Question about GE Monogram ZICS360NRRH C... Bottom Freezer Refrigerator
Glowing light and warm air freezer side
I noticed a dripping noise (similar sound to dropping drops of water on a hot skillet). I looked at where I thought the sound was coming from which is the lower vent in the freezer section. I saw a glowing yellow-orange light and felt heat coming out of the vent. Please help! The temp is set at zero but is ready at 3.
  • tkee4
    tkee4 Oct 27, 2012
    It it normal for the panel on the back (inside the fridge) at the bottom to feel hot to the touch?
  • 943 Answers
HI thanks for your question. you found your freezer in a defrost cycle, which is normal function.the defrost cycle happens every day every 10 hrs. on for about 20 min. then resumes the cooling cycle. so its normal. thanks the appliance doc, please rate my answer. thanks.
Posted on Oct 12, 2008
I heard noise (drop of water hitting very hot item & evaporating) and opened freezer door on GE profile Artica and near lower back something that looks like a round metal piece (spread in a pattern...
Hello, Thank You for using FixYa. I will be helping you today.Yes this is normal..the unit goes into defrost a heating element turns on for about 20 minutes to melt ice off the evaporator which drips onto the heating element and the rest down the drain. Then there is a thermostat that tells the heater to turn off after it reaches about 50 degrees then the heater turns off but the unit will still stay off until some of the heat is gone.Again this is all normal.
Thank You and please rate my answer if it was helpful..
Jun 09, 2011 | Refrigerators
I have an older admiral refridgerator, when you open freezer it sounds like water dripping on a hot skillet. I unpluged it, later pluged it back in and wont come on
The sound was water dripping on the defrost coil...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Dec 25, 2010 | Admiral 26 cu. ft. Side-By-Side...
Our subzero freezer has a new problem. The cubes
Ice cubes WILL BE slightly moist when they land in the ice bucket. they've just been slightly melted in order to eject from the ice maker. Stop playing with the settings, for starters. put them back to normal, i.e., middle setting, place thermometer in center of freezer, and if you can, one in center of fresh food. monitor after 24 hours, and for the next three days thereafter. freezer temps should be in the -5 - +5°F, sometimes up to 10°, fresh food should be 35-40, sometimes up to 44°at the normal settings. If you are not having temperature issues, see if you notice any frozen drips of water on the underside of icemaker, indicating a possible crack in the ice maker mold, or a faulty water valve. You didnt include your model and serial number, so not knowing the path of the ice shoot, some go out the freezer door, some slide over and get dispensed from the fresh food side. Its possible you may have a problem instead with the flapping door that opens to allow ice cubes to be dispensed, or similar type mechanism. If this door does not seat completely when its closed, it will leak warm air directly into the ice bucket, which would make them slightly moist, also too, this warm air can cause frost and ice to buildup near the warm air source...look for any unusual forms of ice and or frost leading up from the flapping door to the ice bucket. Also look for any gaps in the door gasket when closed, this warm air leak can also cause similar problems, but its most likely with the ice door. could be the door, the spring, the solenoid, or something else i wouldn't know without personal refrigerator inspection.
Mar 27, 2010 | Freezers
Kenmore side by side. Noticed water dripping out
please do not use hot water.........only clean drain hole with copper wire with very small cloth on
end.sounds like you left door open? adjust feet to allow door to close itself..if left ajar.
fully defrost.clean drain hole.adjust feet. switch on ...
this freezer works best full....
Feb 04, 2010 | Refrigerators
Whirlpool ET19DKXFW01 water dripping and heavy frost
Hi this sounds like a blockage in the defrost drain. Follow this link to my tips and tricks which will give you instructions on clearing the blockage. If you have any other questions please feel free to comment. Mike
Dec 10, 2009 | Refrigerators
Refridgerator freezer is making noises
Hello, your refridgerator in most likely in defrost cycle. the noise your hearing is the water dripping on the hot heater and ice dropping off the evaporator. should only last 15 minutes and then your all set. Mike
Sep 15, 2009 | Freezers
Water dripping in the freezer We have side by side kenmore fridge and freezer and filtered water. I just opened the freezer and heard dripping of water behind back cover. It sounded as water is hitting...
this IS normall. the freezer is just in defrost cycle. the heat elements are on and defrosting the evaporator. you are hearing the water hitting the elements and running to the drain. this is normall, does it every day, just the first time you happen to notice it. shane
Aug 25, 2009 | Refrigerators
Sound of water dripping on something hot
don't worry about it. there is a defrost heater to melt ice off the evaporator when in defrost mode. happens about every eight hours. the sizzling noise is water dripping on the heater
Sep 25, 2008 | Whirlpool GS6NBEXR Side by Side...
Defrost element
you can check if the heating element has a metal cover on top. water should not be dropping on the glass directly while it is heating up. that is the cause of heating element blowing up. glowing hot glass cools down by a cold drop of water equals dissaster.
Feb 21, 2008 | GE GSH25JFR Side by Side Refrigerator
Falling water hits something hot in freezer and causes sizzle sound
the sizzling noise is water hitting the defrost elememt and this is normal - shows the defrost system is working. if water comes on the floor of the freezer, this may be the drain for the defrost water is blocked. remove the freexer back panel and the drain is in the tray where the defrost water is caught. if it is blocked - usually with ice - clear it with hot water and make sure the water drains freely. takes some patience and maybe several attempts
Jul 13, 2007 | KitchenAid Superba Architect KSCS25IN Side...
GE Monogram ZICS360NRRH C... Bottom Freezer Refrigerator Logo
352 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
