Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Fix bar brake on homelite timberman 45
Brake is not releasing
  • sdk481954 Nov 23, 2008
    brake band seems to tight
  • freesteamin Feb 04, 2009
    My Homelite Timberman, 4 yrs old, lightly used, is having the same problem. Was working fine then all of a sudden the brake bound up and wouldn't release. I've taken the mechanism apart and can see why it's binding but so far I can't figure out exactly what is broken or how to fix it. I am also considering just pulling out the brake band and using it without the brake. Never had one before on all the saws I've used for the past 45 years and haven't had a problem yet. My saw also continuously leaks bar oil slowly when not in use so I'm not too happy with this saw.
It's a design flaw in timberman chain saws. After some hours of use, they develop a bad habit of not releasing the clutch drum completely. And that takes precious power away from the saw. If it becomes too tight, the clutch drum may over heat and cause the plastic enclosure to warp or melt down. After messing with this brake for months, I ended up completely removing it. Replacing it was not an option for me - there was nothing to replace - it is not the brake band that's bad, but the mechanism in the brake handle of this saw that is flawed. Overall, this chainsaw is very cheaply built - Homelite used waaaay too much plastic in it!
Posted on Jan 05, 2009
If the plastic ***'s that hold the spring perfect are worn buy a new body or run without the brake
Posted on Mar 15, 2009
  • 211 Answers
Hi
Remove the parts to reach the brake mechanism..Check the parts(band brake,spring and others).See if they are in good conditions(tighten or broken).Try to find out how the brake mechanism works.Wish you luck.
regards savumihai71
Posted on Dec 09, 2008
Homelite Timberman 45 chainsaw runs fine but will not idle. Ideas?
dirty carb specifically in the idle jet turn it in till it bottoms . do not force more then return to the same place it was set if 3/4 turn in turn out 3/4 see if it works better .
Feb 16, 2015 | Homelite Garden
I have a homelite timberman 45 that starts and runs fine,but at high rpm it bogs down, like it's starving for fuel, what could it be?
You may adjust the High adjustment screw on the carbarater most of the time carbarater needs to be rebuilt.
Nov 22, 2014 | Cars & Trucks
Can you email the page on how to tighten the chain on timberman 45 model...lost my manual. thks Dennis draralbee@msn;.com
This page will help. You may not find your exact model but just find one thats close
Good Luck and BE SAFE
Follow link below cut and paste in address bar
http://lawnandgarden.manualsonline.com/manuals/mfg/homelite/homelite_chainsaw_product_list.html
Feb 07, 2011 | Homelite Garden
My Timberman 45 was in storage a long time, now have it out to use on downed trees. I can't seem to keep the chain tight enough, longer than about 15 minutes. Tricks or suggestions? Thanks.
I would remove the chain and give the guide channel a good cleaning. Use a small blade screwdriver to clean all debris and old bar oil and sawdust. I spray mine down thourghly with WD-40 and wipe dry. I would do the same with the chain to make it has not gotten a little rust on it during storage. Tighten snugly,run for five mins. then recheck and tighten again if needed > If you're still having problems I would try a new chain. Hope this helps.
Nov 22, 2010 | Homelite Garden
Auto chain oiler doesn't work homelite temberman 45
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
Timberman 45 does not cross to an IPL I can find. If you can find an IPL it really simplifies disassembly/reassembly, provides component locations and component part numbers. Without the correct IPL I would not undertake a repair.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 13, 2010 | Homelite Garden
I have a Homelite timberman 45. It won't idle.
been out fighting 2 saws today,r+r lines filters one problem on 1 saw same went from 50/1 to 30/1 quit over heating and evaporating gas,, pulls easier fires an pulls chain well on big cuts//used 50on two cords cool day last year today 80+ over heated
Mar 21, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Loose chain on my 18" timberman
You should have a wrench to fit the hex nut on the side where the bar is. Get a pair of gloves and loosen the nut, on the inside of the bar you will find a screw head that is the adjustment screw, while holding up on the tip of the bar tighten the screw and periodically roll the chain. Lift up on the chain until the bottom of the teeth just about show, release chain and lift up on bar again and SNUG hex nut again checking the chain as above, when satisfied that the teeth are just about exposed tighten the hex nut and roll the chain to ensure that it moves freely. That is it. Let me know if you need anymore help
Feb 18, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
2,353 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
