Question about Sharp Office Equipment & Supplies
Error message F2-04 on Sharp AR 168D copier I changed the toner but it still shows low toner & then this error mrssage
  • 6 Answers
SOURCE: On a Sharp AR-157E, I
Finally tracked down an error code list showing the errors were associated with the CCD and scanner
Posted on Jul 10, 2008
checkitright
  • 1362 Answers
SOURCE: My Sharp AR-336 copier gives
when you turn on the machine it rotates and takes severaal readings from different sources. one of them is for the drum, adjusting the seperation to the age of hte drum. So as the drum ages with the amount of copies it automatically adjust it self. Have the tech replace that sensor (if they haven't done so) or maybe it just has toner on it giving false readings.
http://www.copier-help.com/copier-help/ecs/sharp/ecssf2216.html
Posted on Aug 07, 2008
SOURCE: Error 7C
There's no manual for "machine error 7C" in Bro IntelliFax 4100. To fix this issue. You will need to pull out the toner. Note: the toner and drum are connected.....At the left corner of the drum. You will see a blue tab......You will need to slide the blue tab back and forth for 20th times....And put the toner back in its place.....This is just a temp fix but you need to replace the drum to have it working its fullest......
Posted on Jan 23, 2009
greg_margo
  • 1959 Answers
SOURCE: "Toner Low" keeps showing
Hi Meridy!
There could be a few reasons for the Toner Low msg you're getting.
  1. The toner wasn't evenly distributed when the cartridge was changed (shake gently from side to side before installing)
  2. The cartridge wasn't properly installed (ensure that the lock lever "clicked" into place
  3. The corona wire wasn't cleaned when changing the cartridge or the the blue tab wasn't put back in place (this is less likely the issue but still a possibility)
  4. The new toner cartridge was old and is now defective
I hope this helps with your problem. All the best!
Greg
Posted on Jun 17, 2009
  • 990 Answers
SOURCE: Error H3-00
Hello sir; This error code require a reset procedure ;
press "#", "*", "clear", "*",these four keys by order, then enter 14 press start. then turn power off and back on.
Posted on Aug 26, 2009
How do you clear the error message on a AR-168D?
We inject the cartridge int he printer it gives the message on AR-168S
Apr 07, 2011 | Sharp AR-168D Black and White Copier
System error (U2-40)
This is a problem showing conflict in toner sensor . It is caused by either bad toner cartridge or short circuiting caused by toner spills around the sensor areas.
Solution
Remove the cartridge out and wipe the sensor area and push it back. Then key in C-Auto- C- Auto in that order and enter 16 and press copy key. If it comes back, then replace toner cartridge Ar168ft cartridge.
Dec 06, 2010 | Sharp AR-168D Copier
Error code F2-04 and E7-10 on AR-168D
F2-04 is an improper cartridge code and the E7-10 is a shading/lamp brightness issue. I would say the F2-04 is causing both coded, Change the toner cartridge. I have seen those chips on the back of the cartridges cause weird problems. That or the developer unit has failed.
I strongly suspest that once you resolve the F2 issue the E7 will simply go away.
Aug 03, 2010 | Sharp AR-168D Copier
How to refill sharp 168d
First open the right-side door, then depress the upper side tabs of the front door to open it.
The toner bottle has a green, square plastic thumb grip on the top, front part of the bottle. Press down on this part as you pull forward. You should be able to remove the bottle and replace it. Make sure the new toner bottle fully seats before closing the unit up.
Close the front door, then the right-side door and the machine should recognize the new cartridge.
If you're looking to have the bottle re-filled, you will need to contact one of the third-party companies that refills and sells toner bottles. I would advise purchasing a new, authentic bottle of Sharp toner for this unit, as re-filled, non-Sharp toner providers have a history of selling poor quality toner refill kits.
Sep 26, 2009 | Sharp AR-168D Black and White Copier
Error H3-00
Aug 26, 2009 | Sharp AR-168D Copier
My SHARP AR-168D is not recognizing a new toner cartridge.
Make sure what you've got is Sharp's AR168NT and not AR152NT. Sharp mades changes about a year ago to their toner and the chip on an AR152NT will not work with an AR-168D model.
Aug 18, 2009 | Sharp AR-168D Black and White Copier
Sharp AR-168D H2-00 error code
Check
http://www.copier-help.com/copier-help/ecs/sharp/ecsar161.html
Thanks.
Jun 11, 2009 | Sharp AR-168D Black and White Copier
Having trouble installing a new toner cartridge in a Sharp 168D.
green labeled facing you when you install the toner in the machune there is a wute tape on it
Feb 11, 2009 | Sharp AR-168D Black and White Copier
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
111 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
