Question about Sport & Outdoor - Others
Hot tub breaker keeps tripping
The gfi circuitbreaker started tripping out of the blue; I disconnected the power from the motherboard and breaker did not trip,which indicates to me the powerfeed is ok.,reconnected it to the motherboard with all accessories unplugged and breaker tripped again.Does this mean the board went bad or am I barking up the wrong tree?Any help would be appreciated.
  • 41 Answers
You are exatly right. It's really not that uncommon for Older models to have faulty motherboards. Once you replace that, it should be working new.
Posted on Oct 15, 2008
I have a spa berry 2 person hot tub. Tried resetting it but as soon as I let go of the reset button it trips the breaker. Can't get it to stay on. Tub is 4 yrs old. Where do we start?
Melisa, Breaker/GFI may be going bad. You may have to get an electrician to check for short or faulty motor/heater, etc. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ehottubsandpools.com/?p=320
Troubleshooting tripping hot tub GFCI breaker
Hot tub GFI keeps tripping
Spa Circuit Breaker Mysteriously Tripping Any Clues Portable Hot Tubs amp...
Jun 27, 2016 | Pool & Spa
Sta-rite heater is about a year old. It worked well up until a week ago. It now trips the gfi breaker. I swapped out the breaker and it trips that too. If I disconnect the exhaust fan, the heater powe
Something in the electrical system supplied by the GFI breaker has a ground fault. The current to ground required to trip a GFI is very little such that dampness on any electrical connection can trip it. This is especially true with motors that have a lot of fine wires in the windings and are open to allow cooling.
Hard water and pool chemicals all are worse than condensation from the air because of their ionic nature.
If the same GFI powers the pump it is what I would suspect first. Your question got cut off before the result of the fan disconnect which if disconnected didn't trip the GFI, is probably the problem. But you should open whatever you can access containing electrical components and make sure everything is dry
Feb 07, 2015 | Sta Rite Pool & Spa
What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Oct 02, 2012 | Electrical Supplies
I have a freeflow legend hot tub. the gfi was tripping and i found the heating element was bad. i replaced the heater element now when i power up the tub a circuit breaker trips on the board and nothing...
It sounds like there may be a short in it causing the breaker to trip. I would disconnect the wires from the new element, tape them up and test for the problem again. If it still trips it is not related to the heater element. If it still trips it is not related to the heater element and therefore additional diagnostics need to be used to find out what is is wrong.
Sep 04, 2011 | Pool & Spa
I have a GE two speed motor/pump for a hot tub that I have adapted for a type of therapy called underwater pressure massage (all of the hot tub jets are channeled through a single hose for the high...
Disconnect both hot leads from the breaker at the box. Using an ohmmeter measure the resistance to ground or the neutral bar in your box. If the resistance is LESS than about 50 K you have excessive leakage current. It is unlikely the motor is the problem. I would check the wiring and switching for the leakage. Now to the second problem: If you switch between speeds while the unit is running, the GFI will LIKELY trip. This is normal as you create a massive transient that the GFI PROBABLY can't handle. There are a couple things to try: One is using a two pole control switch and turn off the pump before "switching gears" ... as an electrical engineer I can't explain this unless you can understand electrical transients AND capacitive coupling between the windings and the case of the motor. I realize you may have a combination speed and on off switch so you MIGHT have to add a switch. Ideally I would want a relay for on/off near the breaker that momentarily disconnected before shifting gears. The next fix possibility involves a trick we use to control transients in electronics. This involves noise control by using a toroid around the pair of hot wires. This MIGHT take several turns through a good sized ferrite toroid with both the hots in the same direction, side by side. This forms what we call a "Bi-Filar" choke. Look that up on Google to understand the principle... it essentially helps balance the currents in the hots and isolates them from ground for transients.
May 08, 2011 | Bryant 50 Amp 2 Pole Br250 Type Br Ni...
40 amp gfi on hot tub keeps tripping.I have a 50 amp.can I use?
Your hot tub needs GFI protection because it is electrical, and people sit inside water that could be exposed to electric current.
You have a fault to ground that needs to be fixed.
Size 8 wire for 50Amp breaker.
Size 6 if tub is 50-100' feet away
http://waterheatertimer.org/Color-codewire.html
Nov 09, 2010 | Spa Parts Plus GFCI, Circuit Breaker, 40...
Gfi Breaker 2 Pole 20 Amp: installed 20 amp dbl pole breaker to hot tub. Keep...
When Working with Household Electricity you want to always keep in mind that the BLACK wire ALWAYS carries DEATH. What I mean by this is that working with a Single Phase Circuit (one that uses 120VAC) the only wire that should be carrying a voltage is the BLACK one, the other 2 wires (typically the White Neutral and Green Ground) should both be electrically connected to Earth Ground (usually by being attached to your water pipe.)
It is also possible that your hot tub may use more than 20 Amps.
May 17, 2010 | Cutler Hammer Gfi Breaker 2 Pole 20 Amp
Our hot tub keeps tripping the gfi breaker, but if we don't put it on a gfi then it works fine. How do you fix this
The GFI is sensing a fault, and tripping to protect you. If there is another GFI in the circuit somewhere then you could use that normal receptacle. I mean if there is a GFI in the main panel.
Please Vote !!
Apr 19, 2010 | Balboa Instruments Duplex Digital Panel 2...
2 yr old softub Hot tub with connected GFI wire was emptied and cleaned out and filled; now the GFI trips when pluged in, and will not turn on!
Either the GFI is bad or it is tripping because there is a short in the system (obviously, right). I would turn off your panel break, disconnect the GFI and using a meter test to see if there is a short in the system. You would check the hot lead coming from the GFI to the tub and see if it is shorting. If you can't find a short, you should try replacing the GFI. If there is a short then you need to search for the short. Hope this helps and good luck!
Mar 14, 2010 | Leviton 8599 GFCI Receptacle
Gfci breaker keeps tripping
sometimes gfi outlets go bad and trip try testing with a heavy draw machine in it or just replace it and see if this fixes the problem
Jun 22, 2009 | Balboa Instruments Duplex Digital Panel 2...
Sport & Outdoor - Others Logo
1,005 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
