
How do i connect to a bluetooth headset?
1. On the phone's main standby screen, tap the area next to the battery life indicator in the top right corner, then select the two horizontal arrows. You should now see the Connectivity menu.
2. Select "Bluetooth".
3. Make sure the section marked "Bluetooth" is set to "On".
4. Select the Paired Devices tab at the top of the screen (it looks like two "B" logos with wavy lines between them).
5. Select "Options".
6. Select "New Paired Device".
7. Switch on your Bluetooth headset or headphones, and make sure they're in pairing mode. If you're unsure how to do this, consult the manual that came with the headset/headphones.
8. Select "More Devices".
9. If your headphones appear on the list, select it. If they aren't found, try moving the headphones nearer to the phone and select the "Try Again" option.
10. The 5800 should now complete the pairing process with the headphones. (If it asks for a numerical code, you should find it in the headphones' manual.)
11. The 5800 will ask if it's okay for the headphones to connect to your phone automatically in the future. We strongly recommend saying yes because it saves a lot of bother.
12. Select "Yes" again to connect to the headphones immediately.
Nov 19, 2011 | Nokia E72 Smartphone
I want to output audio from tv to stereo
would be better from the cable box to stereo, check for two sound outlets on the back of the flat pannel, one should be the RCA outlets, the other one should be the headphone type outlet, if the headphone type is the only one, go to Radio Shack and buy a converter from headphone jacks to RCA, I hope that works, if your stereo has the 5 color cable component, do it that way, component out to component in, God bless
Jan 26, 2011 | Televison & Video
The rear heater does not heat up when switch is on
Troubleshooting by Symptom Poor Heater System Performance
  1. Start the engine. Allow the engine to idle. Does the engine reach normal operating temperature? If yes, go to the next step. If no, go to step 8.
  2. Allow the engine to idle. Select the FLOOR mode. Select the minimum blower speed and the warmest temperature setting. Feel the temperature of the inlet and outlet heater hoses at the heater core. Does the inlet heater hose feel warmer than the outlet heater hose? If yes, go to step 6. If no, go to the next step.
  3. Install a thermometer into the center I/P PANEL air outlet. Secure a thermometer to the heater core outlet heater hose. Select the PANEL mode. Select the maximum blower speed. Select the warmest temperature setting. Record the temperature at the center I/P PANEL air outlet and at the heater core outlet heater hose. Are the two temperature readings about equal? If yes, go to the next step. If no, go to step 5.
  4. Inspect and repair the cowl, recirc door, and the HVAC module case for cold air leaks. If problems are found and repaired, go to step 9.
  5. Inspect the temperature door operation. Perform any necessary repairs. When repairs are made, go to step 9.
  6. Turn OFF the engine. Backflush the heater core. Start the engine. Select the FLOOR mode and the lowest blower speed. Select the warmest temperature setting. Feel the temperature of the inlet and outlet heater hoses at the heater core. Does the inlet heater hose feel warmer than the outlet heater hose? If yes, go to the next step. If no, go to step 9.
  7. Replace the heater core. When the repair is complete, go to step 9.
  8. Repair the low engine temperature concern. When the repair is complete, go to step 9.
  9. Operate the system in order to verify the repair. If the system operates properly, the repair is complete. If the heater still does not work properly, repeat the entire procedure.
Insufficient Defrosting
  1. Start the engine, select the DEFROST mode, and select the maximum blower speed. Does sufficient air flow from the defroster outlets? If yes, go to the next step. If there is insufficient airflow, go to step 9.
  2. Measure the engine operating temperature. Does the engine reach normal operating temperature? If yes, go to the next step. If the engine does not reach normal operating temperature, go to step 7.
  3. Select the minimum blower speed. Select the warmest temperature setting. Feel the temperature of the inlet and outlet heater hoses at the heater core. Does the inlet heater hose feel warmer than the outlet heater hose? If yes, go to step 10. If the hose temperature is not right, go to the next step.
  4. Test the operation of the A/C compressor clutch. Does the A/C compressor clutch engage? If yes, go to the next step. If the compressor clutch does not engage, go to step 6.
  5. Repair or replace the A/C compressor clutch. When the repair is complete, go to step 13.
  6. Repair the A/C compressor clutch concern and determine if the A/C system is operating within specifications. If yes, go to step 8. If no, go to step 11.
  7. Repair the low engine temperature concern. When the repair is complete, go to step 13.
  8. Inspect for correct operation of the recirculation door. If the door is operating correctly, go to step 13. If the door is not operating properly, go to step 12.
  9. Repair the air delivery concern. When the repair is complete, go to step 13.
  10. Repair the heating concern. When the repair is complete, go to step 13.
  11. Repair the A/C performance concern. When the repair is complete, go to step 13.
  12. Repair the recirculation door concern. When the repair is complete, go to step 13.
  13. Operate the system in order to verify the repair. If the system is operating properly, the procedure is complete. If the system is still not providing proper defrosting, repeat the entire test
. Noise from the HVAC Module
  1. Start the engine. Cycle through all blower speeds, A/C mode settings and temperature control settings. Determine the type of noise, whether it is a scraping, popping, ticking, clicking, chirping or groaning, or an air rush or whistle. Is a scrape or pop noise evident when selecting modes or temperature settings? If yes, go to step 5. If no, go to the next step.
  2. Is a tick/click, chirping, groaning or scraping noise present, but decreases as blower motor speed is decreased? If yes, go to step 5. If no, go to the next step.
  3. Is an air rush/whistle noise evident in all modes but not all temperature settings? If yes, go to step 5. If no, go to the next step.
  4. Is an air rush/whistle noise evident only in defrost or floor mode? If yes, go to step 5. If no, examine for other sounds, repeat step 1.
  5. Remove the I/P trim pad. When complete, go to the next step.
  6. Inspect the airflow doors for proper operation and the ducts for obstructions or foreign materials. Were any of these conditions found? If yes, go to step 9. If no, go to the next step.
  7. Inspect the mode and temperature doors and seals for warping or cracking. Are the doors in normal condition? If yes, go to step 9. If no, go to the next step.
  8. Replace the appropriate door and/or seals. When the repair is complete, go to step 10.
  9. Remove any obstructions or foreign material found. When the repair is complete, go to step 10.
  10. Install the I/P trim pad. When complete, go to the next step.
  11. Operate the system to verify the repair. If system operates without noise, the repair is complete. If noise still exists, repeat the entire procedure.
Jul 21, 2010 | 1999 Chevrolet Astro
Audiovox Infrared Headphones
My set has an led that glows red when on...if batteries in correctly, and switch on...do you have a red "POWER" indicator. If yes, & still no sound, 1-does the other set work? 2- either side of prob set work? 3-VOLUME up all the way? Could be bad receiver/bad speaker(s) bad vol switch.
IF no POWER led on, then 1-bad batteries 2-bad power switch 3-broken internal power lead/wire.
Kids are rough on these things...any sign was dropped, or dunked in a coke? REMOVE ear cushions are screws if yur inclined.... sk
Apr 08, 2008 | Audiovox (JHHO-110) Headphones
No sound
Do you have sound from the headphone outlet? If yes, then it could be a known problem on the model 5 where it will not switch on the sub.. I have a fix for this, just let me know.
Apr 02, 2008 | Bose LifeStyle 5 Series-III CD Shelf...
JVC LCD Lost Sound
Yes it is repairable
Do you get good audio from the headphone jack?
If yes, then it is the Audio Amp or some component in the Audio Circuit
If NO, then then Audio Switching IC is defective.
Expeens will depend on the person fixing it. expect $70-100 parts. I think labor is normally $80-120. so $150-220 total.
You can get a new 26" for that though. If the headphone works then the Audio Out of the TV will work. I suggest a miini system for audio out.
Mar 10, 2008 | JVC LT-26X506 26 in. LCD Television
Durabrand television model Dwt 2405
Dear friend, Try connecting a pair of Headphones to the Headphone socket in the front of the TV. Do you get sound in both headphones? If yes, then it means that the Right speaker has become faulty. No sound in Right Headphone? Then the Audio Amplifier IC has to be replaced.
Jun 19, 2007 | Durabrand DWT2405 24" TV
Bose LifeStyle 5 Series-III CD Shelf System Logo
193 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
