Question about Kodak EASYSHARE 5100 All-In-One Printer
Prints people purple
How can I get my printer to print normal???????????????????
I have had this piece of junk for about six months have taked it back to the store once, and can not get it to do what it is supposed to do
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 41 Answers
The Kodak printhead is known to dry out. You can call kodak customer service and complain your printhead is failling explain you have run the printhead cleaning many times waisting your ink. They should ship you a new printhead and free inktanks.
or if you dont want to wait on the phone....
I have found lysol hand wipes to work wonders on the kodak printhead. I have an ESP 5 and I have wiped the printhead with a lysol hand wipe many times and it works like new. Here is a link to the product.
http://lysol.com/products/disinfecting-wipes/dwipes-4-in-1/
To wipe the printhead follow these instuctions.
remove the printhead from the printer. put the tanks back into the printhead. Be very carefull not to drop the printhead and do not put the printhead on a table with the nozzle plate down (where the ink comes out). take the hand wipe fold it a couple times. Gently wipe the printhead nozzel plate in the direction of the lines on the nozzle plate do not do a circular motion or wipe against the grain. you may not even have to use a wiping motion. you can just place the wipe on the nozzles and let the printhead soak. this will clear up dried up ink and unclog the nozzles.
put the printhead back into the printer run one printhead clean once to purge the ink and try to print.
I hope this helps.
I used my printer to do a photo guest book at my sisters wedding it turned out great (i wipped the printhead before i started all the pictures look perfect!)
SDtester.
Posted on Oct 15, 2008
Printer will only print purple
on a colour printer, black is mixed with the other colours. Try printing a black and withe photo and you always get a colour cast. If your black cartridge is empty or the nozzles are blocked, you get bad colour and fussy prints.
test all nozzles, like is explained in the manual.
Check, if you know how to do, if nothing fell in the printer, that is now on the print head. Sometimes just dust or paper scraps are picked up by the printhead, making it difficult for the printer to print a normal page.
Apr 15, 2014 | Epson PX730WD Stylus Photo
Alps MD1000 printer won't do anything.
Do you get the green ready light when you first turn on the printer?
Nov 05, 2012 | Alps MD 1000 Thermal Printer
When I print the picture has a purple haze in it ?
If you are using re-manufactured ink tanks, that would explain it, a mi-matched ink tank. To clarify the ink colour is not quite right.
If genuine ink tanks (Recommended) then maybe try different paper. If using photo paper you should be using compatible / genuine paper as the different chemicals react can give this problem.
If using fax / standard paper then could be print head fault....normally get an error code.
Jan 26, 2010 | Dell P703w Printer
Hi my prints are coming out in colour but with a strong purple tinge, how do I make it go back to normal?
first try the print head clean mode.. if that doesn't work go to your windows control panel and click on printers...you may have to recalabrate your printer and may need to change what print mode you are in...last but not least reinstall your drivers for the printer it may have gotten changed when you installed a graphics program....and/or you might just need a new print cart.
Dec 05, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
Clogged printer head on Kodak 5300
Call Kadak Customer Support. They will send you a replacement print head. I have already had to do this twice in about a year and a half. Tell them that you have run all of the tests or they will have you try it again. But in the end they will send you a new print head in a couple of days. This is the only thing that will work.
Aug 15, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Prints purple instead of black on photos only
My Canon printer has TWO slots for black ink cartridges. I assumed one was extra and didn't replace it when I ran out. Text printed just fine with only one installed, but my photos were printing with purple instead of black. I looked into it, and the two cartridges are different: one holds dye-based ink, the other has pigment based. Photos must require both kinds. If your printer is the same as mine, use both!
Jul 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Bizhub 250 slow to print files
When you ask to print the page are you asking for more the one copy? If you are there is a collate check button next to the requested sets box, in the print dialog box. Make sure its not check. Collating the print means your PC sends a copy of the file for each requested copy. IE: you print one page and ask for six copies, your PC sends the file six times, one copy of the file for each print requested.
Also because your printing from a windows application IE: Excel you should be using the PCL print driver as apposed to a PostScript print driver. The time it takes to convert the file into PostScript for the printer to process it is time consuming.
May 08, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
C5200 will not print. No clue to problem.
Junked the Okidata. Using old inkjet printer.
Jan 30, 2009 | OKI C5200n Laser Printer
I HAVE A KODAK 5500 PRINTER. IT IS ABOUT SIX MONTHS OLD. IT WAS WORKING FINE AND ALL OF A SUDDEN IT STOPPED PRINTING. I CALLIBRATE THE PRINTER BUT THEN IT WON'T COPY IT OFF THE SCANNER. I HAVE TRIED TO...
Retailers only have 30-day replacement warranty, unless you paid extended warranty from them.
Call up Kodak immediately to have that unit replaced, manufacturers have 1 year replacement warranty regardless where you purchased it.
Oct 13, 2008 | Kodak Office Equipment & Supplies
WILL NOT PRINT CD DISCS
You could try uninsatlling it completely and reinstalling it again with printer driver disc.
Sep 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
162 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
