Question about Maxtor Hard Drive
Jumper settings i need the jumper settings for model number 91020D6
  • bowleggs2 Feb 07, 2009
    i have a maxtor h driver model 5t040h4 how can i set it to slave
Lcd flutter ln-46c610
You might want to call Samsung with the model number as I remember seeing a notice for certain models that have this issue---a jumper plug needs in those sets to be removed that is located on the power board.
Apr 30, 2012 | Samsung LN46C610 LCD TV
I could not set the jumper ID as 3 in Seagate 73 GB model of Hard drive.It has 12 pins at the back of Hard drive.
You need a jumper on ID pin sets 1 and 2 (as if you were setting it for both ID 1 and ID 2)
These pin sets work like binary, so set 1 for ID1, set 2 for ID 2, and sets 1 & 2 for ID 3. In this mannar, with just the 4 sets of pins, you can have IDs from 0 to 15 (no jumpers to all 4 jumpered..1+2+4+8=15)
1234 set number
1248 binary ID (additive)
If you need further explanation, please post a reply here.
Feb 24, 2011 | Seagate Hard Drive SCSI 73GB 10000RPM...
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
P4gv-mx/s i need the jumper settings lost my manual
Hello. The model number you gave doesn't seem to be listed. They do however list this one: P4BGV-MX. If this is correct the manual can be found at:
P4BGV-MX Manual
Jumper settings begin on page 1-10.
Thanks for using Fixya.
(Note: If this is not the correct one, please use the Comment button to reply.)
Aug 28, 2009 | ASUS Computers & Internet
I need jumper setting for a Maxtor Mode. #
Try this site, just locate your paticular model number for diagram. Hope this helps.
Aug 17, 2009 | Maxtor Computers & Internet
I need to know how my jumpers go
Use the dropdown menu on the above website. Select 'Motherboard' for product category, Socket 478, and select your model number, P4VMM2. Then select your version number, which should be found directly on your motherboard, and click 'submit' This will begin the download for your users manual, which should illustrate the default settings for your motherboards jumpers.
May 14, 2009 | EliteGroup P4VMM2 Motherboard
Maxtor slave jumper settings
Find the jumper settings for the maxtor harddrive on the following link. As per the model number you gave ,it seems like you have the maxtor diamond max drive.
Nov 29, 2008 | Maxtor Hard Drive
Samsung hard drive model number
if this is a samsung, on the actual HD, you will see the jumper labels like the one below.
Usually it will say:
M = Master
S = Slave
Cs = Cable select
but if it is not visible anymore and you have 4 sets of pins, then the slave may either be the 3rd or the 2nd if you are looking at it from the back.
if you have other questions just let me know.
Oct 02, 2008 | Samsung Spinpoint MP0402H 40 GB Hard Drive
Compaq presario 5340 motherboard jumper setting
search for the manual on the net.use its model number placed near the cpu socket.
May 22, 2008 | Compaq (252608-001) Motherboard
Jumper settings for an older maxtor hard drive
Support can be found at in case this is not the exact drive. The model number you listed was not an exact match.
Nov 25, 2007 | Maxtor Hard Drive
Maxtor Hard Drive Logo
167 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
