Question about Thermador UCV36A 36" Universal Cook 'n' Vent Downdraft Kitchen Hood
Thermador UCV36 Cook'N'Vent Downdraft System recoouring part replacement
I have had issues with this Thermador Downdraft system since I bought it. There is a part that has to be replaced about every 9-12 months. It would need to be replaced more often except that I don’t cook very much. The repairman suggested a design flaw in this unit. Apparently the design problem has two issues: 1) is that the yoke is a piece of flat sheet metal bent into shape instead of a more durable part - in not only bears all the load to drive the vent up and down but it also does so by a twisting action which causes more stress on this flimsy part; 2) is the only thing that holds the filter assembly on the yoke is gravity, it is not secured on it. Can anyone offer an alternative fix? Every time I have to get it fixed it costs me $250-350.
  • RogerBatavia Dec 22, 2008
    I have the same problem on my RED30V Thermador. Thermador no longer makes the part for mine. Where do you find the yoke? Maybe the one you're using will work on mine?
4 Suggested Answers
  • 338 Answers
SOURCE: My 7 1/2 year old Thermador CVS36RB Cook 'n' Vent won't retract
sears labor is 137 plus parts. that is something that would need to be looked at. it could be a few different things. if he is handy he can open it up to see if anything is misaligned or broken. the vent may even just be a little crooked and once straight may go up and down like normal
Posted on Dec 07, 2008
  • 5 Answers
SOURCE: install a Thermador UCV36 cook'n'vent
I have three 90s on my downdraft unit - 90 down from unit into slab, 90 out from slab to outside, then 90 down again. If you are talking a 6" or 8" dia vent it should not make a difference at all.
Posted on Jan 07, 2009
  • 37894 Answers
SOURCE: Thermador CVS36R Cook'n'vent vent won't go down and fan stopped workin
You probably will find that the vent is clogged with grease. A switch device works with the vent so the fan operates only when the vent is open and does not operate when the vent is closed. Things should get back to normal after a thorough cleaning unless the fan is defective and won't operate at all.
Posted on Sep 03, 2012
The vent downdraft keeps going up and down
This means that one of the limit switches by the motor has failed.
Apr 22, 2011 | Thermador UCV36A 36" Universal Cook 'n'...
Thermador cooknvent downdraft CVS36R
this is the little circuit board in the switch that is defective here you will eed to replace it.
Oct 24, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Thermador cook n vent stuck in the up position. We have a thermador cook n vent. We had it running for about an hour. We turned the fan off but now it is stuck in the up position and will not go down. ...
replace the switch if the switch is going on and up position and not in down position the you should replace the switch for this part you can order it from thermador if they still stock the piece hope this helps
Aug 11, 2010 | Thermador UCV36A 36" Universal Cook 'n'...
Thermador Downdraft blower Fan Not Working
could have serveral problems / if under counter or in back of range . the last two i had the control buttons w wire harness needed replacement /another required the pc board in connevtion box ( under counter in right cornor. also look for poor connections in the power box .
Dec 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
My thermador stove fan keeps going up and down cvs45r
no
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Mar 07, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Cook 'n Vent Downdraft Up/Down Mechanism Replacing
just the switch should be replacable. My vent has a screw at each end (philips flatheads - accessible only when vent is up) just under the top cap. Removing the screws and cap should give you access to the switch. Just make sure you cut your breaker off first.
Nov 15, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Thermador cook top with down draft ventalation
I would think you can. Most of the cooktops are 240v and the vents are 120v, so the vent may be feeding off of one of the cooktop's hot wires. My vent is fed from it's own receptacle but is harnessed along with the cooktop's 240v.
Oct 31, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Install a Thermador UCV36 cook'n'vent
Hi schmidt_rich,
I'm Harvey the Master Plumber.
Your question is: You took over as owner builder when your builder "took the $ and ran". You are installing kitchen cabs now and discovered the PVC vent pipe (which goes into the foundation and out the side of the house) is in the wrong place for the location of the downdraft unit and integral blower. The vent is actually under the electrical connection panel. You were told initially( 2 yrs ago when you bought the downdraft cook'n'vent) there could be no bends in the exhaust fan route or it would change the effectiveness. Does anyone know if it is ok to put a bend in the connection to the vent? Or do you need to redo your kitchen cabinets?
I can syphathise. I have had to deal with this same problem. I have found that one ell will not degrade the effectiveness enough to notice. If you need more then you may need to adjust cabinets.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 24, 2008 | Thermador UCV36A 36" Universal Cook 'n'...
Kitchen Ranges Logo
248 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
