Question about Bose Lifestyle 28 System
Good Video connection/No sound.
My daughter tripped over the wires. I checked for wire disconnections and found nothing. I also looked for breaks and found nothing there either.
I checked the settings and the remotes for the TV and the Bose.
What am I missing? Good Video but no sound. Bose Lifestyle 28. When I press the Speakers or Surround button on the remote nothing appears on the display except a momentary dot in the lower right corner.
    Sergeant:
    Champion:
  • 200 Answers
HI
when one or bend it too far they are no good i recommend using either the rgb cables or YPbPr.
check their is a loose connection..
thank you
Posted on Oct 12, 2008
  • Thafa Oct 12, 2008
    Hi
    try to replace the wire and then check it..
    thank you
    Sergeant:
  • 399 Answers
Remove all the connections and then reconnect them 1 by 1 in the proper sockets without messing it up.and then check it .
My compresssor keeps tripping the breaker>
Loose wire in panel box or loose wire around compressor. any loose wire causes a high amp draw which blows the breaker. I've found wires that look good but are loose. Go right to the compressor outside and check there first. pull disconnect first and make sure there is no power. you either have a shorted compressor or loose wire. if you ohm out compressor with power off and disconnect the three wires you will get something like this....one wire to other wire 2 ohms... same wire to other wire 3 ohms... other two wires you should get 5 ohms...2+3=5 good compressor.they will add up to each other.
Sep 28, 2014 | Heating & Cooling
Yamaha 2005 150 HPDI wiring diagram
Looking for wiring diagrams for digital tachometer with trim indicators and warning signals. Mine had the plastic trip arm break. No trim reading on Tach face. Replaced trip arm forsensor arm and now have no reading on the tach at all except extremely light tach Number. All other electrical components work OK.
Jan 24, 2012 | Yamaha Motorcycles
I have a goodman manufacturing 3 ton heat pump, model #CPLE36-1. initial call was no a/c. found breaker tripped. reset and hit disconnect and tripped again.. ohmed compressor and fan motor and both ohmed...
What you need to do is disconnect the compressor at the electrical access on the side of the unit. Check each wire to the grounding screw using ohm meter if you get continuity your compressor is shorted do the same thing for you condenser fan. I bet your compressor is shorted. Make sure power is off and remember where the wires go. Trace the wires that go to compressor back to the contactor and capacitor and disconnect them there. If this help please rate me and do a testimonial.
May 25, 2011 | Heating & Cooling
Furnace keeps tripping the breaker changed breaker and wires all good up to the furnace still keeps tripping when i try to turn power on. nothing happened to the furnace and the wires were tested up to the...
Disconnect the black power wire where it is connected to the furnace with breaker off. Put a wire nut on it and then turn the breaker on. If it continues to trip, the problem is not the furnace and you will have to trace the power wire back to the breaker box to find problem. Next, disconnect the black wire from the breaker (with breaker off) and then snap breaker on. If it trips, bad breaker. If the furnace was disconnected and breaker did not trip, you have a short either on the P C Board or the transformer.
Mar 31, 2011 | Heating & Cooling
Installing new light switch and then when try to turn on lights - circuit breaker trips
Hi, if its just a single pole 120volt switch, or even a double, you have installed, I am sure the way you took it out is how you put it back but, you have wired the switch to where the hot wire going in or coming out is grounded/shorted against the ground wire. A switch has just 1 hot wire going in, and the same wire coming out, the switch just breaks the voltage at the one wire. Pull it back out and look for any burned spots on the screw terminals to maybe a bare ground wire. It has to be touching at some point to short and trip the breaker. Should be very easy for you to spot. Nothing major, happens sometimes. Please rate me on my help to you. You will find it as soon as you take it out, just look close at the wire where it is touching and you have solved it!
Sincerely,
Shastalaker7
Jan 23, 2011 | Heating & Cooling
Heater works fine but when you turn on Air Conditioner on it shuts off replaced the relay switch but still not working
MOST LIKELY NEEDS NEW BOARD , THERMOSTAT , TRANSFORMER , MAYBE FUSE ON THE BOARD AND
CHECK FOR WIRE BREAKS AND PROPERLY CONNECTED WIRES
AND IF IT STOPS THAT SUDDENLY THE COMPRESSSOR MAY
BE BAD SO CHECK FOR A GROUND OR TRIPPED BREAKER, AND
BURNT WIRES..CHECK FOR SIMPLEST 1ST. NARROW IT DOWN
AND MAKE SURE OUTSIDE UNIT IS RECEIVING POWER AND
CHECK CAPACITOR. LOOK AND CHECK FOR DISCONNECTED WIRES INSIDE AND OUT.
Apr 07, 2010 | Goodman CKL36AR36 Air Conditioner
How can I disconnect my car without disconnecting the battery? Don't want my daughter taking the car when I have not approved.
Don't have an exact location on yours but they are usually found under the hood in a group of relays. Also, if you have a starter solenoid on the fender, you can remove the ignition trigger wire (battery (+) cable runs to it and exits to the starter...should be a single small wire next to battery connection there. just remove it.
Jun 19, 2009 | 1996 Ford Explorer
Break light will not work
It's blowing the fuse because there is a short somewhere in the circuit. Your inspection just hasn't found it yet. Look for bare spots on the wiring; places where the wire might be pressed against metal (especially sharp edges); damaged connectors; etc.
Apr 21, 2009 | 1990 Nissan Sentra
When i turn my a/c (goodman) to auto and to cool, nothing is working.and when you go outside by condenser unit and manually push the relay in it trips the circuit breaker. is there any short somewhere or...
first stop pushing the contactor in if it tripped the breaker than you have a short and it need to be checked out the small wires are the t-stat wires could have shorted the control tranformer have the system looked at by your hvac people dan
Jul 17, 2008 | Goodman Heating & Cooling
Bose Lifestyle 28 System Logo
135 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
