Question about Kenwood KAC-7202 Car Audio Amplifier
KAC-7202 Major feedback after a few minutes of running.
Ford Escape with premium sterio. Added KAC-7202 and worked fine for a while. Now after a few minutes, the subwoofer gets najor feedback and won't stop until the sterio is turned off.
  • 113 Answers
You might try unplugging the wires from the sub, turn it back on with the wires disconnected- if the noise comes back the amp is probably bad - if the noise doesn'tcome back -turn your head unit off and reconnect the sub- if the noise comes then your sub's voice coil could be shorted- if the noise comes back you should try a different speaker to compare- if the noise still there with the test speaker your problem is definately the amp.
If these suggestions don't help please e-mail me at Merle840@aol.com i will be glad to help. Please give me a good rating if i have been able to help you M. MERLE
Posted on Oct 13, 2008
Kenwoood kac-7202 redlight/no output
you blew the output Ic's (amps one or more ) you can fix this by replacing the output IC's
Jan 29, 2014 | Kenwood KAC-7202 Car Audio Amplifier
I have a kenwood kac-7202 and it keeps blowing the in-line fuse
Are all the wires hooked in right? On the bare parts of the wires, are there any 2 wires touching? Most importantly, do you have the correct fuse for the stereo?
Oct 11, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Where do i connect the power control wire to ? I have a kenwood amp kac 7202, I'm connecting it to a stock cd receiver in toyota corolla 2004
Hello sophnettliss,
Most stock receivers do not have a dedicated amp remote lead and your 2004 Corolla is no exception.
The amp remote can be connected to any switched and fused 12V + source including the OEM receiver accessory wire which is the gray wire in your receiver harness.
Hope this helps.
Oct 02, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Kac-7202 flashing power light
ALL THAT IS A WASTE OF TIME AND YOU MAY HAVE CAUSE MORE DAMAGE TO THE AMP,THOSE AMP WILL FLASH WHEN THERE IS NOT ENOUGH POWER SOURCE EITHER GROUND,OR LOW VOLTAGE REMOTE OR TWELVE VOLT SOURCE CHECK ALL THOSE AND MAKE SURE YOUR HAVE RIGHT SIZE SPEAKERS THAT CAN HANDLE THE LOAD FROM AMP
Aug 07, 2009 | Kenwood KAC-7202 Car Audio Amplifier
05 ford escape wont start. jump started it and it started fine but only runned for a few minutes and the engine started to stall and went off. tried to start it again and it wont turn with the same...
okay try this....talk to your parts store and get a battery load tester, and find out if the battery is indeed dead. My guess is it sounds like the Altenator is dying. they are around 50-100 and can be install by a pro in minutes.
Jun 16, 2009 | 2005 Ford Escape
KAC-7202 will not put out sound. Put in other amp works.
When you switch on the amp did the main amp ic produce heat. If does not change the main amp ic.
Feb 13, 2009 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood kac-7202 wirng 4 subs
look at the Z [impedance] specs for the amp. Look at the Z for the speakers. You may eventually have to wire them in a series-parallel config or risk blowing your output transistors.
Due to the utilization of so many drivers, your power demands are limited. The more drivers you utilize, the more volume loss. Bass response requires a lot of power (W) in which to drive.
Do not worry about paper or polyprop/carbonate structures... focus on your impedance issue or risk frying the output transistors in the long run [thermal runaway].
Oct 15, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Kenwood kac-7202 amp
150/ch into 4 ohms
230/ch into 2 ohms
Spec Sheet
Jan 11, 2008 | Jensen XA2150 Car Audio Amplifier
Kenwood KAC-7202 Car Audio Amplifier Logo
204 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
