Have a Kenmore Oasis 2703 Top Loader. The spin cyle started getting very loud about a month ago. It is not that is off balance or that the machine is no level. When the spin cyle reached top speed is sound like a bad bearing on a car. You have to close the door to the laundry room because you have a hard time hearing TV two rooms away.
Any help is appreciated!
Brad
Your probably right as most washing machines use bearings and they do wear out rather quickly on some machines ,depending on how yours was put together will determine on how easy it is to change , some manufactures made it much more easy than others .If you remove the back panel (that's if it has one )and after it has gone through its spin cycle and you have turned of the power you should be able to feel around where the bearing is incased to see if it has generated an amount of heat even though they are usually encased in oil as this would be a indication that it has failed, if you watch the machine clicking into spin mode ( by looking at the motor etc with the back cover removed)you will also get a better idea as to what parts have come into play and pinpoint the problem area .
Posted on Aug 07, 2017
SOURCE: Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Posted on Jan 28, 2009
SOURCE: Kenmore Oasis top load washer model 100 27072603
Here
is a tip that I wrote about dryers and noises...
It will help
you determine what is happening there...
Dryer
Repair Squeaks,
Grinding, Clicking and Knocking Noise
heatman101
Asker's
Testimonial "That answer was very informative - thank you for
taking the time to educate me. " - teresa241964
Posted on Jan 15, 2011
Jan 16, 2016 | Washing Machines
Feb 02, 2013 | Washing Machines
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
Sep 18, 2010 | Maytag Washing Machines
Jan 03, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Jul 14, 2009 | Washing Machines
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Mar 10, 2009 | Maytag EPIC MFW9700S Front Load Washer
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Mar 05, 2008 | GE WSRE5260D Top Load Washer
Mar 18, 2017 | Kenmore 27032
Oct 01, 2012 | Kenmore 27032
106 people viewed this question
Hello
My Kenmore Oasis is doing the same thing. It seems to have started after I ran the clean cycle. I also recently had to have a electronic part replaced, cost almost $350 with labor! The loud spin noise started right after that, but that is also the same time I ran the clean cycle.
