Heating & Cooling Logo
Posted on Oct 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Parts for a model AF-S125NX Air Conditioner - Sharp Heating & Cooling
Anonymous
Level 3:
  • Master 750 Answers
  • Posted on Oct 12, 2008
Anonymous
Master
Level 3:
Answers
750
Questions
0
Helped
491056
Points
2063
Hello gibbonsbtaza,
Welcome,
You said you need ,Parts for a model AF-S125NX Air Conditioner.
Go to this site and this will solve your part problem for good parts
www.RepairClinic.com
Find this site online ,RepairClinic
Thank You for using Fixya.
Huuum
Please remember to leave a solved rating .
2answers
Where do I add water to an amcor MF8000E?
To add water to an Amcor MF8000E, locate the water tank compartment on the unit, usually at the back or side, and follow the manufacturer's instructions to fill it with water.
1helpful
Where can I get a mounting kit for this product? Frames and side panels
Try e-bay or Amazon.
For the part numbers and descriptions, try entering your model number into "Sears Parts Direct".
They will sell the parts if they list them, also.
God bless your efforts.
How much Sharp AF-S120FX Air Conditioner?
The model number you listed has been discontinued by Sharp. So, getting an accurate retail price is difficult. I did see one online marked Clearance for $269.00. But be careful buying discontinued models, as the warranty may only for a short period of time. Also, customer ratings/opinions on this model, dating back to 2005, were not good.
Hope this helps you and thanks for choosing FixYa.
1helpful
We need a replacement filter for our Sharp Air Conditioner Model AF - S60DX.
Karen, even though your model has been discontinued, you can still get a washable filter replacement for you AC Unit. Most hardware stores and home improvement stores sell a washable, mesh filter kit, that can be cut to size to fit your unit and hundreds of others. You'll probably have enough left over to make two filters, if necessary
I hope this helped you and thanks for choosing FixYa.
How to put in freeze on in my air conditioner af-r509x
Here is a tip that I wrote about how to add refrigerant to a air conditioner orcooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
4helpful
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
18helpful
Ac shuts off E1 error message
E1 Error Code -->> Clean Filter
Owners of Sharp air conditioner models AF-S60FX, AF-S80FX, AF-S85FX, and AF-R80FX may experience the following (highly annoying) issue. After 720 hours of fan operation, the error code E1 will appear on the seven segment LED temperature display. This error code is intended as a reminder for the user to clean the air filter. However, because the procedure outlined in the user manual does not clear this error code as indicated, and the appliance has a nonvolatile memory that cannot be reset by simply unplugging it, the user of the appliance will become mightily frustrated, standing in potentially sweltering heat watching the appliance repeatedly shut down in the midst of operation with the "E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the "E1" code from the display, and plug it back in and re-start it, it will simply run for anywhere from a few minutes to a few hours, and then merrily shut down again with the same flashing "E1" code.
Many people at this point, having put the manual under the canary or some such, will simply return the unit and never buy another Sharp air conditioner. But for the tech-savvy and search-adept, I offer the following procedure to clear the nefarious E1 indication, and obtain another 720 hours of cooling bliss:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above exactly.
If you doubt the veracity of this information, or it does not work as expected, you can get it directly from the source at: 1-800-237-4277 (Sharp customer service line). You'll need to call between 7 AM and 7 PM US Central time, and have your model number and serial number ready.
AF-S80MX Thru-Wall/Window Air Conditioner: What kind of refrigerant does this unit uses? ...
Most new window units are using R-22 or it's most common alternative R-410A - but you will need to check the 'data tag' on the AC to be sure. All AC units have a data tag (either metal or paper label) - somewhere on the AC - which gives you model number, size, voltage, and type of Refrigerant, as well as other info.
good luck!
Top Sharp Heating & Cooling Experts
ZJ Limited
ZJ Limited
john h
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
