Question about Linksys Wireless-G WRT54G Router
Program issues I went under sevices in the control panel under admin tools and did not see the wireless zero instead there is a spot that says wlanauto config its directly under wired auto config and right above the wmi performance
  • Linksys Master
  • 4,338 Answers
You may in the wrong section.
Go to :
Control Panel
Administrative Tools
Click on the Services shortcut.
Then scroll down to the 3rd item from the bottom.
Wire Zero Configuration
Make sure that it is set to automatic,
Then click on Start.
Posted on Oct 12, 2008
Too many unnecessary programs are running at start-up
try this.
click start then control panel. then go to admin tools. under admin tools click system configuration then click start up. uncheck whet you do not wish to run.
you can click start then in the run box type msconfig.exe
Mar 21, 2014 | Microsoft Windows Vista Home Premium with...
D link adapter losing signal
Wireless Zero Configuration is a Windows service on Windows XP and Windows Server 2003 that is used to configure and manage wireless network connections on a wireless adapter. The service name for Wireless Zero Configuration is WZCSVC. On Windows XP, the display name for the WZCSVC service is Wireless Zero Configuration. On Windows Server 2003, the display name for the WZCSVC service is Wireless Configuration.
The Wireless Zero Configuration service is normally started at boot time. The programming interface for the Wireless Zero Configuration service can be used only if the Wireless Zero Configuration service has been started. If the Wireless Zero Configuration service is not started, then the Wireless Zero Configuration functions will return an error.
To enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
The Wireless Zero Configuration can also be started and stopped from a command prompt. To start the Wireless Zero Configuration, run the following command:
net start wzcsvc
To stop the Wireless Zero Configuration, run the following command:
net stop wzcsvc
Apr 10, 2013 | D-Link Computers & Internet
Ibm thinkpad r40 windows xp-pro after formatting and re-installing the system, all updates and SPs downloaded and installed, the wireless "disappeared"! the radio led wouldn't lit, in the connection list...
if drivers installed device is looking for wifi manager which is the software package for wifi.
you can goto control panel open administrative tools select sevices and scroll to wireless zero config and press start.
this will then use windows settings.done
Jan 24, 2009 | IBM ThinkPad R40 Notebook
Wireless Connecion Help Wont Show
check in device manager to see if its enabled and have drivers installed.some wifi are installed without a wireless manager and connect to first available(strongest)network.
go into control panel ,administrative tools,sevices and scroll down to wireless zero config and start.
then when you click on wireless icon you will have choices of connections(AP'S)(access points)
Jan 12, 2009 | HP Pavilion dv1000 Notebook
Have XP operating system, Comcast service, Airport extreme router and a Linksys wireless N antenna. Windows say: Cannot configure this wireless connection. What's wrong?
another program is using the wireless utility, you may find this program in start menu / programs / ... open this program and you will be able to connect to your WLAN - also check your tool bar near the clock - an icon for the WLAN may be there,
if you would like windows manage your wireless you may need to enable the wireless zero configuration service within admin tools / services
Nov 30, 2008 | Computers & Internet
Program issues
You really don't need to install the Linksys cd. Let windows control the wireless with "wireless zero configuration" I install these almost every day.
First reset the router. Hook it on a computer with a Cat5 cable. Then go to in the browser adress fiels. Log onto the router. the default password is admin with no username.
Once in the setup page, go to wireless . There set the SSID (the name you want your network to be)
Then on the security tab, set your encryption key.
Then restart your wireless computers. Click on the wireless icon. click on view all wireless networks. You should see your network there. click connect and put your key in twice. You should be able to connect wirelessly ok.
If "wireless Zero Configuration " is off, go to:
Control Panel>Administrative Tools>Services. Scroll down to Wireless Zero Configuration and make sure it is set to automatic and that it is started.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 12, 2008 | Linksys Wireless-G WRT54G Router
Network Controller?!
try to check whether there are two program trying to run your wireless connection. by default, windows program is running for your wireless connection. if your wireless card have a separate program try to close or disable the windows wireless program. go to your control panel then to administrative tools then to services then double click on wireless zero then select disable on the drop down box and stop the operation then apply. restart your computer.
Jun 26, 2008 | Acer Aspire 4315 Notebook
Belkin f5d7132uk keeps disconnecting
have you tried turning off Wireless Zero Configuration
Go to Start | Control Panel | Administrative Tools | Services
Scroll down to Wireless Zero Configuration, right clicking properties, and Stopping the service in Service Status.
Do this on all the Pcs,
If this solves the problem, turn off Wireless Zero Configuration permanently by changing Startup type to Disabled
Dec 09, 2007 | Belkin (F5D7230-4) Router (587009)
!!!HEP!!! Zyxel M-302
Have you tried enabling the Wireless Zero service? In Control Panel/Admin Tools/Services, scroll down to Wireless Zero and enable it. Some cards use their own interface, some use Wireless Zero. Do you have Wireless Icon showing in the System Tray? You should be able to access the settings by Right-clicking this icon.
Jun 29, 2007 | Zyxel M-302 (M302) 802.11g/b Wireless...
Set up...
Some laptops have a switch that must be toggle for the wireless to work. Check Control Panel/Admin Tools/Services to verify that the Wireless Zero Config is running.
Jun 10, 2007 | D-Link AirPlus DI-524 Wireless Router
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
