The paper to be printed always loads crooked and jams on the right side like it pulls the paper to quick
  • 3 Answers
Well, the internal mecanism of your printer is already worn, or defective. the troner is bad. if its a printer less than 100 bucks, just get a new one, if its a really expensive one, then u need a printer expert, that has the parts for that issue.
Posted on Oct 12, 2008
Epson Stylus photo 340 r printer paper jam when trying to print
first, make sure you the paper correctly to avoid paper jam.
Single Sheets 1. Open the paper support and raise the extension. 2. Place your paper short edge first against the right edge of the feeder, under the tab, with the printable (whiter or glossier) side up. If you are loading multiple sheets, fan the stack of paper before loading it to prevent paper jams. Note: Don’t load paper above the arrow mark inside the left edge guide. Some special papers can be loaded only one sheet at a time. Slide the left edge guide against the paper. Make sure it is snug, but not so tight that the paper is bent. (For letter- or A4-size paper, you may not need to move the edge guide over.) paper.4.2.1.jpg 4. Open the output tray and pull out the extension. You should also follow these guidelines:Always load the short edge first, even when you’re printing landscape-oriented pictures. • When using special papers, check the paper package for additional instructions. Some papers require using a support sheet included in the package. Note: Always keep unused paper in the original package and store it flat to prevent curling.
if you loaded the paper, it jammed again, remove the paper and tried to print, still the same, its a hardware issue, alraedy, the printers roller is broken
Feb 09, 2010 | Epson Office Equipment & Supplies
The paper twists and causes a jam on every print
sounds like something jamed in the rollers like a pin etc
Jan 05, 2010 | Epson Stylus R265 InkJet Photo Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
Every time I try to print, the printer grabs the paper crooked.
There's a leaver where the paper comes out, make certain it's to the left when printing with paper and to the right for envelopes.
Jun 14, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Printer will not allow paper to flow freely; it jams on the left side and prints crooked.
first cancel all the prints going on and switch off and on the printer and keep the paper slowly
Aug 07, 2008 | Canon PIXMA MX310 All-In-One Printer
G85 series prints crooked
From HP's site:
Problem: The print on the paper is skewed.
Solutions: 1. Slide the paper-width adjuster against the left side of the paper stack, and 2. make sure that the rear access door in the back is fully “locked”.
Jun 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
E3 paper jam
if the paper is crooked it will come out wrinkled. If not the print is crooked indicating a different problem.
You wil have to look at the paper as it is printing, to see where it is catching, paper ramp maybe ( before the fuser entrance), exit rollers? ( only place I know there are bristles)
E3 is : paper jam in fuser
also check fingers or claws on fuser they catch the paper if worn.
Apr 21, 2008 | Office Equipment & Supplies
Epson Stylus CX4600 pulling paper in crooked
Hi, please check if there is a paper jam or any obstruction inside that printer. Check also the platen lever or the left edge guide, make sure that paper is loaded correctly. Try printing again. If issue still present. Your printer needs to be send to service center.
--->>> Tirzo
Oct 12, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
