Question about Futuro Kitchen Ranges
Futuro Island Vent Hood
I have a situation that recently has started with my Futuro Island Vent Hood. In the past a blue light would be on the display (4 buttons) when the hood was on. Recently the blue light for the hood is now on when the hood is off. Is there a way to reset this.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 171 Answers
Hi snuds1369,
I'm Harvey the Master Plumber.
Your question is: You have a situation that recently has started with your Futuro Island Vent Hood. In the past a blue light would be on the display (4 buttons) when the hood was on. Recently the blue light for the hood is now on when the hood is off. Is there a way to reset this?
Yes. Turn off at the breaker for 30 min. If this doesn't work it's an indication the control chip has a problem.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 14, 2008
  • Anonymous Nov 09, 2015
    Resetting the unit worked perfectly - thanks!
2004 palm harbor double wide no power to light over island sink and no power to vent hood
both should be 12 volt lights possible bad fuse or bad wire or loose ground
Jul 25, 2017 | RVs
Boston tile range hood light switch
Remove the switch and take it to any appliance spares wholesaler. You will find them in Yellow pages.
Jul 19, 2016 | Futuro Futuro 36-inch Boston Tile Wall...
Ge zv850 vent hood
was this a d.i.y. project, if so was a proper ground ran from breaker usually a size bigger than the power. when the fan goes out does the light do the same, as u may have crossed your device wires. electrical can be tricky because there can be several reasons for your issue. u suggest u double check your work ensuring everything is
Feb 17, 2014 | Kitchen Ranges
Exhaust fan and lights do not work
see this steps and fix it. God bless you
Switch If the range vent hood fan and light are not working the switch might be defective. Watch our video on switch testing and test this switch for continuity.
Selector Switch If the range vent hood fan and light are not working the selector switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rotary Switch If the range vent hood fan and light are not working the rotary switch might be defective. Watch our video on switch testing and test this switch for continuity.
Rocker Switch If the range vent hood fan and light are not working the rocker switch might be defective. Watch our video on switch testing and test this switch for continuity.
Switch Kit If the range vent hood fan and light are not working the switch kit might be defective. Watch our video on switch testing and test this switch for continuity.
Micro Switch If the range vent hood fan and light are not working the micro switch might not have continuity. The best way to test the switch is with an Ohm meter. See our switch testing videos for help testing this micro switch.
Thermal Fuse If the range vent hood fan and light are not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Main Control Board If the range vent hood fan and light are not working the main control board may be defective.
User Control and Display Board If the range vent hood fan and light are not working the user control and display board may be defective. Check other causes before ordering this board.
Oct 02, 2012 | Dacor Millennia DHI602 Kitchen Hood
How to change the light
There are three different models... two wall models (the WL24 and the WL36) and an island model (the IS24). The instructions for changing the lights on all three models are the same.
Light bulb:
  • Make sure your hood is disconnected from the main power supply.
  • You may see a screw at the edge of the light cover. Unscrew it and remove the light cover.
  • Replace the light bulb with the same model as the original. There may be a decal near the bulb that indicates its rating. Don't exceed 25 watts! It's best to bring the old bulb to your store to have it replaced exactly.
Spotlight:
  • If you don't see a screw, then - using a screwdriver - lever the support ring, then grasp it & pull it straight down and off. This ring supports the glass cover - remove it as well (don't drop it!).
  • Replace the lamp with the same type (12V, 20W, G4 fitting).
  • Replace the glass cover and the support ring - it should snap back in.
Fluorescent light:
  • This needs to be changed by a qualified installer. Don't attempt it yourself.
Mar 02, 2011 | Futuro Altair Kitchen Hood
Can this be installed over an island?
Bring a focal point to your kitchen by having an island range hood, combining function and elegant form. A suspended hood is also an efficient way to vent
grease, odors and smoke to the outside from a island stovetop while you cook. You can install an island range hood in just a few hours with the right tools
and knowledge.
1.Wear safety glasses and work gloves. Turn off the electricity to your kitchen at the circuit panel. Cover the circuit breaker with a piece of electrical
tape to prevent people from turning the on switch while you are at work.
2.Lay work drop cloths on your cooktop and floor to catch dust and debris. Mark the duct opening with a pencil in the ceiling, where the island hood will be
installed. Be sure the opening is centered directly above your cooktop. Cut the opening using a hacksaw.
3.Go up to the roof, using a cat's claw and hammer to remove stucco, tiles, sheathing and insulation to make way for the steel venting duct. Drop a
plumb bob down the roof, making sure the line is straight down for the ductwork.
4.Follow the manufacturer's instructions for locations, installing 2-by-2 wooden blocks in the ceiling to hold the ductwork hangers.
5.Install the venting duct from the outside of the home, down to the location of the exhaust vents on the island hood. The ducts should easily slip into each
other. Secure all the duct sections with duct sealing putty, using a putty knife.
6.Screw a roof cap on the end of the duct at the roof. Seal any openings or gaps where the roof, ceiling and duct meet with silicon sealant. Let the sealant
dry, then paint with colors matched to the surrounds.
7.Place your hood upside-down on the floor, with the fan and filter facing upward. Locate and unscrew the metal electrical box cover on the island range
hood, to expose the wiring
8.Install the hood cover to the load-bearing ceiling frame with the package hardware through the four inside mounting corner flanges on the cover.
9.Measure what will be the distance from the bottom of your hood to the cooktop; it should not exceed 30 inches for exhaust efficiency. Have a helper hold
the hood in place while you attach the hood on the hood cover using the included screws. Use a level be sure the hood is level as mounted.
10.Connect the electrical wiring by consulting the manufacturer's suggestions or hire an electrician if you are not familiar with house wiring. Tuck the wires neatly in the hood electrical box and then replace the cover, after connecting the hood wires to the wall wiring.
11.Remove the electrical tape on the circuit breaker, turn on the electricity to your kitchen and test your island range hood.
May 26, 2009 | KitchenAid KHVU781RSS Stainless Steel...
Hood fan works but displays the letter "C" ?
wow! finally the solution that works! Holding the '+' sign for 4 seconds. We had our vent replaced by kitchenaid once and were about to call again and complain since our new one did just the same thing without resolution using the 'H' button as indicated in the manual! Thanks for help it's so appreciated!
Feb 22, 2009 | KitchenAid KWCU205HSS Kitchen Hood
Installing a vent hood...
There is no kit to make this conversion. That being said, you could get an estimate from a sheet metal fabrication shop on creating the conversion you are seeking.
Good luck with it.
Feb 13, 2009 | Frigidaire PLHV36W7CC Kitchen Hood
Kitchen Ranges Logo
626 people viewed this question
Top Futuro Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Futuro Kitchen Range Expert? Answer questions, earn points and help others
