Question about Garden
Soleniod do it mater now the soleniod is wired can it be turned any way?how do i wire a riding lawn mower i dont know which way to turn the soleniod
  • 48 Answers
It doesnt matter how you turn it starter to large terminal battery and charge wire to other large terminal key wire to small terminal
Posted on Oct 17, 2008
I have a sabre garden tractor that keeps blowing the fuse for the ignition i found no bare wiring anywhere.
The only reason a fuse blows is because it got overloaded(too much amps). Most lawn/garden tractors use separate soleniod for the starter and you said it blows a fuse as soon as you turn on the key. At that point the starter wouldn't(or shouldn't) have any current to it at all. A stuck on soleniod would keep the starter engaged till you unhooked one of the battery cables. Find what that fuse protects in electrical system and start looking for bare wires, maybe a wire has rubbed through where it's laying against metal
May 13, 2015 | Garden
Replaced starter dont remember how wires go back. the large red small red and the blue with the female slide on wires i know where they go but the larger blue one with the o shaped end i not sure if it...
you will have 3 or 4 wires to the solenoid. it sounds like you know where the 2 small ones go so the other 2 are for the battery and starter. one side of the solenoid will have a wire from the battery and the other side will have a wire to the starter. these 2 wires are larger because they carry the amperage required to turn the starter.
Apr 16, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Yardman mower
Try this. Disconnect the one single wire going to the solenoid. Use an ohm meter to see if there is 12 volts DC at this wire when you turn the key switch in the start position. If you have voltage then your solenoid is bad and needs to be replaced. If you dont have voltage, check the safety switchs for proper operation.
Apr 27, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
When i turn the key the lights turn on but no clickling or anything. checked fuse that is good so not sure what it could be. lt 1050 lawn tractor
most likely a bad soleniod,turn the key on and cross the 2 cables on the soleniod,it should start
if so you need a nwe one
Jul 26, 2011 | Garden
Cant find a wiring diagram for my 17hp briggs and stratton 42inch cut yard machine lawn tractor it will not turn over with key i just got it cheap but have noticed three wires that are cut but dont seam to...
Try going to:
This download is free.
Most owners manuals have a wiring schematic diagram page in them. You will need the model # on this site to check for an online operators/users manual. Most REPAIR manuals on the net are either book or CD and are not free.
Aug 29, 2010 | Yard Machines 155 Torque Briggs Stratton...
Will not start fuse ok battery ok they said try new starter, its ok turn key on hear click Sound sounds llik up at carberator, AMP gauge gos negetive and starter will not ingage, belt for mower is...
I would try to jump the starter. Pos cable on the starter then ground out the neg, it the starter turns over that isnt it. then check the smaller wire going to your soleniod, when you turn your key to the start position it should have power. then check to see if there is power from the battery to your soleniod then with the key turned power from the soleniod to the starter.
Aug 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower clicking noise - wont start
May 22, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Clicking sound from rider when trying to start
try moving the fly wheel, if that dont help pull the stater off but leave it hooked up to the hot wire and turn the switch on and spin the starter over
Aug 16, 2009 | Champion International Champion& Small...
Either the igniton is bad or the wires are backwards. You can bypass the ignition and touch the wires together to see if the solenoid turns. You can also use an ohmmeter/voltmeter to check the current.
May 22, 2009 | Mtd Garden
Garden Logo
193 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
