Question about Sony VAIO Digital Studio PCV-RX550 PC Desktop
Error Message "STOP 0x000000ED UNMOUNTABLE_BOOT_VOLUME"
When I attempt to start my computer I get the error above. I attempted to go into SafeMode, I then would get a screen almost resembling the BIOS with
details about the computer, it would give me a count down, then the screen would start showing all the Window products: Windows.dll, Windows.exe, a whole list going down the screen. Afterwards it would look like the computer would boot because I would get the Windows XP screen, then the deadly cycle would happen again where I would get the error message above.
I simply want to be able to retrieve the information off the hard drive if that is possible. Please help!
    Scholar:
  • 136 Answers
There are two options to retrieve data: remove the drive and use it on an external box in another pc, or use an OS that boots from cd, like KUBUNTU, and record it in cds or dvds (though only LINUX systems will read them).
As for the causes, it might be a hardware fault (damaged HDD) or simply some driver you've updated recently and is giving hardware some suicide commands. And don't send it for repair if you have sensitive data in there, unless you can be there through the whole process.
Posted on Oct 14, 2008
How can i fix a blue screen error UNMOUNTABLE BOOT VOLUME. technical information is: STOP: 0X000000ED, etc.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test or replace all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Jan 13, 2011 | Microsoft Windows XP Home Edition
Will not boot-up, then used safe mode, I got a "stop code"
STOP error 0xED means that the I/O subsystem attempted to mount the boot volume and it failed. STOP code 0x000000ED may also display "UNMOUNTABLE_BOOT_VOLUME" on the same STOP message. Problem is with the hard drive
Check this: What MS has to say http://support.microsoft.com/kb/297185
Most probably a damaged directory structure. Firs make sure that the hard drive is connected properly. Use your windows cd and boot from it. Go to Repair mode. Type Dir and if it says there is an error accessing the disk. (Directory Enumeration). Type D: (If u have a separate volume er I mean a partition) Type Dir and enter. If it shows the directory list thats fine. Type C: and go their again. (You have to hit enter after typing for every command) Type chkdsk C: or chkdsk /r C: (recommended)
Then it will scan the disk and do the repair. (There is a minimal loss of data if its damaged pretty too much). If you see that it repairs after the process type Dir and hit enter. If you see the directory list then its the time to boot the machine and its all done! If still error is shown type fixboot instead chkdsk Note: If chkdsk command is unavailable type help and hit enter to get a list of commands. Check for scandisk and use it (scandisk c:). Thats for older versions of windows.
Thanks for contacting Fixya.
May 28, 2010 | Toshiba Satellite A45-S121 Notebook
Stop: 0x00000ED
0x000000ED Unmountable Boot Volume
Boot to the Windows CD, go to recovery console, run CHKDSK /R see if the issue resolves, if not replace the HDD
May 15, 2010 | Dell Dimension 2400 PC Desktop
Unmountable boot volume - Each time I try to start the notebook the same problem happens
There are a few things that can cause this error and each error has a different fix. Please consult the following Microsoft link for repair instructions,
http://support.microsoft.com/kb/555302
If your message is
yiur fix is towards the bottom of the page.
Good Luck
Jan 13, 2010 | Toshiba Computers & Internet
I'm getting a stop error code 0X000000ED,0X86714368, 0X0000006, it's on a Dell Latitude D600 laptop?
Unmountable boot volume indicating that the system cannot successfully read the boot sector of the hard drive.
Run the diagnostics on the hard drive, if it fails, replace the hard drive.
If diags pass, boot to the recovery console, run chkdsk /r If it still gives the error after that, you can try reinstalling windows.
If that fails to resolve, then again, replace the hard disk drive
Nov 19, 2009 | Dell Latitude D600 Notebook
hi,
-this can be a hardware problem or a software problem
-run diagnostics first on the computer
-turn off computer; while the computer is off, press and hold the "Fn" key then press power at the same time to initialize the test
-if you find error message like 0142 - this is a hard drive failure; contact your manufacturer for replacing your hard drive
-if no error is found, it is a corrupted Windows; you need to reinstall Windows, ensure you consult local technician to back-up files before installation.
cheers!
Oct 05, 2009 | Dell Inspiron 1525 Notebook
Hi
It looks you have a bad hard drive. Have you tried changing it? If not, try it. Regards.
Nov 28, 2008 | Sony VAIO VGN-FJ270/B Notebook
Open Questions:
USA***1~877~778~89~69***Avira Antivirus Support Helpline Number? USA 1-877-778-89-69 Avira Antivirus Support Helpline number is straightforward to use. Avira Antivirus Support phone number is open twenty four hours daily and seven days per week.Avira Antivirus support Helpline Number's agent will assist you with remote help.Avira Antivirus Support Helpline Number 1-877-778-89-69 is one of the most promosing and helpfull number of any Antivirus issue's.We are open 24*7,ready to solve your problem with just a TollFree call:-1-877-778-89-69 .Our expert team finding your issues area and solve the problem in faster and easier way.We are Happy To Help You.We are Avira Antivirus SupportUSA.A single call will change your life.just dial:-1-877-778-89-69. For any question or help:-1877~778~89~69. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number. Avira Antivirus Support Phone Number Avira Antivirus Customer Service Phone Number Avira Antivirus Tech Support Phone Number Avira Antivirus support Helpline Number Avira Customer support Telephone Number Avira Helpdesk number Avira Tech support Telephone number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number Avira Security Tech Support Number Free Avira Antivirus Customer Support Number Avira Customer Service Tollfree Number.
Mar 24, 2017 | Avira Computers & Internet
See all Sony VAIO Digital Studio PCV-RX550 PC Desktop Questions
Computers & Internet Logo
197 people viewed this question
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
