Question about Dryers
Dryer is not heating. Replaced thermal fuse, it blew twice and then the outlet popped and the plug is now black.
    Problem Solver:
  • 52 Answers
The wires are crossed. you may have a negative connected to a ground. Or there is a short in the wires.
Posted on Oct 12, 2008
Miele Dryer Problem
HI,
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Aug 06, 2008 | Dryers
Maytag dryer is less than 3 years old. Blew thermal fuse. Cleaned all of the venting inside and out. dryer still overheating and blowing the thermal fuse. Replaced the thermal fuse and the high temp sensor...
Have you tried replacing the operating thermastat it's what shuts it off at the right temp and would cause the thermal fuse to go if it is not shuting.off at the right temp. It happens.
Hope this helps.
Dec 05, 2010 | Maytag PYE2300AY Electric Dryer
Thermal fuse blew...replaced it...got one load dried and new fuse blew...checked for clogged vents; are none. What else could be causing the thermal fuse to blow and so quickly as the new one did?
You need to change the t-stat, thermal fuse and high limit all at the same time...
read the electric no heat tip...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 24, 2010 | Dryers
I have a roper gas dryer and have replaced the thermal fuse twice, the dryer will heat and dry a load of laundry and then next time i try to use it the dryer doesnt heat what else could my problem be???
Hi
If your dryer is not heating, then check if the power cord is plugged into the wall. It may be loose or disconnected. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working. Now, check whether the heating element in your gas dryer is burned out by using an ohm meter to check for continuity. If the continuity is not there then you would need to replace the element. After checking the element, check out the thermal fuse to see if it's burned out. The thermal fuse is attached to the exhaust duct on the back panel of the gas dryer. It's usually surrounded by a black resin material situated in a housing made of white plastic. If the fuse looks like it
Sep 20, 2010 | Roper Dryers
Will not start
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with: Power from the house Door switch Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
Jan 01, 2010 | Kenmore 63942 Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Dryer wont get hot
Did you replace the Thermal FUSE? Or, the Thermal CUT-OUT? If the thermal fuse blew, the dryer would not run at all. If the thermal cut-out blew the dryer would run, but would not heat. The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Its great that you've cleaned all the duct work. That's usually the number one reason why dryer's fail. Poor ventilation causes the dryer to overheat to the point of failure. Now....before you go tearing the dryer apart again, did you verify the voltage at the wall receptacle? If you are missing a portion of the input voltage, the dryer will still run, but the heating circuits won't work. That's because the drive motor only requires 110-120VAC to run, while the heating circuits require 220-240VAC. If you have confirmed your input voltage is good all the way to the terminal block at the back of the dryer (read across the RED and BLACK leads), then the problem is your heating circuits. If the voltage is good at the receptacle, but bad at the terminal block, you have a bad power cord.
As far as what you have attempted so far, I'm not trying to undermind your abilties, I just want to confirm we're talking about the same components. Many people confuse the Thermal Fuse and Thermal Cut-Out. Although they perform similar in function, they are located in different locations in the dryer electrical circuits. Please read through the info I provided and let me know if you have any questions. All the readings you should get are provided. I hope this helps you isolate your problem.
May 04, 2009 | Whirlpool Dryers
Dryer won't stop
your blower wheel is either real dirty or your outlet is clogged up causing the thermal to trip.
Jan 11, 2009 | Estate TEDS840JQ Electric Dryer
Whirlpool electric dryer
either you are pushing the dryer back to far and crushing the exhaust vent hose .your exhaust vent going outside is stopped up , or your low temp thermo will not let the dryer cycle and it is over heating.
Feb 27, 2008 | Dryers
Dryers Logo
57 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
