Question about Roper RGX4634KQ Gas Dryer
Motor removal for Roper RGX4634KQ Gas Dryer
My Roper RGX4634KQ Gas Dryer hums when I press the start button. I suspect the motor has gone bad. Before I spend $100 on a new motor, is there anything else that could be causing the dryer to do this?
How do I remove the motor?
  • Paul Hardy Oct 12, 2008
    I had allready removed the drum. The belt looks good. I jumped out the door switch so that power would get to the motor. When I press the start button the motor hums the way an electric motor does when it's seized up, but the motor turns freely. I think if it has a capacitor that is failing it might cause this symptom, but more likely would not allow any current to get to the motor at all. Unfortunately I don't have any way to test it.
    Sergeant:
  • 352 Answers
The windings in the motor may have gone to ground, not enough to stop the rotor from freely spinning and tripping the breaker, but enough to cause motor to hum idlely . Unhook electrical supply, take off electrical connections, tip unit on its side, remove motor mounting bolts.
anaanymous
Posted on Oct 16, 2008
    Sergeant:
    Champion:
  • 435 Answers
When it humms, does it turn at least little bit ?
If the motor rotates freely, try rotating little bit and then try to start it.
You can check the motor alone by connecting the power directly to it (check motor power ratings).
If it works, something wrong with circuit, if not, motor is bad.
    Sergeant:
  • 399 Answers
Try this link for extra information
www.applianceaid.com
Posted on Oct 12, 2008
  • masterexpert Oct 12, 2008
    You will most commonly measure two electrical parameters when you're troubleshooting your appliance: resistance (measured on units called "ohms") and voltage. Typically, both of these measurements are made on a single meter called a multi-meter, which you can set to measure either ohms or voltage.
    http://www.applianceaid.com/electrical_t...
    all the measurements and procedures to measure the powers at junctions is given step by step on the above link.
    feel free for further assistance if any.
I moved and cannot locate the pilot/ignition source on the dryer to relight it.
It's been many, many years since dryers had pilot lights. Look for an igniter that may have gone out. It should be behind a service door.
May 30, 2015 | Roper RGX4634KQ Gas Dryer
Recently had 8" of water in basement. When dryer
You may need to call for service...what your describing sounds like the motor is bad..give it several days and see if it does start but i suspect the motor is bad
GENE
Sep 10, 2011 | Roper RGX4634KQ Gas Dryer
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
The dryer is humming but not spinning when i removed the top cover i see the belt in the middle of the drum. Do you know where it supposed to go?
is belt disconnected? Is belt broken? Will dryer rotate manually? if so ,
I suspect that the belt broke. order a new belt Home depot has a good parts service or try other local appliance places. You will have to disconnect power first, Remove front panel to access drum Dont forget to unplug door switch there should be a plug front top right, in the rear on the bottom there is a motor and an idler/tensioner. install the new belt and under tensioner Yes the path will seem awkward and re assemble. Also now is the time to vacuum lint out
Dec 30, 2008 | Roper RGX4634KQ Gas Dryer
I still need instructions on how to remove the motor
hi. not unless the blower is jammed with something.the top comes of, the front comes off the drum comes off replace the motor. if you need my assistance lets chat. thanks
Oct 12, 2008 | Roper RGX4634KQ Gas Dryer
Gas dryer hums when I press the start button but won't start
hi thats a sign of a faulty motor . replace the motor thanks the appliance doc.
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
Jul 21, 2008 | Roper RGX4634KQ Gas Dryer
Roper gas dryer will not start
hi that sounds like a bad motor.
Jul 14, 2008 | Roper RGX4634KQ Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
146 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
