Question about Zanussi FJS1225W Front Load Washer
Cycle problem My machine started cycle,took on some water then stopped.Now does nothing,no error messages just three flashing lights in timer window. Bungey
  • bungey3066 Oct 13, 2008
    Still no joy after checking water supply,noticed light at the Start/Pause button is flashing.
  • bungey3066 Oct 18, 2008
    Thanks to all for your help,problem cured by unplugging and replugging connections at water inlet.Thanks again ,Bungey3066.
    Genius:
  • 1,269 Answers
Let the machine cycle without water or load, just let it spin just to isolate the problem if its the motor or the timer circuit. If it still stops without water, its the problem with your timer. That one needs further diagnosis. Double check any loose wires or and faulty electrical and electronic component using a multi meter tester. If you found nothing suspicious, replacing the timer might fix the issue. If it doesn't stop without load or water, its the motor problem. The motor can be replaced as well.
Posted on Oct 13, 2008
    Sergeant:
  • 306 Answers
First try another gadget, a lamp or something on the wall plug, to see if the point is live. Then check your washer plug, could be that the fuse in the plug has blown, check out your washer wire....motor brushes can be replaced in situ but you will find it easier to remove the motor.
take the rear cabinet half off and undo electrical connections to motor. motor is held in by 4 bolts. undo and motor will slip out.
brushes are located towards the end away from the pulley and held in by 2 small bolts. undo, withdraw brushes and see if badly worn
easier way is to check continuity across the brushes with the motor in situ using a multimeter
Posted on Oct 18, 2008
    Sergeant:
  • 352 Answers
With this zanussi model a re-occuring problem that a lot owners are reporting is the water is not filling up the tub fast enough and the sensor shuts down the cycle. You will not see an error code for this because the pcb doesn't see this as an error. Check your filter to see if it is clogged, check water connection and make sure there is adequate water flow. The key here was no error code. Just not enough water to satisfy the sensor.
anaanymous
  • Zanussi Master
  • 19,396 Answers
That can be a problem with the cycle timer, check if water is being pumped into the machine, or it is being drained out.
  • Ginko
    Ginko Oct 13, 2008
    When the cycle does not advance, it is generally either a problem with a defective control timer, and in that case the timer should be replaced, or a problem with the water supply at the back.
    If cycle get stuck in the middle , and it does not drain, there is also usually a problem with the drain hose or drain pump not draining.
    Try first unplugging the machine for ten minutes, see if this reset the machine circuits and can clear the error.
    If it does not restart, there is probably need for a timer contrtol replacement.
    See also foolowing suggestions from Repaiurclinic:
    What
    is wrong with your Washing Machine?
    If you need parts you can insert your model number here, they also provide free schematics.
    Here is another part distributor : |
    Find Parts .
    If you post exact model number, I can find the schematics.
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
Washer stalls mid-cycle and keeps running but doesn't progress
check to see if the water is warm if not the heater has gone or the thermistor is faulty
if warm i can be a dead spot on the timer where the contacts are worn if so needs new timer
Jul 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore top loader, water won't drain
sounds like the pump is out. If you are certified to work with electrical, you can check power to the pump .May also be in the timer assembly too which can also be checked for operation.
Jun 13, 2017 | Kenmore Washing Machines
Soon as i set cycle and swich on door light flashes open
hi,
The cycle doesn't advance
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Thanks for your question.
Jan 03, 2009 | Ariston Technologies AW129NA 16 Lbs Front...
After performing a descaling cycle, the descaling light still flashes, what is wrong?
The manual states that after you descale, you have to hold down the hot water button for 6 seconds, that will turn it off and "reset the timer" till the next time it needs to descale.
Oct 31, 2008 | Coffee Makers & Espresso Machines
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
WF320P Water fills on wash cycle drum starts to rotate. After 30 seconds or so middle three red error lights flash and cycle stops.
Hi there swamib lets see if we can help you out. If the lights in the middle of the appliance flash led 1,2,3 that means there is a problem with the heater it is most likely it is open circuit replace this and it should solve the problem keep in touch noffie......
Apr 08, 2008 | Washing Machines
Washer stopped during cycle
cleanlaundry If your washer is less then a year old do nothing and call the manufacturer ASAP. It is under warranty for one year. Gendos...post back
Mar 17, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
66 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
