Question about Proview PL926WBi 19" LCD Monitor
I NEED HELP PLEASE!!!!!!! PROVIEW 19" MONITER.
Ok so i bought a 19" proview PL926Wbi moniter and it worked great up until 3 days ago when i would turn on my computer and the display on the moniter would say: no signal. so i checked ALL of the wires and re-plugged them in and it still happened. then i tried out different VGA cords and it still didnt work.. after that, i made sure that it wasnt the computer ports that where shot by trying to hook up a different moniter so i did and the display came on fine.... CAN SOMEONE PLEASE HELP ME?? i need some solutions......
  • brandon waltz
    brandon waltz Oct 12, 2008
    ok well the screen lights up fine and the box that comes up that says no signal is blue with the top bar being violet and ill try the paper clip thing.... the video card in my computer is fine but is there a possobillity of getting a new video card for the MONITER? oh and the advice is great and i really apreciated.
  • brandon waltz
    brandon waltz Oct 13, 2008
    ok so can you email me your contact info so i can send you the moniter at some point?(if thats ok) and once again i REALLY apreciate the info and i just NEED this moniter to be fixed cuz i really dont have the extra $ to buy a new one rite now.
    by the way, my email is dmuffins458@gmail.com
    Novelist:
  • 159 Answers
Does the led on front of the monitor stay blue or does it become amber ?
If it becomes amber, then you are not getting a signal.
No harm in trying this : You can try to see if it is a contact problem.
With the monitor unplugged.
Use a small paper clip to run in and out of the blue vga plug holes a few times each to make sure they are not plugged or gummed up.
If that doesn't help and you know that your video cord is good, then I am afraid to say that more than likely there is a problem with yor video card.
If it stays blue then the signal is there but the screen isn't fully lighting up, leading to a failing power-inverter board or a bad bulb.
powerseller
bammbammfran
Posted on Oct 12, 2008
  • Fran Bednar
    Fran Bednar Oct 13, 2008
    The 926 no signal box is usually light blue with dark blue top. But violet is close ?
    There is a video board in the monitor itself that deciphers the input
    signal to a resolution that you monitors screen will recognize. For
    instance widescreen versus regular screen.
    Cards are not readily available. I just sold my last widescreen one yesterday. I have regular ones but they wont work right.
    Not sure what new ones cost, but you can drop an email to proview to ask.
    parts@proview.net
    I usually do not repair video cards because usually the problem is in
    the main chip, but if the new ones are pricy for the guess that it is
    the problem for sure, I will be willing to check it for you first. Just
    costs you postage.
    Ebays bammbammfran
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
Does my Proview PL926WBi 19
Any monitor will work with any computer provided the correct graphics card driver is installed. When you install Vista and you do not install the graphics driver, Windows will default to Generic VGA driver and you will not get the best resolution that the monitor can display.
Jan 29, 2010 | Proview PL926WBi 19" LCD Monitor
Pl926wbi 19"proview monitor,screen goes black every 3 seconds,
Bad capacitors on the pcb boards internally unsoldering ad replacement is indicated.
Feb 17, 2009 | Proview PL926WBi 19" LCD Monitor
Moniter clicking
check capacitors inside for damage is found replace them
Feb 13, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Pl916s proview 19 inch flat screen moniter
I managed to solve the same problem by replacing the six 470uf 25v capacitors. I have notice that the old ones has a bulging top.
Feb 07, 2009 | Proview PL916S2 Monitor
19inc moniter power on then goes off within 1 sec
bad capacitors in the power circuit for the inverter power supply, replace these and everything should be alright it requires soldering skills or I can do it for a fee. It can also be transistors but much more likely it is capacitors.
Jan 12, 2009 | Proview PL926WBi 19" LCD Monitor
ProView PL926WBi
bad capacitors on the board, replace these and the inverters should get there power.
Dec 01, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926Wbi
unsoldering is the only way to UN-mount capacitors the board needs to be out of the casing. a solder iron and some electronic solder wire can be bought at radio shack or any other electronics store.
procedures are all over the internet
Sep 30, 2008 | Proview PL926WBi 19" LCD Monitor
Proview Monitor pic quality diminishing
It sound to me as if the focus on the moniter has changed. If so a couple of possible tihngs might be going on. You could have a dust build up due to the static charge difference the dust and the high voltage potential with in the moniter. If so you can open it up and clean it with an air sorce or vacumn. You might also try adusting the focus adjustment on the back of the moniter. The worst case is that some componet is becoming weak and will fail in the future. Good luck
budman630
May 14, 2008 | Gateway FPD2275W LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
237 people viewed this question
Top Proview Computers & Internet Experts
Diego Zenizo
Diego Zenizo
Level 1 Expert
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
