Question about Dell M570 15" CRT Monitor
Stretched Image Just got a new monitor and now my images are all stretched sideways. Both monitors are Gateways but they are different shapes. Did I buy the wrong thing? If not, what can I do to correct the problem?
  • MsPrint Oct 12, 2008
    Unfortunately that didn't help. On the side of this new monitor there's a menue... When you press it info is displayed on the screen. But there isn't any Select button (+) and no Adjust button (-). Now what??? (Btw, I tried every option with the menu and I can't figure it out.)
    Thank you for your help, though!
    If I could just find the word "resize" ANYWHERE I'd try it. I'm at a loss here. I will check the cable connection but I have a feeling I'm gonna hafta find a local geek! Thanks so much for your help, k.
  • 94 Answers
The problem is just the monitor settings. To reset the monitor, just press the Select button (+) and Adjust button ( - ) on your monitor at the same time.
Posted on Oct 12, 2008
  • kagebunshin Oct 12, 2008
    Did you try adjusting the settings on the monitor..like resizing it? Also kindly check the cable connected from your monitor to the CPU. Check for broken pins..this will cause problems on the image.
Screen image is stretched or smeared
I had that problem, after awhile of using mine, the words would appear to be streaking. I bought a new monitor.
Feb 19, 2014 | Gateway FPD1975W 19" LCD Monitor
Desktop icons stretched horizontally
Sounds like you need to set the screen resolution for the monitor. The computer should recognize each screen individually in the desktop options dialog. If it doesn't recognize the two different screens, you may want to change the resolution when you plug in the monitor.
May 14, 2017 | Computers & Internet
ASUS P4SP-MX detect the new LCD monitor VH197D as an CRT. picture is stretched; circle's becoming a ellipse. Can you help me!?
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Feb 21, 2012 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Image stretched widthways
Hi
Depending upon your operating system: Right click on an open area of the background screen. The goto to settings or display settings. From here you're going to want to change the display resolution or display size to match your monitor. Experiment with the different sizes until you get the one that's right for you.
May 13, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
The LCD monitor has different image proportions from the old CRT monitor and all my images are stretched. How can this be corrected
go to your desktop and right click. select properties. choose the settings tab. resize you image. easy to do!!!
Dec 30, 2009 | Computers & Internet
Image stretched
No offense, but if you're an IT ignoramus, you should know how to fix this. I see you said 2 monitors, did you see that you could've added display to the second monitor making it look out of proportion? A simple fix is either adjust resolution, disconnect second monitor, or you could do the hardest one, test every single component related to display until you find the problem. Good luck with the last one,if you come down to it.
May 07, 2009 | Dell Computers & Internet
Photographs do not look normal on this monitor.
this is not monitor dependent. It depends on the graphics software that you use, try to keep your proportions locked with your graphics software.
example when you want to increase the size of an image drag it from a corner and not from the side.
Mar 24, 2009 | Star Computers & Internet
Acer AL2216WBD LCD Monitor Problem
If your computer does not have a video card that supports the correct resolutions for the widescreen monitors, then your picture may get stretched. Much like watching normal tv programs on a an hd set. It will eitther strech or cut off the picture.
Try different settings in you computer display settings.
Fran
Sep 09, 2008 | Acer AL2216WBD LCD Monitor
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
Dell M570 15" CRT Monitor Logo
149 people viewed this question
Alun Cox
