Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer, elite 70 series is leaking water on floor
Model # 110-26732501. Washed a load of sheets yesterday and washer had completed cycle but water on floor. It is leaking from the front. My husband checked all hoses and no blockage. no cracks in tub. No loud noises, he thinks I overloaded it but if I had wouldn't it have been off balance and made noise? So, we do not know what to do. My husband could do by himself with some direction. Which we would rather do than call a serviceman, unless its too complicated. Please any help is good...Thank you very much.
  • 550 Answers
The hose from the drum to the pump, and from the pump to the drain, are at the front,
Movement of the drum during wash cycles, wears the short hose between drum and pump and it develops cracks, eventually a wash load of any size will finally cause one of the cracks to penetrate through the rubber, and constant drip occurs.
Its an easy fix, no more than screwdrivers needed.
the local parts guy will have the hose, even if it is labelled ge frididaire whirlpool the same hose is common to many makes and models
  • turn off water unplug washer
  • pop the endcaps off the control panel, and completely remove the phillips head screw under each endcap kenmore washer, elite 70 series is leaking water o - dec762a.jpg
  • lilft the control panel ~1inch and flip it over the back of the washer,
    (do not dislodge the water level sensing hose or we'll be back to fix it later, hinges are plastic, dont bust em)
  • remove the two brass clips under the control panel
    (note position for reinstall)
  • remove lid switch connector
  • lift entire body up ~1 inch and remove forward
  • motor pump hoses gearbox are now exposed.
examine hose from drum to pump, and from pump to cabinet rear,
replace cracked and crazed hoses.
reassemble in reverse order
Posted on Oct 13, 2008
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
Dec 28, 2015 | Kenmore series 70 80 90 Washer timer...
Water leaks under washing machine
SOUNDS LIKE YOU MIGHT HAVE A WORN OUT DRAIN PUMP, YOU WILL HAVE TO OPEN IT TO DO A VISUAL CHECK ON IT,
Feb 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
It's an Elite not sure the model number but I have a leak from underneath after the clothes are washed and when the water is discharged before the spin cycle.
this could be a broken hose or a leak from the water pump , if you have an access panel in the back u can check this , or access from underneath
Sep 26, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 70 series slow agitator
You have burned the clutch this must be replaced
Jun 09, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore HE3 Front Load Washer - Leaking Water into wash tub
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Washer 70 Series - sheets stuck around agitator
The transmission probably stripped the worm gear that drives the drum - you would have to crack it open and take a peek.
Nov 24, 2008 | Kenmore 15864/15862 Top Load Washer
Leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Kenmore 70 Series Top Loan - Fill Cycle won't stop when full
Does the water stop when you push the timer in or are you having to shut the spigots off?? If it stops when the timer is pushed in then you have a problem with the pressure switch. There are quite a few tricks to axcessing your machine's components but if you are handy ill attemt to help.
Jan 12, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
3,669 people viewed this question
Sal De
fordexpert
Robert Rankin
