Question about Panasonic Home Theater System System
Volume Control on my SCBT100 Blu-ray Home Theatre doesn't work.
When you touch the volume control, the volume increases all the way from the minimum (0) to the maximum (50). If you touch the down volume, the volume decreases to 0. Nothing I do permits me to stop the increase or decrease at any level except 0 or 50.
  • 4 more comments
  • pararescue Nov 09, 2008
    I have the same issue. Any fixes yet?
  • walkerSIT Dec 05, 2008
    Same problem here
  • brentirish Dec 19, 2008
    I'm having the same problem. Has anyone found a fix yet?
  • fuckto Dec 21, 2008
    goes auto up or down
  • actnoble Jan 06, 2009
    yea I have the same problem. Sa-Bt100. When I press the volume up or down it will go automatically all the way up or down.
  • DarkKnightBR Mar 11, 2009
    I have the same contition but was able to get around it by unplugging the machine for an hour. I had the "Dark Knight" Blue-Ray disk in my machine while watching a local over the air HD digital tv station on a Panasonic 50' HD 1080 plasma. I don't know what the connection is yet, but it has not occurred again since I haven't had the "Dark Knight" in the player.
Unplug the power and let it sit. Plug it back in and it should fix. Worked for me.
Posted on Mar 22, 2009
I have a phillips hts5560 home theatre system and im getting no sound through the speakers! I have tried everything the blue ray player workz but no sound at all through speakers can anyone help?
Hi Candice, Does your blue-ray DVD player have volume control as well as your television, I have blue-ray DVD with volume control as well as the television volume control.... I have the television volume turned up full and control the volume through my blue-ray DVD.... Hope this helps... CHEERS...
Apr 16, 2016 | home Audio Players & Recorders
My remote is bad and need to increase the volume manually on Samsung ht-txq120 home theatre system
If your remote won't work at all, then you'll need to get a new remote from Samsung to control all functions. If however, everything works on the remote but the volume, keep the original for all other functions and just use a cheap universal remote programmed to the Samsung code to control the volume. I had the same thing happen on a Sony THIB remote for a HT. I used a Scientific Atlanta to turn it on and off, as well as control the volume, but retained the original remote so I could get at all other functions. If you have to buy a new Samsung remote or if you buy one of those high-dollar universal remotes that program a zillion functions it will cost you big. Fair warning.
Mar 17, 2016 | Samsung HT-TXQ120 Home Theater System...
I can not get my RCA Blu Ray home theater to play what comes through on regular tv. It plays a dvd and will also play when using netflix from my ps3. I do not have any sort of cable box. My tv is a Sa
Gotta find an audio output from the TV and run it to aux input on the home theatre, select the aux function and it should work, if your tv has no audio out see if it has a headphone jack you can use as an audio out, can get a cable with 3.5mm headphone jack one 1 end and rCA red/white on the other, becareful when doin this as the audio output level froma headphone jack maybe controlled by the tV's volume itself. keep tV volume low and use the home theatre volume if your doing it that way
Nov 24, 2013 | RCA Blu-ray Home Theater With Vudu,...
I have an old JCX TS750 Home theatre system.Is it possible to put the tv sound into the speakers. many thanks ...
Yes. Connect the audio from the cable box to the home theatre. Just change your function when u are watching tv to video 2 or where ever u plugged it in. Then turn your tv volume down and use volume on this sanyo
Jan 06, 2011 | Sanyo Televison & Video
Sound is weak how to increase volume
Please check your all the audio and video connections. Also put the placing of AV Enhancer (button on remote control) in the ON position You can increase the volume by increasing the volume of the TV.
Dec 27, 2010 | Panasonic DVD-S27 DVD Player
I have a Philips Home Theatre System, model HTS7200 which showed 'unknown disc' when I put discs inside.
hi I have a Philips dvd touch screen HTS7200 the lights on top for volume and play are not working ,the try is not opening ,there s no sound coming out thanks
Dec 17, 2010 | Philips DVDR3380/05 DVD Recorder
LG LHB953 Theatre system volume control with comcast dvr 3
Try the help menu in the comcast remote. I believe you have to program it again for the LG to work the sound.
Jan 01, 2010 | Televison & Video
Is my tv audio doomed or will the home theatre system work anyways.
some devices these days have a built in volume control, try using your remote for which ever dvd player or satalite bix you use, on push the volume up button on it while you have the volume on the tv maxed out so that you will be able to tell a defference if it works or not.
Jun 02, 2009 | Philips HTS 6600/12 Home Theatre...
I have a coby dvd player which is connected to my home theatre sound system. However, i canot increase the volume to a satisfatory level past #20. the theatre sound system is at max volume.
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, there is no way to increase the output of the Coby dvd player within the player itself. It may be that the player isn't outputting very well through the audio coaxial output which i presume your using. If this is the case, there is no fix for that type of issue. You would want to replace the player.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Jan 16, 2009 | Coby DVD-224 DVD Player
Light-up volume bars on the hp pc notebook dv7 1132nr
Hi Folks....
If you are talking about the Quick Launch buttons of the Notebooks from where we usually increase, decrease or mute the Volume, the lights will be still and will not increase or decrease with the increase or decrease in Volume.
However, you do have a utility which should be preinstalled in Notebooks called HP Quick Touch which shows the bars on the Display when the volume is Increased or Decreased  using the Quick Launch buttons. This application is not compatible with Windows Vista 64 bit edition.
The HP Quick Touch application is available for download from the link below :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38358.exe
Save the file in the Notebook and double click it once the download is completed to install the application.
Hope this helps....
Dec 20, 2008 | HP Pavilion dv4000 Notebook
Panasonic Home Theater System System Logo
383 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
