We've had this pump for a 2 years now. First year worked flawless, now it keeps screwing up. Everyday it's the drain is clogged. I can't even program to run sweep anymore, because i never know when it will just shut off for no reason.
SOURCE: I have intelliflo VS+SVRS pool
There is either something blocking the suction side of this pump (blocked valve, strainer, strainer basket, leaves on main drain.) or the pump is not getting primed in the aloted amount of time. You can increase the priming time on the pump, or manually prime it, or just turn off the svrs feature temporarily until you get a good prime again. If you need the manual to figure out how to do these things, here is the link.
http://www.pentairpool.com/pdfs/IntelliProVS+SVRSOM.pdf
SOURCE: After two years of perfeft performance, the Legend
If your RPM is low, you will need to increase pressure to the cleaner. If the sweep hose is laying on the side and not sweeping, you will need to adjust the screw that holds it on to get it to a gentle sweeping motion. It is also possible that you have too much hose weight on the pool cleaners sweep hose. Try removing some of the weight and seeing if that changes.
SOURCE: the pump keeps trying to prime. There is no air
Most of the time you are sawing air from thpumo lid. Hav you lubricated the o-ring in the lid? If that doesn't work, keep working your way forward and lubricate the 3 way valves as well.
Hi
F21 error means that the drain time has exceeded 8
minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to
clear the display. If errors still remains then please check the drain hose and
make sure it is not plugged or kinked. Disassemble the washer by removing the
back from the washer and check the electrical connections at the pump and make
sure the pump is draining. Also inspect the pump filter for foreign objects.
Before disassembling remember to turn off the power and disconnect the washer.
If it still doesn't help then there is an issue with the pump and you'll need
to replace it. Hope this helps... Please post back if you need more
information.
Daniel
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
Hi
information.
Daniel
Hi
Dishwasher not draining issue usually occurs due
Daniel
Hi
information.
Daniel
Hi
Daniel
Hi
Daniel
