Samsung HCP4741W - Won't turn on. Red light flashes on the power button. I checked inside and all boards and wires look fine. Any idea???
  • 65 Answers
SOURCE: power button flashing red
stk convergence packs may haqve failed in the dead short mode stk392-110 removing them from circuit may allow the set to turn on again good possibility do you know how to solder?
Posted on Dec 09, 2006
SOURCE: no power,red power lights keeps flashing.
Just my coment THis tv has a complex system that include a digital signal porcessing in a high levle technology to show a good performance, i myself work on the development of that model, we was thinking we are best, for improve that many eng. dedicates almost all life to have that technology in our rooms, I offer my apologize for that but many eng dedicates all year 18 hours a day to fix that, thanks
Posted on May 13, 2007
  • 179 Answers
SOURCE: ON/OFF button (red - off and on - green) flashing all the time
it is important to count the number of red flashes, if it is 5 then the lamp ballast board has failed, (part #1-468-798-14) if it is 4 then the optical block fan (# 178706511) is probably to blame, if it is 6 then the thermal fuse has gone bad..(# a1137954a)
Posted on Nov 29, 2007
  • 1779 Answers
SOURCE: Lamp power supply board on Panasonic PT-50LC13 mulfunction.
You can purchase the lamp supply thru "Encompassparts.com... The cost is $100.00, there is a $250.00 core charge on that module, so when you return the old they refund the 250. Initial investment will be 350.23 then take the 250. off that. That will be the end cost.
Part # LSEB3087A
Posted on Apr 16, 2009
  • 1525 Answers
SOURCE: Sony rear projection TV power light flashing red.
hello it will flash if the bulb is not securely fitted and make sure the front cover is fitted securely as well
regards
shaun
Posted on Jan 22, 2010
I have a Samsung LN52A550P3FXZA. The TV does not come on.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
May 26, 2016 | Samsung Televison & Video
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
Samsung 40" lcd ln40c530f1fxza won't turn on
The main board would be susoect next if the power supply has already been replaced.
Mar 02, 2013 | Samsung Televison & Video
Samsung TV won't turn on. Red light is solid, won't blink when pressed. All capacitors seem fine (none swollen or vented).
That model is covered under a class actions lawsuit settlement over bad power supply boards. You need to contact Samsung about this and get a warranty claim started, even if the original warranty is over the settlement terms will cover parts and labor. You can get additional information about this along with contact information here: http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
Sep 24, 2012 | Samsung LN32A330 32 in. LCD TV
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Samsung LN-S3251D
We have the same problem we have had ours for 2 months, went to turn it off the and the tv froze, could not turn it off or change channel. We had to turn it off at the power point, now it will not turn on at all. The red light flashes but no picture.
Jul 05, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
