Question about Logitech X-530 Computer Speakers
No sound from Creative Labs Speakers- Please help
I have recently been having a problem with getting sound from my surround sound speakers. They are CREATIVE LABS 5:1 surround sound and I used them before and they worked fine on my computer.
I think the problem started when I rebooted my computer because of a virus but I have re-installed the sound drivers for my Dell Dimension PC and normal dell speakers work fine, there are generally no sound problems at all only when I plug in my surround sound speakers.
The weird thing is, when I plug earphones into the the volume control unit for the speakers I can hear sound, just nothing from the subwoofer or satellite speakers.
I have done all the usual stuff like change control panel settings for my sound card to 5:1 and tested the speakers. But still nothing works. Like I said, I used these before and now they dont work!
Please help :(
  • johnvier Jan 21, 2009
    there is no sounds coming from speaker .. neither in earphones
  • 3 Answers
To localised your problem, try to plug your speakers to other sound source like mp3 player ,stereo system. if still no sound coming from it,your problem is within the speaker system. perhaps the audio power amplifier ic inside, need to be replaced.
Posted on Oct 20, 2008
Connect creative 4.1 speakers with laptop at time 2 speaker work
i assume ur mother board supports surround sound an ur using windows os. go to control panel - sounds and audio devices - speaker settings-advanced - speaker set up with the drop down menu. select surround sound - apply - ok.
if ur using surround audio drivers like realtek, etc. the settings console should have somewhat similar options like audio input/output (I/O) options. select surround sound speaker setting and configure which audio port should be audio output ports. driver settings can be accessed from control panel too. to access control panel click on start menu there u'll see the control panel menu.
Mar 13, 2010 | Creative Labs Audio Players & Recorders
Reply...
Creative Sound Blaster X-Fi Surround 5.1 will be the best option as creative soundcard worls great with creative speakers....
Jul 27, 2009 | Creative Labs Inspire T6100 Computer...
Not enough jack
You need to buy an external sound card, without which you will not be able to get much from your speakers. It will not produce surround sound.
The sound card will give you required jacks and will produce real good sound. You may try audigy cards from creative.
No sound from rear speakers Creative t6100
Try this:
Go to Control Panel >> Sounds and Audio Devices. Click on Advanced button under Speaker Settings and for Speaker Setup select 5.1 surround sound speakers from the options. Click Apply >> Ok and then check.
Mar 29, 2009 | Creative Labs Inspire T6100 Computer...
SOUND OUT OF 2 SPEAKERS ONLY
Hi there
have you went to sounds and clicked on the speakers and scrolled down to the surround sound or the quadraponic setting, and also by changing to different speaker advanced settings you should be able to get the other speakers working ok
best regards mike
Mar 23, 2009 | Creative Labs Inspire 4400 Computer...
I have a creative audigy Creative Labs Sound Blaster Audigy 2 Sound Card and Creative 7.1 surround sound speakers. When I was using XP all 7 speakers worked perfectly. Now with my newer Vista machine,...
Uninstall all sound drivers for the card. Delete all folder and use search to locate everything related to the sound card. Remove card , turn comp on w/o card. Turn off reinsert card.
Should fix it.
Vista has many,many issues like this.
If you have more types of sound listed in "SOUNDS" delete all but Audigy.
Re-install drivers AFTER you get ALL NEW VISTA UPDATES>
Mastersage
Feb 18, 2009 | Creative Labs Sound Blaster Audigy 2 Sound...
I had bought new creative inspire m4500 but instead of four only
I found the solution to my own problem.
(First install the software that is provided in the form of a CD with your SoundBlaster. I had to buy a 5.1VX Creative Sound Blaster for my Creative Inspire M4500 4.1 speakers.)
Go to the folder ‘Creative’ which you may find in your Program Files.
Then double click on the following one after the other:
Creative
SB5.1VX
Surround Mixer
SurMixer (SurMixer.exe)
Now go to EAX.
Select CMSS 3D.
Check on the box ‘Enable CMSS 3D Surround.’
Select ‘Stereo Surround.’
Hope your problem is solved now:))
Feb 16, 2009 | Creative Labs Sound Blaster Live! 5.1...
Creative speakers 2.1 Deteriorated sound quality
Yes.speakers like all the other computers parts need to be maintained very well.dust can deteriorate the sound quality.Regular servicing might help out to get the original quality.Else you can do it on your own by cleaning with a normal hand brush.Hope this helps you out.Please do rate If this could solve your problem.
Sep 12, 2008 | Creative Labs SBS 330 Computer Speakers
Sound effects
search in the soundcard software for a place where you can choose stereo 5.1 6.1 ect
go program files and look for the folder creative in there ther is like a file named somethig like creative console its in there the stereo option!
Jan 10, 2008 | Creative Labs Sound Blaster Live! 5.1...
Logitech X-530 Computer Speakers Logo
758 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
