Question about Whirlpool Duet GHW9150P Front Load Washer
Light blinking When I push the start button the light just blinks and the washer will not start. Could this be a door lock problem? The door seems to be securely closed, please help
    Scholar:
  • 98 Answers
Click this link if you get any error or any light blinking on the pannel and the unit does nor works
http://www.applianceaid.com/frigidaire_frontload_washer5.html
thanks
Posted on Oct 12, 2008
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
Light Blinking (start/pause)
Door lock faulty probably,,,,try closing door,,switching on and lightly thumping door near handle
Jun 15, 2013 | Tricity Bendix AW1000W Front Load Washer
Lights blink on settings around the knob won't run from there
Your door switch is not working, the machine thinks that the door is still open.
Mar 11, 2012 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore Washer Model 48102. When I try to start it, the 'lock light' blinks. The door seems to be latched, but even when pushing on the door, it does not quit blinking and will not allow the...
Check and see if the door is impeded by lint ,gasket or something else. the switch could be out of alignment other wise I would say it is bad. Might want to look online to see if other people have had this problem and wrote a blog about it
Feb 15, 2011 | Kenmore Washing Machines
Everything seems to work, door locks, but water won't flow
Check the water solenoid valve, it may have failed. A quick test is to use hot wash rather than cold wash. If the hot water works, then your cold water valve has failed.
Jul 02, 2009 | Kenmore 46462 Front Load Washer
Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Sep 23, 2008 | Asko D1996SS Built-in Dishwasher
Blinking red lights and no washer operation
Dave, glad I could help, I'll mark this one as solved.
Jun 12, 2008 | Kenmore 4292x Front Load Washer
Kenmore HE3t lights up ,won't start
sounds like a door lock/latch issue, its not recognizing your closing door so its not starting unit
Feb 28, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Blinking Cycle Light
Most likely a faulty door interlock switch...try closing the door with more force, or pressing the door while trying to start...if this works it may be time to find a door lock in the meantime... Oshie
Jun 22, 2007 | Whirlpool GHW9200L Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
900 people viewed this question
Dan Webster
Dan Webster
Sal De
