Record and watch different channels with freesat
Being trying to find an answer to this question,If you use a Humax HD Freesat set top box,can you record one channel,watch another channel at the same time using LG RHT397H Digital DVD Recorder + HDD RHT397H model
thank you
  • Anonymous Mar 29, 2014
    Sound has stopped working on hd channels
    Sergeant:
  • 196 Answers
I believe that the Humax can only output 1 channel and because it has no built in hdd and twin channel capabilty that is all you can record 1 channel (unlike sky +/sky HD) so that means also that unless you watch a different source (like the picture from your aerial (terrestial channels)) you are stuck with having to watch the channel you record
Posted on Oct 12, 2008
Freesat box keeps freezing when you put TV guide on
Go into Factory reset, but before check if your system download is up to date, ( in menu )
Aug 10, 2014 | Humax Televison & Video
Freesat oneforall
Check whether it has setup codes to Humax Freesat. If you wish to get more details, check these sites. http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 30, 2013 | One For All URC 7740 Remote Control
I want to use my tevion remote to operate humax freesat box? i dont know how to use it
You will need the correct set up code to link the remote to the freesat box.
try this website http://www.xdiv.com/remotes/
Feb 18, 2011 | Televison & Video
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Dec 29, 2010 | Samsung Televison & Video
Hi,i have a humax hdr freesat box connected to ext-6 via hdmi cable.every thing works fine on bbc1 hd,but on the other hd channels, all i get is a green screen.any ideas please?
have you used a satellite finder for maximum signal and searched the internet for the angle at which you need to align your satellite dish?
Dec 26, 2010 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Can i set up my blu ray recorder DMR-BS750 without
The purpose of that freesat to bo able to record/playbak 2 channels at the same time. But you still need a satellite dish pointing to the satellite in the sky so it can work.
Jan 13, 2010 | Panasonic Televison & Video
I am about to receive an LG32LF4700 Freesat/HD TV If I disconnect the SKY Box and connect the TV direct to the Dish cable will I receive Freesat HD channels. Also can I connect an extra bedroom TV into the...
Yes you can split the signal out from the back of the Freesat/HD (not the TV)to the second TV.
Look what outputs are on the Freesat box - the RF (standard cable) output should go to the 2nd TV (TV set to CH3) and the a/v cables,HDMI or DVI cable should go to the new TV - Note:To receive HD the output from the Freesat should be either HDMI,DVI or Composite output (RGB video jacks) with red White for audio. If you have HDMI this is best - it also provides audio.
Oct 28, 2009 | LG 42LC2D 42 in. LCD HDTV
No sound on hd tv thru freesat
HDMI to DVI adaptors do not always support audio.You have to run seperate audio into the TV.
Jan 12, 2009 | Televison & Video
Freeview/Humax/Freesat
No you cannot record on to your pvr in HD, and yes you will have to wait for an HD-pvr unit. This is because of the HDCP agreements.
Jun 16, 2008 | Televison & Video
Televison & Video Logo
320 people viewed this question
Top Televison & Video Experts
