Question about Samsung Digimax D53 Digital Camera
Blurry bright pictures
If i take a picture outside or in the light, it comes out very blurry and the brightness overrides the actual picture. can you help me?
    Problem Solver:
  • 3 Answers
1.go to menu go to quality and put in fine. make sure also that your flash is on during the night and your not moving the camera around while your taking pictures.
Posted on Oct 26, 2008
Panasonic hgtv 1080i blurry screen
The blurriness is caused by the picture tube itself. If you were to look into the light that you covered up, not recommended because it is very bright and could hurt your eyes, it would look blurry compared to the others. The picture tube would have to be replaced about cost about $400 or more to replace
May 05, 2017 | Cars & Trucks
The camera took great pictures then all of a sudden the screen appears as a purple haze -- and the pictures come out as just a purple blurry haze. Adjusting brightness doesn't work. Yet, the shutt
If the LCD displays correctly on previous photos then the problem is more than likely a CCD or associated ribbon connector failure due to moisture/condensation or age/misuse. Good luck with finding a replacement part!
May 31, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
Why does my camera take white pictures outside,
Do you have the ISO set to a very high number instead of "auto ISO"?
Apr 18, 2010 | Kodak EasyShare C763 Digital Camera
When trying to take pictures of my motorcycle with all the led lights on at night the pictures keep coming out al blurry or very bright I have tried the settings on night time/ museum/ without the flash/...
Most likely the problem is "Camera shake". This just means that being in the dark, the camera shutter speed is long enough that the natural shake of your hands make the picture blurry.
You've got a couple options. The easiest is to find a nearby object and use it to steady your hand as you take the picture. You can also get a tripod and use the time delay release on the camera. This will let you push the button (which shakes the camera) and then step back before it actually takes the picture.
If you're shooting fairly bright LED's on the bike, you also might go into manual mode on the camera and experiment with shorter shutter speeds. Most people can use a speed of 1/60 without too much blur, so start with that and move to shorter speeds (maybe 1/100 or less). With the manual speed, you may get enough light from the LED's to make a good picture.
If this doesn't work for you, post a comment and I'll check back every few days and give some more ideas. Your camera may have some other ways to work through this. Rear curtain flash would be the best, but I don't think it has it....
Sep 11, 2009 | Nikon Coolpix 4800 Digital Camera
Picture is pale, yet reds are bright. checked color, brightness, and conversion settings. TV seems unresponsive to the color, tint, and brightness adjustments.
open the back and look into the projectors red blue and green should be clear picture if its blurry need to change the coolant if its not on need to replace the projectors
Aug 22, 2009 | Philips 50P8341 50" Rear Projection...
Picture went bad
GO TO THE MENU ,,TRY THE COLOR CONVERSION OPTION,, OR CHANGE YOUR CONNECTION JACKS
May 15, 2009 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Why are my pictures so blurry.. HELP PLEASE!!
Hi Lindsay Davi,
First, make sure you have the file size set to the highest size and highest quality. Small file size and low quality settings produce small files with pixelization.
Second, no camera performs as well in low light as it does in bright light. It sounds like you are new to photography, so you should start out by shooting in bright light - outdoors in the sun. Once you know how to take good photos in the sun, then you can try taking photos when it is overcast, or in bright shade (on a sunny day but outside of the direct sunlight). As you develop more experience in taking photos you can try more difficult lighting situations such as indoors.
Flash lighting is difficult because the light "falls off" quickly as the distance from the flash to the subject increases. The camera's flash tries to put out enough light to illuminate both the subject closest to the camera and to also try to light the background, but this is often impossible. So the subject is too bright, and the background remains dark. If your subject is further away, the lighting evens out some. If your subject is close to the background (e.g. standing in front of a light colored wall) the camera will get the flash exposure set to a better value and the photos will come out better.
It would also help to get a book on basic photography.
Dec 26, 2008 | Nikon Coolpix S550 10 Megapixel Digital...
Help with settings - blurry SD picture
contrast full, brightness, tint, color, in the middle, then adjust sharpness for what suits your eyes, you may turn brightness and color below middle.
Mar 17, 2008 | Sony BRAVIA KDL-40V3000 Television
Blurry and Bright white on subject face
This could be a CCD fault or possibly Lens damage. Not I would think something amenable to a sensible repair price- check Olympus first though.
Jun 18, 2007 | Olympus Camedia C-4000 Zoom Digital Camera
Why do my Fun! Digital 320 pictures come out blurry?
Blurry images can be caused by any or all of the following: * Distance/Focus range -- the Fun! Digital 320 has a fixed focus range of 3 - 6 feet (1.8 meters) for brightly lit indoor photography, 3 ft. (1 meter) - infinity for outdoor photography. For best results, make sure that the camera is at least 3 feet away from the subject(s) when taking pictures. * Camera/Subject movement -- This is a common cause of blurriness, especially in low-light situations (see Lighting below). Hold the camera as steadily as possible while taking a photo, or use a tripod (a tripod mount is located on the bottom of the camera). Avoid subjects that are in motion. * Insufficient lighting -- the Fun! Digital 320 is designed for taking photos outdoors or in brightly lit environments. Inadequate lighting can exaggerate camera movement and contribute to blurred, "muddied," or uncrisp images. * Lens condition -- Check the lens periodically for smudges. If necessary, wipe the lens clean with a soft, lint-free cloth. Do not use cleaning solutions or chemically treated tissues. * Enlarging images using software -- otherwise normal digital images can appear to become blurry and/or blotchy when over-enlarged in software. To see an image's "true" appearance, use the software's Zoom In or Zoom Out feature to view it at 100%.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Samsung Digimax D53 Digital Camera Logo
145 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
