Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint F-01 Error code
Hi Folks,
I have a Hotpoint washing machine model WT761P.
Over last couple of weeks my wife has said that the washer has not finished its cycle until she manually selected rinse and spin. Today it completed its cycle automatically but the door remained locked. After turning off at the plug it allowed her to open the door. When I turned it back on it gives error code F-01. At this point I cannot use the off button and have to unplug at the wall to remove the power. According to various sources this appears to suggest an issue with the motor or control unit. If I unplug the motor the fault code remains. I have removed the control unit and inspected the circuit board but can see no evidence of burning. I still suspect it is the control unit but have 2 questions:
Is there any way I can confirm if the unit is faulty before I waste money buying one.
Where can I get a new unit from as none of the parts sites seem to list them. The info on the board is that it is a Selectron with code no: 215009163.01.
Any help gratefully received before I have to go and buy another as I can't see that the cost of an engineer call out, labour and part(s) being any cheaper.
This washer is only 2 years old. What happened to the good old washers that ran for ever? My Dads is over 20 years old!
Thanks
Griff
Hi
my washing machine is 2 years old, hotpoint wt761p showinf f-01. it hasnt finished it cycle. turned off by mains to open the door and get washing out.
please help!!
stella
Posted on Nov 27, 2008
    President:
  • 1,653 Answers
Posted on Sep 08, 2012
Bought a new machine!!
Posted on Oct 16, 2008
How can i fix my hotpoint wt940 with F-01
Hi Hayley,
Please help us help you. Expand on what is working and what is not. SO please add to your comments and repost.
First things first. Water is always a hazard with electricity. Please turn of the power source to your machine and do a fine cleanup, Take canister vacuum and get the hard reach places. A large box fan will help dry the machine and the floor. Pull the machine away from the wall. If possible lift the top off the machine to allow air flow and a panel cover for examination. a hair dryer can be used to dry electronic components in the event of an overload. Give it a chance.
If the machine restarts and is faulting. Here is a link to diagnose the coding Error Codes Hotpoint Service
F01 - Short circuit motor triac*
Here is a place for an online repair manual Free Online HOTPOINT Washing Machine Repair Manual
Here is the Hotpoint manual conversion site Download Manual Hotpoint Service
It appears you may need a new module if the cleanup does not clear out the code
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3336-hotpoint-first-edition-hvl-series-washing-machine-and-washer-dryer-error-codes.html
Fare. Well.
Jan 05, 2015 | Hotpoint Washing Machines
Hotpoint washing machine, model WF630, Error F-03???
Error code F03 is indicating a problem with the wash thermistor, it could be open or short circuit.
Check connections on thermistor and heater element.
Hope this helps.
Dec 15, 2009 | Hotpoint Aquarius WD640 Front Load...
F-01 error hotpoint WMD960P
Error code F01 is indicating ashort circuit motor triac.
Check connections on motor the motor plug and then control module.
Please rate my solution.
Thanks.
Nov 17, 2009 | Hotpoint Washing Machines
Error code F-05 for hotpoint aquarious washing machine
your pump/filter/outlet hose is blocked. clean it all out with the power off.
Oct 30, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
I'm getting an E30 error code just after the first
Dear customer,
                     Error 30 (on Hotpoint) just means the motor isn't working. Several things, including the power module, can cause this. The most common cause though is worn carbon brushes. There is also a 7.5 amp fuse on or near the power module, which can blow. This fuse is on the motor circuit to protect the circuitry of the power module. If it blows, then the motor won't work and you will get error 30.
If it has blown, it's likely to be caused by the motor. I had one last week where the armature in the motor had shorted to earth which blew the 7.5 Amp fuse.
To check the brushes, with the machine unplugged! Have a look at
http://www.washerhelp.co.uk/spare-parts-shop/hotpoint-carbon-brushes-faq.html
http://www.washerhelp.co.uk/spare-parts-shop/Hotpoint-carbon-brushes.html
Plz rate this solution.. thank you..
Apr 09, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint WF640
the f-01 error code on your hotpoint all in 1 washer/dryer is a short circuit code for the motor. the only way to clear the code is to have a service tech come and inspect the reason for the error.
May 12, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
568 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
