Hi benimur i have philips DVP 3020 in setup > video settings > componet there are two options. after switching i lost signal to tv completely!! dvd still works as i 'blindly' pressed play and down to navigate trough mp3 folders. shows time of track playing. i would like to MASTER RESET the device, however i can't figure the solution that was posted on this topic already.thats how i found you out. ( there is no front panel on philips dvp 3020, and pressing channel up+down buttons on bush tv which is connected to dvd player and shows NO SIGNAL clock with expiring time - gives no results BYE) Thanks for ASAP help
  • zoso101 Nov 17, 2008
    The same thing happened to me tonight and i can't find the manual to try and change it back 'blindly'!! did you find a solution yet?
  • Anonymous Feb 02, 2009
    Did someone managed to do it?
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me",.
There might be more than 1 version of this player depending on country of origin or intended marketing region hence the solution posted that you are referring to might not be applicable to your concern.
Offhand, I would suggest that you try a hard reset, that is unplug from the mains for an extended period of time (perhaps even overnight). The idea is to dissipate whatever residual power is inside the unit and hopefully thereafter, it will revert to factory defaults. Then try again. On the first power ON, wait till "NO DISC" is displayed, then try a known good disc. Alternately, you can also try, unplug, wait for a minute or so, press & hold the STOP button, plug the unit to the mains. You can also try that with the other buttons.
Should the above be not corrective, am afraid that the a firmware update/flash/reset is required by an authorized service center.
Hope that this be of initial help/idea. Pls post back how things turned up or should you n
Posted on Oct 13, 2008
I bought some DVDs at, but I live outside the region code area witch the DVDs are supposed to work. I live in code area 4. I need someone to find a code to region 1. I have a Phillips home...
This player is relatively easy to change to region free. Please complete all of the steps below to unlock your DVD player.
Please note: Unlocking any DVD player may invalidate the warranty. Unlock sequences may not work with some firmware updates and some DVD players have been damaged through failed attempts to unlock them. Unlocking your DVD player is done at your own risk.
Unlock sequence for the Philips DVP 3020:
1. Switch on your TV and DVD player;
2. Make sure the TV is set to the correct input for the DVD player;
3. Remove any disc from the DVD player and close the disc tray;
4. Press the "SETUP" button on the DVD player remote control;
5. Use the LEFT/RIGHT arrow keys to highlight "PREFERENCE";
6. Enter 1 3 8 9 3 1 using the numerical keys on the Philips DVD remote control;
A pop-up menu will appear on the TV screen.
7. Use the UP/DOWN arrow key and choose "0" for all regions;
That's it. You should now be able to watch DVDs from all regions on your player. It is also a good idea to switch the player to standby and then switch it back on before trying any discs.
This is a verified unlock sequence for the Philips DVP 3020. If it doesn't work the first time, switch the power off and start again at step 1. If it still doesn't work, it is likely that you have updated your Firmware to a new version and this unlock sequence does not work with your firmware version
If you need further assistance, please reply to me from within this page and let me know which firmware version you have installed in your DVD player.
Jan 28, 2011 | Philips Televison & Video
I have a Philips DVP-3010 DVD player which I purchased in Europe and thus it was set to PAL video output mode. Connecting it to a US television (which understands only NTSC) and playing a DVD produces a...
Check that the TV doesn't have the option to display PAL transmissions. It might be able to do it via any of the connectors. Otherwise your best option is to find a TV that can indeed convert both signals, or get a converter box.
Apr 04, 2017 | Philips DVP3020 DVD Player
Unknown disk error on philips dvp 3020
I would guess that it's an incompatible disk format. If your burning software allows you to pick different types check the Philips manual for a compatible format
Mar 06, 2010 | Philips DVP3020 DVD Player
How to connect dvp 3356 t0 samsung 29 inch tv with crt tube.
Please check the connection. If you are connecting the 3 RCA cables to DVD component input/output, you need another pair of RCA cables to connect to audio out (FL&FR rear of DVD player) and Audio in (L&R) in your TV set. Else connect 3 RCA cable in 1-Video out & 2 Audio out of DVD player and 1-Video in & 2 Audio-in of TV.
Dec 15, 2009 | Philips Televison & Video
Philips DVP 3020 Wrongly set to Component
Use the yellow composite plug to connect to your tv..this always gives out a signal..
Feb 02, 2009 | Philips DVP3020 DVD Player
Region codes
Press "Setup"
Scroll to "Preference" using the LEFT/RIGHT arrow key
Press "138931" and a pop-up screen will appear.
Use the UP/DOWN arrow key to choose the desired number ("0" for any region)
Aug 26, 2008 | Philips DVP5140 DVD Player
Philips dvp 3020 dvd player will not play, the "no disc" sighn keeps coming on.
Try this. Wait for the "no disc" sign to appear, and only after that load the dvd. The 3020 I have works alright when I use this method.
Jul 29, 2008 | Philips DVP320 DVD Player
Pls try a full master reset which if done correctly would revert the unit back to factory default:
1. Power on the unit;
2. open the front panel lid to have access to the controls;
3. simultaneously press and hold the channel up and down buttons;
4. wait till "BYE" is displayed;
5. wait till clock switches off;
6. power on again and re-configure.
You may need to restore "Region Free"
1. Power on the DVP 3005.
2. Bring up the System Menu.
3. Navigate to the Preferences page.
4. Press the following combination of keys on your remote in this order to bring up the secret menu showing the Region Code.
1 3 5 5 6 6.
5. Use the arrow keys on the remote control to change the Region. To make it region free, set the Region code to “0′ (zero).
6. Exit the System Menu.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 22, 2008 | Philips DVP-3005 DVD Player
PAL problem
The DVD player you have is only compatible with NTSC TV. There is no way of changing that to PAL.
It is compatible though with PAL discs. It will convert the video signal of a PAL disc to NTSC format.
Dec 21, 2007 | Philips DVP3140
Region codes
Philips DVP 3015K / DVP 3020 / DVP 3040 / DVP 3040K / DVP 5140 / DVP 5960
  1. Method 1:
  2. Open the disc tray
  3. Press SETUP
  4. Navigate to the preferences page
  5. Enter 138931
  6. Select the region using UP/DOWN
  7. Press PLAY
  1. Method 2:
  2. Open tray
  3. Press 9, 9, 9, 9, 0
Dec 19, 2007 | Televison & Video
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
