Question about Denon AVR-2307Ci Receiver
HDMI XBOX360 Elite -"No Signal"
I just got my XBOX360 Elite back from repair by Microsoft (RRoD). I hooked it up to my Denon HDMI in and the TV (Samsung 50" Plasma 1080i) cannot see the signal. I switched my HDMI TV connection with my xbox360 input and the Denon reconized the TV, but again, not the Xbox360. I swapped HDMI cables and again the Denon reconizes the TV input but not the XBOX360. I connected my XBOX360 directly into my Samsund 50" Plasma and it reconizes the Xox 360 sound and video fine.
So, what is preventing my Xbox360 from being reconized by my Denon AVR-2307CI? My Denon is 13 months old.
  • Anonymous Oct 25, 2008
    He too and microsft want charge £60 for a repair what a joke
  • Spit51 Jan 08, 2009
    Solution: The problem was my XBOX360. It was my second one and it failed after less than five hours of use. On the plus side, Microsoft has been very supportive about the warranty after the failure has been confirmed.
  • 43 Answers
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Posted on Jan 06, 2009
No sound coming out of speakers tuner or cat/tv
Please add details of setup so I can help you. For example. My Directv box hooks into my HDTV HDMI. Sound is carried inside that cable. I then get sound on my TV from my Directv RCVR without any other hookup. But I do have more. I use an optical cable to go into my Denon 1312 TV/optical input. Since my Wii, PS3, VCR, and formerly Xbox360 all plug into the HDTV inputs and I use it to switch. The Denon is not HDMI capable so this is best for me.
This is the first thing I would try. hook the HDMI to your HDTV from the CATV/SAT box and turn up the sound on the TV. [Box and TV on and correct input used] If you hear audio, the hook it back up as before. Now, turn on the Denon to radio. and turn it up. Got sound?
NO: check speakers and speaker setting. Let's say you have speakers hooked to A but not B. is the selector on B or AB. That won't work. It has to match the hookup. If speakers are on A only, select A only, etc. Also check with known good speakers. Also check all cables to be plugged into the correct spot and plugged in fully.
Thanks PM me if you need more help.
Aug 07, 2014 | Denon AVR-1601 Receiver
I am trying to hook up my apple tv to my pioneer elite plasma, but I only got video, no audio. So, I thought maybe is should hook my apple tv to my den non amp, here I didn't get either, video or audio....
Look for an audio out on your TV to connect a cable from it to your Denon. You say your TV has no speakers then you say they are built in? which is it? If your TV and the Denon have an HDMI port, use an HDMI cable to connect the two.
Nov 29, 2017 | Denon Audio Players & Recorders
Hi, I've had my xbox 360 elite console for
might want to check the cable, if you are not getting light from the xbox360 most likely you have changed something on the TV. make sure its on the right setting
HDMI device has to be on first in some cases.
make sure the plug is good and well connected.
restart the xbox360 and try again.
try the xbox on another hdmi device to see if it working.
or try the regular mode of the xbox.
May 26, 2010 | Microsoft Xbox 360 Elite Console
When i hook up my Bell 4100 Sat receiver to the Aux 1 in, i receive the sound but no video. I have tried using all sorts of combos, s-video and yellow video cable. The tv is hooked up witrh HDMI from the...
Thanks for clarifying that for me. The simple answer is the Denon home theater isn't able to convert the signal from your Bell receiver into an HDMI compatible format. You'll need to use either S-Video or the regular yellow cable to connect your Home theater to the television. The HDMI out provided would only work for the internal DVD player. This is a limitation of HDMI, not a problem with your home theater. You need HDMI in (or DVI in) to get HDMI out.
May 02, 2010 | Denon S-301
Denon AVR-2807 HDMI out signal
i seem to have a similar problem with my Denon AVR 4310CI . The output to my LCD TV just went green . On checking with some people , they suggested resetting . it didnt work . Any probable reasons
Feb 06, 2010 | Denon AVR-2805 Receiver
No picture when hooking component through receiver. Get sound but no picture. Tried to put ps3 in input 1, 2 and 3. Tried multiple cables as well
with Denon you have to go into the menu and "assign" the inputs.
You have to select if you are using HDMI, s-video composite etc.
If your unit has upconverting remember that it will upconvert a s-video signal to HDMI but not the other way around.
HDMI is a digital signal composite, s-video etc are analog therefore you could not use the HDMI output from your PS3 but then use the red, blue green composite outputs from your receiver to run to your tv.
Dec 29, 2009 | Denon Televison & Video
How do i use a hdmi cable on my xbox360 elite
Purchase an HDMI cable, connect one end to the back of your 360 elite, connect the other to the back of your television. Power up your 360. If there are other issues, please let me know and I will do my best to assist you
Nov 16, 2009 | Microsoft Xbox 360 Elite Console
Is it possible for xbox360 hdmi to connect to the hdmi of laptop?
If there is the same number of pins and you can find the drivers for it than it could be possible.
Jun 11, 2009 | Microsoft Xbox 360 Elite Console
Best way to hook up all my componets
The best way to use the Denon and get your money's worth is to connect all devices to the Denon using HDMI connects if possible, if you use HDMI make sure you assign the audio if needed.
HDMI from Denon to TV. the Denon will upconvert all signals to HDMI to the TV
Jan 29, 2009 | Denon AVR588 Receiver
Xbox 360 hdmi cable
Make sure both the xbox and tv are on and tv is on HDMI source. It won't recognize each other unless xbox is turned on and tv is set to the correct source.
Sep 24, 2007 | Microsoft Xbox 360 Elite Console
Open Questions:
Denon AVR-2307Ci Receiver Logo
3,435 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
